Bricked MSS54HP, turns on for a few seconds
    Engine was able to run for a sec, so I think the DME firmware programming is ok. Can't imagine engine can fire up with corrupted codes/data DME.
      Originally posted by Nexite View Post
      I flashed an MSS54HP with the CSL software
      Is it your original DME or a spare S54HP? To narrow down if it's hardware or firmware issue, I would install the stock DME back to test.
        Fires on one cylinder and dies sounds like what I experienced when having EWS delete issues.
        Unresponsive to software/programming tools and a maxed out temp gauge sounds like it is stuck in program mode. At least that is what I experienced.
        He has not responded, so maybe he sorted it out.
        Old, not obsolete.
          Hey sorry guys! This is a second DME, my stock dme works completely fine and I just did a 800 mile roadtrip on it no problem.
            Finally have some time to work on this again, I tried re-programming via winkfp, the DME is able to identify itself and report the old VIN of the car it was taken off of (I BDM the stock image back on) but then when WINKFP goes to actually start updating it it gives the following error. Comfort mode -> Update ZUSB -> MSS54 -> No vin entered -> Done -> Program ZUSB update. I know its been a while but any insight anyone could give would be great! Been running the stock Alpha N tune and its getting to me a bit lol.
            One note, the ECU seems to be more functional than it was before, it now properly reports the temperature and RPM of the engine to the gauge cluster but doesn't show the check engine light when turning the ignition to the second position (which I believe it does do on my normal ECU).
              Not a winKFP expert but I'm pretty sure that bootsectorupdate should not be active.
                I don't think it makes a difference for ECUs that don't have 0ba files anyway
                Honestly I wonder if his ECU is having the same issue one of mine on the bench was having. The slave CPU just drops out intermittently. A second ECU works fine
                  Is there any way to test this or good resources for the pinouts of the CPUs? I've got access to a good scope and multimeter.
                    Dunno if there's a good way to test. I think the pinout matches this, but not 100% sure https://www.nxp.com/docs/en/user-guide/MC68336376UM.pdf
                      I haven't messed around DME in a long time but if my memory serves me right, maybe you need to put it in boot mode.
                      Hello guys! I recently had a thread started of trying to troubleshoot the current state of my DME which was confirmed to be bricked from a mishap with MSSFLASHER. In the course of this thread, Terra mentioned that I can my particular error by grounding pin 37 on the master and slave of the EEPROM. I was also in contact with
                        Had some time to mess around with it and checked it out with a thermal camera. I found the main 5v rail tantalum bulk capacitor was getting really hot so I replaced it and now the DME doesn't turn off after a minute but I still can't communicate with it through INPA. The temp gauge on the dash works properly which means the DME is at least communicating with the dash.
                          I can view the ECU hardware ID in mssflasher and was actually able to see the hardware ID and in INPA I can see the expected software and assembly numbers.
