CF doors by Carbon Microsystem
    We make the moulds from high-quality shrink-resistant resin and they have special inserts for aligning the two sides of the doors. Therefore, when we glue carbon doors, we can guarantee that the doors will have the same geometry as the original door.
    We also scan some parts, but this is more for modeling and not for control.
Name:	WhatsApp Image 2025-01-24 at 13.09.20.jpg
Name:	WhatsApp Image 2025-01-30 at 10.38.12.jpg
Name:	WhatsApp Image 2025-01-31 at 18.15.41.jpg
      Depending on price I would be interested in touring doors or even a hatch.
      Email to [email protected]
        I think the crash bars will be useless on these doors. On any impact, carbon fiber generally will shatter not deform like metal. I am just thinking if there is an impact along the side of the car, I would think the carbon fiber would shatter at the crash bar mounting point from the force causing the crash bars not to anchor like it is supposed to do making them useless.
        It seems the only way to get true protection from side impact when using these carbon fiber doors is a having a full roll cage.
          The crash bar is threaded, and the anchor bolts directly to the bar, not the door. the door itself only contributes a mounting hole that orientates the bar.
          considering when the door is closed that the anchor point is only millimeters away from the grab point of the chassis, imo I don't think the door skin is contributing anything meaningful structurally in an accident
          Fwiw I sold my doors to a guy with a dedicated track car, he bought them because he was told that you can strip a door to kingdom come as long as you keep the crash bar. As soon as you stop using it is when they make you run door bars/roll cage.
            It depends. The yield strength on the carbon can be significantly higher than steel and aluminum. Layup of the carbon and different cloths can double the strength. I'd guess that the door panel would contain a lot of the debris. No real way of knowing without testing or a lot of engineering.
            That said, I personally would only install carbon doors on a caged track car where I wear a helmet with the visor down.
              Another batch of carbon doors has been shipped.
                I will add some new photos of carbon doors for BMW E46 coupe
                  We are currently planning to start production of carbon doors for E46 Touring and Sedan. If anyone is interested, write to PM.​
                    Original doors for BMW E46 Sedan and Touring have arrived. We are starting production of new moulds.​
                    The weight of the original doors is 15 and 12 kg
                    The weight of the carbon door will be approximately 3 kg.​​
                        Looking forward to these! Thanks for taking this on.
                          The first door for the E46 Sedan/Touring is disassembled and ready for production of door interior elements.
                            Wow very nice! Easier to do dent removal after the panels have been separated?
                              Happy to see the development work!
                              My only nitpick from when i had my doors was that the outer skin in carbon was much more flimsy than stock, I think the touring guys would appreciate a little more material to stiffen it up at the expense of some weight
                                What do you mean by that? Was it reverberating while you drove or just if you pushed against it that it would flex?
                                The doors are shorter so not as long of a span to bridge, maybe not the same issue in that case?
