Originally posted by Arith2
DuracellTTU Build: 280/288 Cams, Lang Head, CSL Airbox, Full SS w/ Dyno Results
2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
Originally posted by bigjae46 View PostNice build! It’s hard to hang in there as an original owner. I’ve been thinking about selling my E90 M3. This thread will help convince me to keep it!
I have countless hours of research and labor into this car. Starting over on a new platform just didn't make sense. This car has been completely personalized and customized to me. No other stock car in my budget can match it. The only car I'd want to move to is a GT3, but that won't be anytime soon.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
Very nice build and numbers!
Have a very similar build to you as well (SS catless, 280/272 cams, 12:3:1 comp), and had Hassan tune my car.
Made 363whp, but our crappy 91 Octane and higher compression here was the limiting factor.
Would be very interesting to run a higher grade octane or Ethanol blend (will have to wait for the border to open to get to the states). Was told that there was probably another 30-40whp left on the table.TiAG 6mt Coupe | KARBONIUS | SUPERSPRINT | FIKSE WHEELS | OEM CSL | MILE END COMPOSITES | AST 5200 | HOTCHKIS | BREMBO | RECARO | BEISAN | CATCAMS | CP-CARILLO | TMS | RTD | ROGUE ENGINEERING | AKG MOTORSPORT | HTE PERFORMANCE
Sae dynojet?TiAG 6mt Coupe | KARBONIUS | SUPERSPRINT | FIKSE WHEELS | OEM CSL | MILE END COMPOSITES | AST 5200 | HOTCHKIS | BREMBO | RECARO | BEISAN | CATCAMS | CP-CARILLO | TMS | RTD | ROGUE ENGINEERING | AKG MOTORSPORT | HTE PERFORMANCE
Correct
You should post that dyno in this thread: https://nam3forum.com/forums/forum/m...s-280-272-camsTiAG 6mt Coupe | KARBONIUS | SUPERSPRINT | FIKSE WHEELS | OEM CSL | MILE END COMPOSITES | AST 5200 | HOTCHKIS | BREMBO | RECARO | BEISAN | CATCAMS | CP-CARILLO | TMS | RTD | ROGUE ENGINEERING | AKG MOTORSPORT | HTE PERFORMANCE
Originally posted by ethan View PostAwesome build. Can you comment on changes (broadly speaking) you guys had to made to the CSL tune to accommodate this hardware? How was the AFR pre-tune? Thanks for posting.
Would be very interesting to run a higher grade octane or Ethanol blend (will have to wait for the border to open to get to the states). Was told that there was probably another 30-40whp left on the table.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
Speaking of which, can we please make the database a 'Sticky'?
Here is a summary of the mods:
2005 ZCP w/ 155k miles at the time of the build.
Karbonius CSL Airbox (OEM trumpets) w/ OEM Snorkel and operational flap
Lang Stage 2.5 head w/ Supertech valves and springs
Schrick 280/288 cams, 12.5mm lift w/ DLC rockers
Port exhaust side of head
SS V1 stepped headers
SS catted section 1
SS resonated twin pipe section 2
SS race mufflers
Kassel Performance CSL ECU conversion
Kassel Performance MAP sensor
TMS underpower pulles, water pump and power steering
SPAL electric fan conversion
Turbo Toys V3 exhaust hub
Custom tune by Paul Claudes
91 octane pump gas
Mainly the valve spring kit. I've got a good idea on which valves I want to run but I haven't had any luck figuring out which springs work well with a set of 288/280 and/or 280/272 cams.
Was kind of leaning towards just the Supertech valves and leaving the stock springs until I came across this thread.
Thanks in advance.
Originally posted by Hamilton View Post
I know this thread is 2 years old now but I just wanted ask OP if you by chance had the part numbers for the valve and valve spring kits that Lang Racing uses in their head service.
Thanks in advance.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
