e46 M3 Community-designed CAD files Master List
    Awesome! This will be super helpful. Btw, I see you’re in the Bay Area as well, would you know anyone who’d be willing to let me scan their CSL airbox? Have someone willing to let me scan it if I can bring it over to them. I do have someone willing to let me scan their box already, but I’m not sure when that would be.
      For everyone else, I’ve been working on a mirror switch block off trim piece, need to work out some fit issues, will upload once I’ve gotten it to fit
        Originally posted by Vanar View Post
        Would you be able to get a download for the two scans you posted onto Google Drive or something like that? I’m trying to create a snorkel that would directly duct from both the brake duct and the upper kidney grill duct. Appreciate the help!​
        Lol looks like we both had the same idea!
          Sway bar reinforcement brackets for use with bigger sway bars or if your mounts are deforming. These are designed to be bonded and riveted in place to prevent corrosion or stress cracking from welding.
          Purchasable via this link at sendcutsend: https://cart.sendcutsend.com/li65gku0oex1 or by taking the DXF or STL attached to your favorite metal shop.
Name:	Reinforcement alone.png
ID:	362938 Click image for larger version
Name:	Screenshot 2026-08-02 at 12.20.36 PM.png
ID:	362939 Click image for larger version
Name:	Reinforcement on chassis.png
ID:	362940 Click image for larger version
Name:	Reinforcement with sway installed.png
            This little oil cooler clip is broken on most e46s and is never replaced because *each side* is $30. Well, we weren't having any of that so I CADed and printed some FRP (ABS-GF in my case) ones. Here they are, mated to a factory plastic one and mated to themselves. I also included CAD for a beefier version, which I haven't printed yet but it may be less likely to fail, particularly if you're not using fiber reinforced plastic. This should cost you <$1 instead of $30.
Name:	Oil Line Clip Beefy.png
ID:	363388 Click image for larger version
Name:	Oil Line Clip.png
ID:	363383 Click image for larger version
ID:	363381 Click image for larger version
ID:	363384 Click image for larger version
ID:	363382 Click image for larger version
            3mf file I used is also included if you have a dual head printer
Name:	Screenshot 2026-08-09 at 12.32.43 PM.png
ID:	363380 Click image for larger version
              Aaaand printing. Will be a very nice replacement for the current zip ties.
                Thanks, I printed these out of some PET-CF I had and they came out great.
                2004 M3 Silbergrau (Silver Grey) ◙ Convertible ◙ SMG ◙ Karbonius CSL Airbox ◙ Mullet Tune ◙ Front 996 Brembos ◙ Status Gruppe V2 Headers ◙ CPI RTX Sec 1 ◙ Kenwood DMX958XR
                  Nice!!! Will be printing
                    Alarm cover replacement plastic mounting pieces. These three parts replace the two parts in the car and critically are installable without dropping the headliner because the upper part is separated in two pieces. Each part is backward compatible with the original part (meaning you can print and install just one and don't need the other) and the alarm cover includes an improvement of 3 engagement teeth instead of one that likes to break off.
                    Alarm Cover 3D files.zip
                    Print orientation matters if you want the teeth to be sharp. Pay attention to the photos or use the supplied 3MFs
Name:	cabin iso view.png
Name:	full section view.png
ID:	614151 Click image for larger version
ID:	614150 Click image for larger version
Name:	teeth section view.png
Name:	alarm cover clipper print orientation.png
ID:	614148 Click image for larger version
Name:	Roof clipper print orientation.png
                      Weighted shift knob inserts to convert your standard or lighted shift knob into a weighted one. Get this printed from stainless steel and it will be ~100 or ~110g vs the 83g factory part. Print should cost around $50 shipped, which is much cheaper than a knob.
                      Two versions:
                      1) Weighted knob insert.stl.zip is a 1:1 of the factory part (I fit tested this one, good to go)
                      2) Weighted knob insert_nodrafts.stl.zip removes the casting draft angles to add an extra 10g (I did not fit test this one but it should install just fine)
                      Click image for larger version  Name:	Screenshot 2026-10-22 at 6.12.55 PM.png Views:	0 Size:	168.6 KB ID:	614154 Click image for larger version  Name:	Screenshot 2026-10-22 at 6.12.33 PM.png Views:	0 Size:	370.5 KB ID:	614156
                      Quoted on craftcloud.com:
                      Click image for larger version  Name:	Screenshot 2026-10-22 at 6.14.52 PM.png Views:	0 Size:	189.3 KB ID:	614155
                      Click image for larger version  Name:	IMG_0825.jpg Views:	0 Size:	86.9 KB ID:	614162 Click image for larger version  Name:	IMG_0813.jpg Views:	0 Size:	62.7 KB ID:	614160 Click image for larger version  Name:	IMG_0814.jpg Views:	0 Size:	67.9 KB ID:	614159 Click image for larger version  Name:	IMG_0848.jpg Views:	0 Size:	50.1 KB ID:	614161
