Thanks, here is a pic of the chain tensioner hole.
Engine noise
The threaded hole still has plenty good threads.
It's safer to chase the threads from inside to outside, but you also can do this from outside by using a guide -- something with the inner diameter same as the tap OD and place the guide flat against the hole lip -- this will huide the tap straight. The tap should turn free after a few turns. If not then stop and check, or run from inside.
I tried to clean the threads today but the tap wasn't the correct size, I used a m22x1.5. it was too small.
I found this post, so I figure it's m26x1.5. it says it on post #8. It don't list s54 engine. But they got 2 sizes 22 and 26, I will try the 26
https://nam3forum.com/forums/forum/m...sioner-w-o-oilLast edited by M3powerzz; 03-18-2024, 07:40 AM.
I may be late to this party but what all have you already replaced?
Did the valve cover break because the chain hit it (there will be witness marks in the shape of the chain)?
-If so did you do a leak down test to see if it had bent valves?
I had a similar failure with a customers car years ago, one of the tabs dropped onto the chain, then rode it up and got between it and the gear which lifted the chain blowing a hole in the valve cover like you have pictured. That car didn't bend any valves but it did tear up the sprockets AND the Timing Chain (amongst other parts as well).
Just throwing this out there to make sure you are fully repairing this failure... From your pics and short replies I think there is likely more damage in this engine and you are going to be chasing failure after failure if not done correctly.'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
Originally posted by George Hill View PostI may be late to this party but what all have you already replaced?
Originally posted by M3powerzz View PostThe valve cover does break because of the chain, I didn't do a leak down test as yet.'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
