Quiet Lightweight Flywheel?
    Sreten of M539 restorations used a lightweight (~ 4 lbs. lighter than stock) dual mass flywheel from PTB Racing on one of his cars. Skip to 16:40 in the video to see it.
    Old, not obsolete.
      That's awesome, but a custom built one probably costs more than I'm willing to spend.
        BBRTuning Isn’t your single mass fairly quiet?
          I forget the brand, it was made it the UK, got it though Matt as Euroconnex. Its for my E63 M6, so not the same, but replaced a dual mass and I have zero NVH issues with it.
          I *think* they make one for the M3 as well, but who knows if it will act the same.
          TTV Racing
            • Designed to bolt to OEM clutch
            • Compatible with OE starter
            • Installed using Genuine BMW bolts
          • CNC machined from a forged high carbon steel billet
            • Dynamically balanced by TTV from the factory
            • Fitment for MT and SMG2
          • Weight:
            • Single mass: 5.3 kg / 11.6 lbs
            • OEM: 10.97 kg / 24.2 lbs
            Thats the one.
              I have a JB Racing flywheel. It sounded like marbles in a glass jar with the 420g. Mostly quiet with a ZF320 although the car has always been a tin can with the ZF320.
              The rattle might have more to do with the transmission than the engine.
                I run the same setup with my zf320, the 420g is a noisy box.
                  Dinan used to make lightened factory flywheels for the e39 M5.
                  Partee Racing has taken over making them for that market. Don't know if they'd be interested/able to do it for our flywheel. Will link Peter to this post....
                    Same. But the ACT clutch from my JDM days was much worse. For a street driven M3 the trade-off wasn't worth it to me. One day I'll go back to stock.
                      TTV Racing
                      • Weight:
                      oh wow, this one?
                      1011 – BMW S54 Lite Lightweight to suit standard Clutch and Standard 6 Speed Gearbox Standard weight single mass flywheel for SMG Gearbox Models Available Requires Flywheel Bolt :  BMW 11 22 7 805 885
                      Seems like they have others too for the S54:
                        Nice. I liked the sound the Grand-AM. ~19.4 lbs
                        Click image for larger version  Name:	image.png Views:	0 Size:	20.3 KB ID:	329284​
                          Unfortunately that's the way this car was designed, it's meant to have a dual mass flywheel... as soon as you go to a single mass, you're going to get chatter, it's just the nature of the beast.
                          My ACT is pretty decent, and there's days where it's not even loud. But, then again, there's days where it's pretty loud.
                          I think it depends on how hot it is, the angle the car is at, and possibly other factors.
                          Normal for it to chatter when you kick in clutch pedal at at low rpms 1st/2nd? Loudest for me after a bit of driving too.
                          '05 ///M3 Mysticblau Metallic / Grey Nappa 6MT
                          '24
                          Audi RS5 Nardo Grey / Black​
                            Yeah exactly, it's after I've been driving for awhile, when I put in the clutch at a stoplight. I've never heard it in 2nd. I only ever hear it when I put in the clutch and I'm not moving.
                            2004 Dinan S3-R M3
                            2023 X3M Competition
                              Chrisyphus
                                I dont see any reason we couldn't do it at first glance. I'll discuss with Peter next week.
                                E92 M3, 6MT
                                Head​ of Engineering and Design
                                ParteeRacing.com​​
