Originally posted by Obioban
Recommended Engine Mounts?
I've got the street. As others have said, my main complaint is the vibration caused when the AC compressor comes on at idle.Originally posted by Altaran View PostWhich Vibras are you running, the street or race?
Yeah you're right, I should try that before anything else. The mounts are great aside from the vibrations at idle.Originally posted by stash1 View PostTo everyone complaining about a slight vibration at idle w/aftermarket mounts...just try raising your idle by 50-100rpms. With the amount of tuning software options available, this is pretty easy to do, and will generally all but eliminate the little bit of vibration you’re experiencing.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Actually sorry I remember why I went with the RE Group N mounts now... they drop the engine 5mm... and the increase in stiffness was only 30%. so it meant i had a fresh new feeling but the engine sat at about the same level as it did with my super old worn stock mounts... I can run stock idle speed and get no NVH change. I have MSSMapper so can flick between a tune with 800rpm idle and 1000rpm idle and other than the change in engine note there is absolutely no change in NVH... I would say from my experience that anyone having NVH issues with RE Group N mounts has other issues and they are blaming the mounts.
Maybe because they arent paired with whatever transmissions mounts people are running? - I run RE Group N engine mounts and RE Tranny Mounts and no NVH issues... mind you I also run the TMS Poly Shifter bushing and RE Octane SSK and I can feel everything through that, but at a level I enjoy... but definately no vibration or rattling in the car and this is coming from someone who is lazy and if i break a specialist non generic trim tab I dont bother replacing it if the remaining ones hold well enough so my interior is not as securely in place as stock which should make me more susceptible to rattling etc...Last edited by STAATS; 06-20-2020, 08:06 PM.
Well I haven't driven my car too much because of everything that's been going on, but seems like the raised idle has eliminated all the complaints I had. No more vibrations at idle.Originally posted by stash1 View PostTo everyone complaining about a slight vibration at idle w/aftermarket mounts...just try raising your idle by 50-100rpms. With the amount of tuning software options available, this is pretty easy to do, and will generally all but eliminate the little bit of vibration you’re experiencing.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I’ve been running the BMW Motorsport Group N mounts for years. Love them. Like others I never noticed a NVH issue.
Been told the RE ones are a good copy and next best thing.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - Euro Bumper - Gruppe M CF Intake - Supersprint - M Track Mode
A side note.
I have the Vorschlag Poly Competition motor mounts on the race car. They work very well, BUT if you plan on a clutch replacement or tranny swap make sure you loosen the upper and lower nuts on the Vorschlag engine mounts or the bolts will likely break. My mechanic, nor I knew this and both were broken.
Terry Fair at Vorschlag gave me the heads up on this yesterday when I ordered replacement hardware (https://vorshlag-store.com/collectio...13-upgrade-kit). The actual poly bushings are still in like new condition, albeit a little dirty.
FeffLast edited by Feffman; 08-24-2020, 04:19 AM.
Vibra-Technics solid aluminum because M3 GT3RS. Stock is fine too.2006 Silber Grau Metalizat ZCP 6 MT
Just don't do poly. Think of it this way...you can go rubber and get kicked in one nut, go solid and get kicked in the other. Go poly and get kicked in both nuts. Poly has the downsides of solid and rubber...no upside.
Includes poly FCABs. What's the over under the passenger FCAB will last 3 months before it melts?
stock385.7whp 288.8 wtq :
-CSL airbox ( custom)
-280 272 Cat cams
-Custom SSV2, modified for a bigger collector
-Custom Section 1 2 and 3: oversized to 2.5 inch and en E9xM Xpipe
-TMS pullies
-Electric Fan
-HTE performance Tune :P
PM for performance Tunes
IG: https://www.instagram.com/hte_performance_tuning/
Has anyone tried the 034Motorsport's Density Line Mounts => https://www.ecstuning.com/b-034motor...4-509-3646~kt/
For reference, I am currently running the Vibratec Street and like them...but the passenger side has gotten super squished (along with other signs) that appeared to be about to fail. I was on the original group buy - so my set are about 7 years old with only about 35k miles on them. I know they advertised to be rebuildable, but my research tells me otherwise. I would like to replace it with something similar - slightly firmer than stock (my stock passenger mount collapsed about a quarter inch shorter than driver side after only 25k miles), but don't want much added NVH. The 034 mounts advertised to be made from solid 55 durometer rubber, where stock hydraulic mount are from 45 durometer with voids. Any inputs/experiences on the 034Motorsport's Density Line Mounts would greatly be appreciated. Thanks.
