Has anyone here actually weighed their vehicle?
    Originally posted by tr3flip View Post
    What Ian said. I did it mostly for weight savings as I was competing heavily in Bimmer Challenge and Global Time Attack. All the lighter, faster guys had AC delete and ZF swaps. I've since gone back to 6 speed. The ZF felt like shit even with new detents, bushings, etc.
    Used to be able to get a ZF for $250-$500. Now its $500-$800 which isn't terrible. Used to be able to make it essentially a no-cost swap.
    In addition to the other points, there are a lot more clutch options for the ZF 5 speed which don't cost an arm and a leg. Most popular is the E34 M5 clutch and a Sach HD pressure plate.
    As far as the feel of the gearbox, a fresh ZF will be WAY better than a fresh 420g. That's one thing I noticed back in the 2000's. The ZFs are all over 20 years and maybe 30 years old so there is a lot of variance in the condition of the internals.
      You can also check this:
      GT4 Composites
        That sounds weak...lol Making the car track only makes weight loss decisions easy but quite difficult for a street car especially if it can't be undone.
        The carbon cabin filter housing would be a good weight loss opportunity. You could remove all of the rear speakers and use a nice neo mag midbass in the front doors which doesn't cost a lot and will cut some weight.
        The one good thing about carbon panels - no door dings!
        What is the neo mag midbass in the front doors which doesn't cost a lot and will cut some weight?
          Sound deadnening is like 30lbs, I prefer to remove it and keep more interior parts instead
          Complete audio with wiring harness can be removed and just get a Bluetooth speakers and put it on passanger seat for longer ride!
          Door airbags can be removed and coded like CSL.
          You can drill holes into trunk hinges, cut some sheet metal and drill holes into dash bar. On the lower steering wheel cover, you can drill plastic rivets and remove the foam and metal plate. Remove the foam from dash bar, remove some foam under floor carpet.
          Can also use titanium hardware!
          Are there any threads about the sound deadnening removal?
          I don't think I will be pulling the interior out to thin out the wiring harness, at least not yet.
          Pretty sure the door airbags are gone since the car has Hard Motorsports door panels.
            You don’t see this? Looks like at least 3 others have. Man I’ve had so much trouble attaching excel files on here for some reason.
            No I see the spread sheet but it is just an image, it is just not a fillable spreadsheet.
              Pros: 25 lbs lighter
              cons: no 6th
              people claim the 5 speed is more reliable, but I think that’s bogus-- 420g is a tank, and all the 5’s seem to develop 5th gear lean.
              Agreed, I also think having that extra gear is worth the weight penalty.
                Must be the way you’re viewing the forum. I see it when logged in and also when not logged in using an incognito window.
                  Its been years. I remember Pioneer and Alpine making a reasonably priced mid. I used a pair of Hybrid Audio mids which were outstanding but they aren't cheap.
