Originally posted by marksae
Where's your IAT? (CSL guys)
Originally posted by beyondm3 View Post
What is the point of this instead of using the CSL IAT? Why not just relocate the original?2004 Silbergrau Metallic 6MT
I relocated mine to the air duct below the snorkel/intake, it was after the one on the Turner box was heat soaking so Hassan recommended I relocate to around here. Has been pretty solid since:
Last edited by siamkazi; 03-05-2024, 08:45 AM.| 06 6 Speed Vert - JB on Cinnamon| Beisan | ACL Rod Bearings | ST Sway Bar | TMS CSL Box | Megan headers | H.T.E Tune | 550 Injectors | OEM Section 1, 2, 3| 200 Cell Cats | OEM SSK | Bilstein B12| 712 yellow tag |
Originally posted by elbert View PostHow are you guys checking the IAT values? INPA or a "hidden" OBC function?
Sorry for the noob level question
Also, I'm not sure why the tuner is suggesting putting the Beru (E34) sensor down in the lower brake duct intake tract. The air going into the intake manifold won't be nearly as cold as that area. The engine will be reading a colder air temp and my guess is throwing more fuel into the engine.
On the other BMW engines using this Beru sensor, it is mounted either in the intake manifold or after the air filter. I think that the CSL snorkel or better yet the unfiltered section might be a better location to mount this air temp sensor.Last edited by Slideways; 03-05-2024, 08:45 PM.
INPA or Testo
On the other BMW engines using this Beru sensor, it is mounted either in the intake manifold or after the air filter. I think that the CSL snorkel or better yet the unfiltered section might be a better location to mount this air temp sensor.Last edited by ac427; 03-06-2024, 11:57 AM.
Exactly. BMW Did loads of developement with the IAT sensor in the airbox. Heatsoak or not, allowances in the original CSL tune must have been made to account for the IAT's position.
I'm curious what other symptoms people experience from the heat soaked sensor other than reporting of higher temps. I seem to have only read about higher temp readings and not so much lower performance and the like.
I was using the IAT that came with the turner box (this was back in 2021 at Autoclub Speedway here in SoCal in the early summer) when we started noticing idle hunting, lights on dash, and the motor running lean. If I recall, it was reading temps super high, was chatting with Hassan and the suggestion was that the IAT was heat soaking. Came back, used the current IAT and relocated to the duct, had Hassan make some changes, and it's been smooth ever since (including sessions at Buttonwillow etc). Mind you, this is my own story so I'm just sharing my experience.| 06 6 Speed Vert - JB on Cinnamon| Beisan | ACL Rod Bearings | ST Sway Bar | TMS CSL Box | Megan headers | H.T.E Tune | 550 Injectors | OEM Section 1, 2, 3| 200 Cell Cats | OEM SSK | Bilstein B12| 712 yellow tag |
