Does anyone know the spring rates for the Bilstein B16 kit?
Coilover Recommendation
Originally posted by EthanolTurbo View PostDoes anyone have experience with MCS 2WNR?
For the purposes of my use for the car they are great. I love them when in the canyons and on track. They are not as comfy as compared TCK SA (450/550) which feel like pillows by comparison, (I also have Ohlins on my E92 - not a direct comparison Which are better for street).
Have considered going with the FCM Stage 3 setup. Met with Shaikh about a month ago to discuss and it seems like a better dual duty setup.
E46 serves as my “fun” car of the two and I don’t mind the “firmer” ride,2006 BMW M3 / Interlagos Blue / 6SPD
2012 BMW M3 / Santorini Blue / DCT
Originally posted by IceInMyVeins14 View Post
Is there a TCK Coilover conversion they sell that works with the regular Koni shocks and struts?
But the last time it came up on here, people mentioned that adding that on top of regular Koni struts led to bump travel issues, like the post you quoted mentioned.'03.5 M3 SMG Coupe - Jet Black / Black
Originally posted by r4dr View PostOn another topic, I'm curious why I always see TCK recommended and never hear Ground Control in the same threads. They're both Koni-based systems, what's going on beyond that?
However, I’m looking at TCKs site and it shows they have these components for a coilover conversion:
TCK's valving is better than GC's, by a not insignificant amount.'03.5 M3 SMG Coupe - Jet Black / Black
I was initially wanting to buy a cheap set of coils to lower the car and have better handling but have opted to wait and buy a set of MCS 1 wnr. From the reviews they are a proper track shock while still being comfortable and compliant on the street. Just the dampers are 2700 though . A full setup with eibach springs, top plates/mounts runs about 3900. Essentially $4k in coilovers which is why I'm putting the purchase off for as long as I can haha.
Originally posted by SUPREM3 View Post
I have them. Setup close to flat ride via FCM (Technically Need 850 rather than 800 in the rear).
E46 serves as my “fun” car of the two and I don’t mind the “firmer” ride,Instagram: @logicalconclusion
I also have Ohlins on my E92 and love them. I drive my M3 mostly on the street but will start tracking it soon: should I stick with Ohlins or go to MCS2WNR? Is it worth the extra $1k+ over Ohlins?
Gesendet von meinem LON-L29 mit Tapatalk
Originally posted by HighSchoolDream View PostAdjustable front sway bar end links a must when going aftermarket suspension? What brand is preferred?
IMO Turner's sealed adjustable are the best out there, if your sway bar is compatible with them.
One adjustable end link lets you dial out preload. Two adjustable end links lets you dial out preload and set the sway bar to be perpendicular to the end link.
Are adjustable endlinks necessary if your lowered? say 13.5" ride height from wheel to fender.
If you're willing to micro tweak your ride height until there's no preload, you don't need adjustable end links. But, that process would be a huge PITA and there's no way to do that and corner balance the car.
So, functionally you need them. Technically you don't.
