Thanks, must have got one of the last sets. Can't really entertain changing wheels now
List Your Suspension/Wheels/Tires Setup in Great Detail
Those fit just fine. It's the ET35 wheel that has the spring perch clearance issue.
edit: is this why Apex recommends 5mm spacers behind ET35 wheels for “certain” coilover kits?
What’s the spring perch rubbing issue? Any way to mitigate? The R&T kit is high on my list along with 9.5 width ET 35 track wheels ...
The struts in the Ohlins BMS Mi30 kit for the E46 M3 were designed to work with the OEM top mount. When converting to aftermarket camber plates, the "stack height" of the camber plate is much thinner than the OEM mount. This strut spacer kit moves the strut up to accommodate for the thinner stack height of the camber p
Yeah, the 5mm wheel spacer is needed unless the Ohlins strut spacer is used to raise the strut body up ~20mm.
https://3dmmotorsport.com/products/o...rut-spacer-kit
Nice, thanks. I’ve been emailing these guys to assemble a kit and was planning on using this spacer, so that takes care of that concern.
Originally posted by jpiazzam3 View PostOk I’ll play
Front
VMR 710 19x8.5 et35 (gunmetal)
Firestone firehawk 500 255/35/19
dinan strut bar
hotchkis sway bars (middle setting)
koni shocks (softest setting)
eibach springs
135i 6pot calipers
ecs tuning 2 piece comp. rotors
Rear
VMR 710 19x9.5 et22
firehawk 500 285/30/19
dinan rear strut bar
hotchkis sway bar (softest setting)
koni (soft)
eibach springs
Porsche 996 4pot calipers
oe comp. 2 piece rotorsJust some old shitty cars.
Originally posted by y2k_o__o View PostFor 18x9.5 ET35 square, will I be OK without any spacer or camber for stock suspension setup ?
Front:
BBS E88 18x10 et21.5
Michelin PS4s 265/35/18
Camber: -3.6 degrees
Rubs: On full lock
Spacers: None
Springs: 5" 9k Swift
Shock: TCK DA
Camber Plates: Vorshlag
Ride Height: 13.25 inches
End Links: E36 M3
Control Arm: OE
Sway Bar: OE (powerflex bushings)
Tie Rods: OE
FCAB: OE
Brakes: 996 Brembo
Rear:
Camber: -2.4 degrees
Rubs: None (shaved fenders)
Spacers: 5mm
Springs: 4" hyperco 550lbs on gc weight jacks
Shock: TCK DA
Ride Height: 12.75 inches
End Links: Swaybar deleted
Camber Arms: Eibach
Sway Bar: Deleted
RTAB: Synchro Design
Subframe: Solid PSM / Vince bar
Brakes: 996 Brembo
MCS - Vorshlag - GC - Hotchkis - Supersprint - BBS - Brembo - Dinan - PSMax - SDW - VinceBar - DMG - Haimus - Karbonius - AEM
