Originally posted by heinzboehmer
F8X M3/M4 CF Drive shaft mod
It does increase responsiveness significantly. I have single mass + carbon driveshaft + solid rear end on my e92 m3. It feels like the rear end is bolted to the gas pedal, just going up and down the rev range is a pleasure in itself. once you drive the car set up this way, going back to stock trim the car feels lethargic and lazy.Originally posted by EthanolTurbo View Post
I personally hope this mod further decreases drivetrain clunking when shifting at low-medium RPM. Anything else is a bonus. I'm thinking in conjunction with the lightweight single mass flywheel this will increase responsiveness significantly.
- Likes 4
Mine is installed and I don't have any issues, but I was only able to drive 30km before I got stopped.Originally posted by Obioban View PostStill nobody has installed?
May get around to some more during the next days, I hope I don't get stopped again...
Last edited by Altaran; 02-29-2024, 11:38 AM.2002 E46 M3 TiAg Coupé >> full tracktool conversion @m346gt
Flanges are the same, there was concern about clearance issues due to the shift actuator sitting directly above. I believe somebody confirmed fitment, but I cannot comment on that since I have a manual.Originally posted by Derek //M View PostAre the flanges or driveshaft different for a 6sp and SMG?
got stopped?Originally posted by Altaran View PostMine is installed and I don't have any issues, but I was only able to drive 30km before I got stopped.
There are 2 versions of the f8x driveshaft with different lengths correct?. I guess it really doesn’t matter as the driveshaft has to be cut down regardless. A donor e46 m3 driveshaft is needed to source the flanges. Anything else?
Part number 26117855000 is 1477mm in length.
Part number 26107857629 is 1471 mm in length.
BBS - Recaro - JRZ - PFC - Dixis Spirit - Supersprint - Haimus - Vorshlag - RKP - YFCM - Ground Control - DMG Autosport - Diffsonline - Autosolutions - Koyo - Mile End Composites - GC
It doesn't matter which one you get. One is PreLCI (cheaper), the other is LCI. You can use a donor E46 330i driveshaft or you can splurge and buy new end pieces like I did.Originally posted by Projecte46m3 View PostThere are 2 versions of the f8x driveshaft with different lengths correct?. I guess it really doesn’t matter as the driveshaft has to be cut down regardless. A donor e46 m3 driveshaft is needed to source the flanges. Anything else?
Part number 26107857629 is 1471 mm in length.Instagram: @logicalconclusion
Can you share the part numbers for new end flanges? I only see CVJ part number 26117841003. What about the other side that bolts to the guibo? Any other miscellaneous parts needed?Originally posted by EthanolTurbo View Post
Are you able to get the driveshaft registered on your papers? I only have a vague understanding of how TÜV works, and what’s allowed as far as custom parts and repairs/upgrades vs tuning parts that are explicitly TÜV approved.Originally posted by Altaran View PostCops. Here in Germany they like going after modded cars...
