Originally posted by Obioban
Megan Racing Headers Install
Originally posted by Circa Surviven View Post
For sure! I have 18 new ones ready to go. The local dealership has the torx studs in stock, so I'm going to use those instead of the stock design. We're they hard to thread for you? I've read a couple comments by those using them on the e46 m3, saying they were hard to install by hand and they stopped trying in fear of stripping the head.
Originally posted by Johnvu View Post
They went on pretty easily. If it isn't threading easily, it is likely that you aren't centered. However, if it is tough, just get it down as much as possible before stripping lol.Garage:
2002 BMW M3: Slicktop jetblack/cinnamon. SMG to 6-speed. Arc-8's. Koni yellows/Dinan springs. Macht elbow. Megan headers. Stock section 1+AR20. SCZA section 3.
2001 BMW 740i
Only the threads into the block need anti-sieze, keep the exposed (sticking out of head) stud dry. With anti-sieze you should be able to bottom out the n54 studs on their "shoulder" by hand but some may require the use of a ratchet.
If using a ratchet only grip the head of the ratchet as to apply very little torque until you know you've got it then use ratchet handle to seat the stud fully.
A light coating is sufficient.
Cubie, it's the other way around. The threads for the copper nuts only require copper anti-seize to aid in removal if the manifolds need to come off at any point in the future. The anti-seize keeps the nut from seizing to the stud and pulling the stud out of the cylinder head.2004 Silbergrau Metallic 6MT
That does make sense but is it not a good idea to put anti-sieze on the studs to prevent the threads from potentially galling in the head? You do not use any anti-sieze on the threads going in the head?
TIS for reinstalling manifolds with new copper nuts using copper paste (anti-seize):
I thought everything went fine with the install last weekend because the car drove fine and didn't have any weird noises. Started it tonight after sitting for a week and it sounds like I have an exhaust rattle/possible leak in the front header area that varies by rpm. What's the best course of action? Pulling everything back apart like the heat shields and expansion tank to check if the heat cycle loosened up the nuts? I think the section 1 to header might be slightly grazing the heat shield even though I tightened the headers with cardboard between it and the shield.Garage:
2001 BMW 740i
Originally posted by Circa Surviven View PostI thought everything went fine with the install last weekend because the car drove fine and didn't have any weird noises. Started it tonight after sitting for a week and it sounds like I have an exhaust rattle/possible leak in the front header area that varies by rpm. What's the best course of action? Pulling everything back apart like the heat shields and expansion tank to check if the heat cycle loosened up the nuts? I think the section 1 to header might be slightly grazing the heat shield even though I tightened the headers with cardboard between it and the shield.
If you are sure you have a leak take your heatshields off a check if all the nuts are tight enough. It's not a bad idea to do this a little while after a header install regardless. I noticed a few haf loosened up on my last header install just a bit, or so it seemed.
Did the flanges on headers look flush, did you check them out before install?
Did you use factory gaskets and new factory nuts?2004 Silbergrau Metallic 6MT
I think some are able to bend the heatshield out of the way somehow if there is interference at headers/sec. 1 area.
Did you use factory gaskets and new factory nuts?Garage:
2001 BMW 740i
Whenever exhaust bolts and nuts get heat cycled, they can loosen. Could just be the new sound rattling your heat shields. Welcome to headers.This is my Unbuild Journal and why we need an oil thread
Originally posted by Arith2 View PostWhenever exhaust bolts and nuts get heat cycled, they can loosen. Could just be the new sound rattling your heat shields. Welcome to headers.2004 Silbergrau Metallic 6MT
Don't think the Megan headers would be thick enough, but on my SSv1's I had to slot the upper heatshield holes in order to raise it up so it would not contact the headers.This is my Unbuild Journal and why we need an oil thread
I think I had to bend the heatshield up now that you mention it. They aren't thin, that's for sure.Last edited by Circa Surviven; 05-15-2021, 04:49 AM.Garage:
2001 BMW 740i
I found the EGR had came completely off, I guess I didn't tighten it enough. I started the car and it wasn't rattling on idle on jack stands but it seems like the section 1 piping when connected probably grazes the top of the heat shield. I guess I need to loosen the bank 1-3 headers, put the section 1 back on and then tighten with cardboard shoved up above it.Garage:
2001 BMW 740i
