Thanks guys for the correct torque of 200nm or 147.5 ft lb.
This higher torque just makes it harder although an impact driver may be the way now. BTW, I was able to screw it in by hand a couple of turns before using any tools so I don't think I cross threaded.
On a similar thread, someone suggested Nord-lock. Do you apply the same torque with the Nord-lock?
On a side note, do you tighten the fronts diff bolts first or the rear? Does it matter?
