Definitely not as bad as Michigan roads but they have their spots. Most of the roads around me are in pretty good shape currently, but the winter was very mild so not much damage was done.
FCAB - what’s best?
Originally posted by enjoy_m3 View PostCan anyone chime in the NVH on the turner monoball? They claim there isn't but I'm not so sure
I don't use them anymore because I use DTM Style control arms now, and these don't use standard shape fcab.
If someone in Europe wants a set, I may sell mine since they are just laying around...2002 E46 M3 TiAg Coupé >> full tracktool conversion @m346gt
Such a predicament for my DD: don't like the OE experience and don't want road salt and back road dirt in expensive Turner monoballs, but thanks to you lot I'm always nervous about my Rogue polys! (30k and counting...)Last edited by ethan; 05-07-2020, 09:04 AM.
The Turner monoballs are delrin isolated, so it's not straight metal on metal through (similar to a "street" camber plate vs a track one-- the street plates have isolation materials, in addition to the monoballs).
For a DD, I'd do OE(M) everything on the car than potentially RTABs.
Originally posted by Obioban View PostFor a DD, I'd do OE(M) everything on the car than potentially RTABs.
Originally posted by ethan View Post
Can't see how it wouldn't, but your experience of it would likely depend on the rest of your suspension setup. I.e. it might be very noticeable on an otherwise stock car but not so much on one with race camber plates. Anyone on the forum using Turner monoballs on a mostly stock suspension?
Went through a ton of gravel in Maine and New Hampshire when I did a road trip with the M3, no issues yet. I grease them regularly to keep the dirt away.2002 M3 Carbon Schwarz/Black 6MT
Rein is the R in CRP (Continental-Rein-Pentosin), so not a cheap knockoff brand per se. Some of their stuff I've bought has been totally fine and clearly equivalent to OEM. But I've also heard of some parts being low quality. I don't know where the FCABs would fall
As far as poly, I have driven an M coupe (99) with poly FCAB's and the steering was very nice/direct, no annoying additional NVH that I could detect but those cars have a lot of NVH to begin with.
Originally posted by slavik1988 View Post
I run Turner monoballs on KW V2s. The only time I feel them is where there are seams in the road. There is a noticeable transfer of harshness into the steering wheel. I accepted the trade off for the gain in the direct responsiveness I get from steering inputs.
Originally posted by Seagull View Post
What would you recommend there? It's too late for me now, just had the RACP reinforced and replaced the subframe and all the bushing and RTABs with OEM, but curious what you would recommend
Avoid poly like t̶h̶e̶ ̶p̶l̶a̶g̶u̶e̶ covid
I'd go with one of the monoball options. I'm using Turner's sealed monoball and am quite happy with it. A lot of people here (including Obioban I think) are using the Synchro Design Works unit. Dinan's another good (but expensive) option. If I were buying today, I think I'd go with CMPAuto's assuming no major COVID delays etc.
Anything sealed with high quality bearing should be good, but I think CMP and Dinan have the best design-- with them being equal, and CMPs being considerably cheaper.
