Originally posted by maximus5403
Brembo GT Kit and CSL/ZCP Wheels fitment question
Ease of pad swaps is the only benefit, but it's a HUGE benefit. Needing to take the caliper off to change pads sucks. I'd say easy pad swaps is at least 50% of the benefit of a BBK over the stock brakes, if you're tracking the car.Originally posted by bmw m3 s50 View Post
Is the ease of the pad swap the only benefit? I remember speaking with Dave Zeckhausen, he mentioned there were other benefits using the 4 piston over the 6 piston. I just can't remember what they were.
I have a vague memory, that the 6 piston were 2 piece vs the 4 piston which were 1 piece which improved on pedal feel at the limits?
I'm not sure of the pad selection for the 6-pot, but for the 4-piston calipers there is a massive massive selection of available pads.Originally posted by Obioban View Post
I was this close to ordering a set of EBC 6 piston BBK fronts. Was going to just pull the trigger, bc “no way should I need more than a 12mm spacer.” Good thing I decided to print out the template, bc nope… need 20mm spacers at minimum. So disappointing, I think I am just going to rebuild my comp brakes instead.2006 E46 M3 Interlagos Blue ZCP Slicktop "CS"
Get an 18MM spacer in the front. Rears will have ample space and will only need a spacer if you want a more filled out look.
20MM is the absolute max up front. I ran a 20MM with my 8" ZCP's. It was at the limit, and I could feel the feedback in my steering wheel.
25MM would be nice if it did not come at the expense of scrub radius and the wheel bearings.Last edited by AWE46M3; 08-17-2026, 11:57 AM.
