Climate comfort looks to be ~$700 shipped. Has anyone found a better deal?
OEM Windshield
Originally posted by Tom Day View PostClimate comfort looks to be ~$700 shipped. Has anyone found a better deal?
I know the junkyard has stigma attached but it can be a REAL goldmine there.
Originally posted by SteelGreyM View Post
If you want you can check your local junkyards for e46's. Take a quick visit and check for good windshields. You'd be surprised what you find there...
E46 M3 Coupe - 09/04 Production, 103k miles, Black/Black, 6MT swap, AS 0% kit, BBS RG-R + AS4’s, CSL flash, Karbonius airbox, Euro header + Section 1, Koni Yellow, Xtrons, SAP Delete, lockdowns complete
Originally posted by m3nt0s View Post
+1 to this, I assumed junkyard meant just that, and everything was actual junk. After going with a couple friends and finding some legitimately great parts I have no problem with sourcing junkyard parts again.
What I’m really talking about are those sweet sweet manual transmissions. Recently found a 540i at my local junkyard. After some investigative work I realized the car had EWS issues. Not even 4 hours letter you bet I walked out with the manual trans and the engine.
It blocks infrared without blocking visible light. End result is less heat entering the cabin through the windshield without impacting visibility.
Climate Comfort windshields were cool tech, and are a nice OEM solution but FYI modern nanoceramic films outperform them in terms of rejecting heat, and UV/infrared while doing so without blocking radar/toll pass signals (although I do believe there is a small square behind the mirror that does not have the polarization film). Such films are readily available locally and only cost $100-150 installed <1hr. Much cheaper and easier than replacing the entire windshield too. I have it on all my cars and will never not have it again.
Originally posted by robgill View PostI also recently installed the fully loaded ""green windscreen, green shade band, climate comfort windscreen and rain sensor" and do not notice the purplish hue at all. Makes me think it was only on early versions.
Sorry for wall of text this is one of the few things I have some input on.
I replaced my glass myself, I work at a windshield replacement company. I don't know any part numbers, but I made a point to put the climate comfort glass in when I realized that was an option. I actually like the purplish tint/hue, it's subtle and helps with the sun a little bit. If you're paying out of pocket don't go OE - rather Pilkington is the OE brand(OEM?). It will be the exact same part the dealer will sell you(minus the BMW logo) but will be significantly cheaper depending on how much your local glass shop marks it up. Have your glass company buy an OE molding from the dealer. They'll probably get a better price than you. Try to wash your car in the same week you take it to your glass guy.
I remember the molding around the windshield sucked to deal with, but cutting out the windshield was very easy; the urethane is rubbery and not particularly strong. After I got the windshield out I noticed that the urethane that holds it in wasn't applied with any sort of primer from the factory, and more or less peeled off easily from the top and maybe some of the sides. I have a grey car, but depending on the color of your car(different chemical compositions in the paint - I'm thinking white cars might be worse) the factory urethane might not be holding in your windshield in particularly well in the event of a catastrophic accident, so see replacement as a good opportunity to guarantee your windshield will stay in place properly for passenger airbags to work optimally, keep unbuckled people in the car in event of accident, etc etc. I took the factory paint off the pinchweld down to bare metal on the areas that the urethane didn't stick, and reapplied windshield primer from whatever urethane adhesive system I was using. (Dow/Dupont, but some people will swear by other companies/systems)
Merely food for thought, but here in AZ, rocks in windshields are a given, especially when chip sealing is done on the roads. Effin hate it. Sucks for tar on the car as well. Therefore I've had a zero deductible for glass with State Farm for thirty plus years here. No questions asked, I call and say took a rock, glass is replaced in my garage before you know it at $0.
