Originally posted by bigjae46
Tested and Ready 70° and 75° Thermostat
Not sure. I'd guess that it factors into the tune at least for emissions purposes which is why the engine with throw a code for a t-stat. I have an epic tune...I'd have to guess that it would not affect anything. I'm the wrong person to give a definitive answer.Originally posted by CrookedCommie View Post
Not sure, does DME maintain mixture based on coolant temps? Need to check data on how fast the oil temps came up. I'd like to avoid the hassle of having to block the grill during cooler events.
I thought it only did that on open loop start up.Originally posted by CrookedCommie View Post
Yep I'm pretty sure you're right.Originally posted by ac427 View Post
A search of the code suggests that it might have some very minor effects on things like accel enrichment, but the only other side effect I can see is you'll slightly more easily trigger a "cold start" when restarting the engine when it's warm, which is neither here nor there.
Can't see anything in the mixture path that is affected by TMOT once in closed-loop operation (at that point it's all ambient pressure and intake air temp (plus exhaust temp for the CSL)).2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
