Porsche Brembo 996 BBK conversion
    Anyone running rear stock 18s square 255s? The rears clear really well, so why not just put rears on the front? Spacers required basically make it the same offset
      Spoke design also matters.
      I run stock 18x9 square with 265, 3mm spacer upfront just in case at autox wheel bearings give a bit, but it clears without. Rear has plenty of room without spacer.
      Youtube DIYs and more
        Just to confirm the leading piston (smaller) is at the bottom, correct?
            Never saw a resolution in here for whether or not these would fit behind 17x9.5 ET35 Apex Arc-8s. Any word, or should I be a guinea pig?
              You’ll need spacers. More than 5mm. I run them with 12.
                How are folks with apex 9.5" et35 wheels managing with he wheel poke on spaces? When I mount my 18x9.5 et35 with a 5mm spacer (to clear the brakes) I'm getting a lot tire extension past the fender. Enough to make me concerned about contact under full compression.
                Still on stock suspension with camber pins pulled.
                  In most cases camber, more of it.
                    Or run a 255 tire or a narrower 265 tire (as in, not michelin)
                    If you're on stock suspension, you won't have much neg camber while static (so it'll look like lots of poke), but because of your ride height, when the front compresses, the camber will go more negative, and should clear the fender fine on 9.5et30.
                      With a 275/40/17 Falken RT660 tire I needed more than 3 degrees of camber and a decently high ride height. With a 255/40/17 RS4 tire it’s more like two.
                        But was that with the 12mm spacer such that the wheel was 9.5et23? Most run 9.5et22 with 265 tire and -3 to -3.5 camber.
                        Begs the question - why not just get the typical 9.5et22 wheel which would then negate need for spacers up front AND in the rear, and you could still rotate front to rear.
                          Yea, that would have been smarter, but I didn’t know that ~4 years ago when I put these brakes on and bought the wheels.
                            Same, I got 18x9.5 et35 on a 265.. had to put 10mm spacer to fit over the brakes. Punching the air, should’ve got the et22
                            2006 ILB | M-Texture
                              I wish I could have Brembo brakes. I don’t think I can’t have it with my wheels spec
                                You can get 6 pots which will suit your car better anyway.
