Transmission trouble
    Originally posted by E46m3zcp View Post
    Well the bread trick isn’t working for me. Pilot bearing’s blue “cap” broke and the bread is coming out through the bearing. I tried for about 1h and it won’t budge. What do people use for this?
    Click image for larger version Name:	IMG_6003.jpg Views:	0 Size:	167.3 KB ID:	267467
    Click image for larger version Name:	IMG_5998.jpg Views:	0 Size:	139.3 KB ID:	267468
    Thinking of using J-B weld to glue a washer to the front, blocking the bread from coming out. Is this a bad idea? (taking care not to glue the sides of the bearing in)
    Pilot bearing puller and save yourself another hour and some bread - https://www.autozone.com/transmissio...E&gclsrc=aw.ds
      This tool does not fit. Hopefully this can save someone a visit to the store
        That's unfortunate. Maybe it could work with some modification to the hooks. Otherwise, the other option is the slide hammer - Link . The genuine tool was 250 and seems to be NLA - Link .
          I finally got it out with the bread. Yesterday I was making the bread too wet, and it allowed it to come out through the sides for being too wet. The trick today was not add moisture to it, just push it in as it is from the bag
            Supposedly you can also do this with wet toilet paper which may not break down as easily as wet Wonder bread.
              Lol, this makes me "wonder". What makes you say I used Wonder bread? 😂
                I would think this will work better than bread -- 50 cents from Walmart:
                  I would throw that pilot bearing in the trash. Those bearings don't fit correctly in the crank flange and will be loose. Get a Genuine BMW.
                  Email to [email protected]
                    Yeah I had bought another genuine one. Just brought the one from the kit to test fit the tool 😁
                    I also got a Sachs TOB but it looks different than the one that was installed on the transmission, I’ll try posting a photo later
                      left is Sachs, right is the one which came in the Luk kit (INA). The metal part that contacts the pressure plate is loose.
                      Click image for larger version  Name:	IMG_6044.jpg Views:	0 Size:	118.1 KB ID:	267632
                        I think you're talking about the bearing thrust axial plays, which is fine because the bearing is under a slightly preload so it's not loose any more when installed with slave rod pushing on the fork.
                          I don’t think it’s axial play. The top of the bearing isn’t clamped. What you said about preload still applies.
                          Mine came exactly like in this video
                          https://m.youtube.com/watch?si=AfK9TzeaK7XYoFYF&t=33&v=x9LWkST1gIA&featu re=youtu.be
                            I've replaced more BMW TOBs than I have LuK TOBs, actually I have not replaced any LuK for that matter.
                              What is the proper way to install a slave cylinder on an SMG. I have ISTA+, had a look at the TIS, and It's very trivial. What makes me doubt is, there is nothing said about bleeding.
                              Is it better to pre-fill the slave cyl. with Pentosin, does the bleeding procedure in INPA or ISTA take care of everything?
                              I'm curious about the mechanical way in which air makes its way out of that cyl., since there's only one line. Anyone knows? When things don't make sense to me I get paranoid. I don't want to have to remove the slave cyl. once installed on the car! Thanks
                                Anytime you open the system you will have to bleed. Filling with fluid is fine. Slave cylinder is nothing to be worried about.
