As far as gears...everyone has their own opinion...best best is to try it out and go from there...you're going to get a mixed bag of reviews and a ton of opinions on what each person personally likes...
288/280 vs 280/272 cams.
BBS - Recaro - JRZ - PFC - Dixis Spirit - Supersprint - Haimus - Vorshlag - RKP - YFCM - Ground Control - DMG Autosport - Diffsonline - Autosolutions - Koyo - Mile End Composites - GC
Can anybody share the source information on where they verified that the BMW rocker arm PN 11-33-7-549-034 are DLC coated?2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
My data point: 288/280 Cat Cams with new followers (oil bridge and E39 M5 pressure relief valves), Turner CSL airbox, Euro headers, stock section 2, El Diablo muffler, Alpha-N dyno tune by HTE. The dyno run before mods yielded 292whp. After mods and multiple runs, it peaked at 346whp so gain of 54hp. I just swapped to a more free flowing race muffler. I'm going to dyno the car again to see if it did anything.
Originally posted by jager911 View PostMy data point: 288/280 Cat Cams with new followers (oil bridge and E39 M5 pressure relief valves), Turner CSL airbox, Euro headers, stock section 2, El Diablo muffler, Alpha-N dyno tune by HTE. The dyno run before mods yielded 292whp. After mods and multiple runs, it peaked at 346whp so gain of 54hp. I just swapped to a more free flowing race muffler. I'm going to dyno the car again to see if it did anything.
Originally posted by duracellttu View PostCan anybody share the source information on where they verified that the BMW rocker arm PN 11-33-7-549-034 are DLC coated?
Originally posted by arg617 View Post
Would love to know this as well. It's looking like I need to replace the head gasket so thinking of changing cams “while we're in there”. The Schrick rocker arms seem to be on back order, so would be great if these were a good alternative….
Originally posted by Martyn View PostI am many others have used the BMW 320i / 11-33-7-549-034 rockers without issue.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Sorry I haven't kept up on the thread, but just looking at the last couple posts, I wanted to confirm, the rocker arms from the P45 and P54 (same parts) are indeed DLC rockers direct from BMW.
I don't have my documentation/research still on hand, but I used these with my 288/280 cams. I will double check the part number, I wasn't aware these were NLA.
Sent from my Pixel 8 Pro using Tapatalk
Hei everyone! I need some help, i have som wear on both my camshafts wich have done 174.000km, they need to be replaced and i am thinking to do 288/280 with new rockers from Schrick, but my problem is that Schrick is on back order until end of 2024 and they say among others that you can not use OEM parts. Any toughts?
is it a option to go for 280/272 cams? I see some places say you can use OEM as long as they are new. But here also i see some places mentions you «have» to use dlc coated from schricks
Originally posted by Snagg30 View PostHei everyone! I need some help, i have som wear on both my camshafts wich have done 174.000km, they need to be replaced and i am thinking to do 288/280 with new rockers from Schrick, but my problem is that Schrick is on back order until end of 2024 and they say among others that you can not use OEM parts. Any toughts?
is it a option to go for 280/272 cams? I see some places say you can use OEM as long as they are new. But here also i see some places mentions you «have» to use dlc coated from schricksLast edited by digger; 03-23-2024, 06:16 PM.
