  • Slideways
    Can anyone tell what manufacturer date my pump is? Grok thinks it's a 2019 year
    Click image for larger version  Name:	IMG_2457.jpg Views:	0 Size:	101.8 KB ID:	356417​
    ​Click image for larger version  Name:	IMG_2458.jpg Views:	0 Size:	79.0 KB ID:	356418​
    Stamp shows 11.00, so November 2000
    Under the electrical connector, it should have the week of the year and the year.
    Not really in AI's wheelhouse.
  • bavarian3
  • karter16
    I haven't done the adaptation process for the new pedal yet.
    Do you know the process for this? Or is it just resetting adaptations? (I'm going to google after posting)
    I did test the wiring harness for proper voltage and ground. All the pins did their parts, so I'm ruling out wiring unless you all feel otherwise. I need to get real jumper pins so I can get the multimeter in the back end of the plug before I can test plugged in. I'll see what Amazon has to offer in the meantime
    As for the EML itself. The light will be intermittent and then came back on today after a few minutes of idle.
    Just had a check and confirmed:
    - zero point adaption happens during the pre-drive check every time you start the car.
    - 100% point adaption happens in the followup (period of time after the car is switched off after driving) if one of the following is true (virgin DME, EGAS/EDK adaptions cleared).
    So yes - clear the EGAS/EDK adaptions and it should happen next time you turn the car off. (it can also be triggered over DS2, but clearing adaptions seems like an easier solution)
    Also fwiw if you have an OBD2 cable you can use MSS54 DS2 Tool​ to both clear the adaptions and read the live values the DME is receiving from the pedal.
  • Darbshaw
    The pedal has two position sensors in it, one that measures a 0-5V range and the other measures a 0-2.5V range. The DME compares the readings from the two to ensure that they both agree on the position of the pedal.
    When you swapped the pedal did you do the adaption/learning process? as I think the DME has to learn the ranges the new pedal is reporting.
    Second thing would be to look at the actual values the DME is seeing from those two sensors and see whether it's that they're not quite aligning, or no signal at all from one of them (could point to wiring issue), etc.
  • Keith_MN
    Originally posted by DJAM3 View Post
    I'm at the point where I'm thinking about putting in a smaller pin and calling it good 😆
    If it makes you feel better, I did struggle with it for quite a long time. I actually forgot, I did give the end of the pin some additional beveling in an effort to get it fully seated. Not sure if that helped, the lightbulb moment for me was that it popped in when I torqued the pin at an angle more than I expected. A little grease always helps too.
  • DJAM3
  • Keith_MN
    I've been struggling with an Autosolutions SSK installation. Finally got the shift arm carrier inside the transmission ears and it looks to me like it's 99% aligned but the pin won't go in. Any tips to get the last 1% adjustment?
    I did as well. I believe what got it done was massaging two pry bars. One between the tunnel and the pin to create pressure on the pin. Another wiggling underneath, above, etc to get the end of the pin to line up with the trans. I found that mine needed to be tweaked to set it. Few hundred miles on it now, feels great.
  • karter16
    What replacement options do we have for the gas pedal? I'm getting a consistent limp mode on the track car that has me stumped.
    112 70 YES Pedal-position sensor, comparison fault 06 B5 08 09
    So far I've only replaced the pedal with a 60k mile unit off Ebay but the code persists. Do we need a particular pedal for the M3? The 60k unit was off a random E46 PN: 35406753518. The original pedal on my car was PN 35406762480. Although the PN shown on real OEM is 35426786281.
    All of these are different and would make me believe that this pedal should be interchangeable between cars. Even the Bimmerworld listing shows all E46 models as compatible. Would our cars specify this issue being a TPS fault? Or does it just point to pedal sensor regardless?
    Any help here is appreciated!
  • Slideways
    If it is not the pedal, it could be one of the other TPSs. After that, I would check that the throttle actuator plastic rod end joint does not have play or a crack in it.
    All E46 pedals are the same (other than autos which have a removable kickdown switch) with certain part numbers being superseded. 518 should work. If there is 30 day returns, you can try another pedal.
    Edit: First try what karter16 posted below.
  • Darbshaw
  • Marc E46M3
    Carly is good but it isnt free, yearly subscription.
    Thanks, dude. Much appreciated.
  • DJAM3
  • 0-60motorsports
    Originally posted by Marc E46M3 View Post
    Hey fellas - I have an SMG, and the car turned off on me unexpectedly yesterday. Good thing I was near my house, and I was able to quickly restart the car. I did some research and suspect it may be related to the "salmon relay" so I ordered one. I also want to get a good scanner/coder to diagnose the issue and future issues. I'm reading online that there are Bluetooth coders that will work with smartphones now. Any good scanner/coder that you of to recommend?
  • Marc E46M3
  • ljmartyre
    3D print or have someone 3D print a tool for you - https://nam3forum.com/forums/forum/c...-install-tools
    Corteco (OE for BMW) seal is about $14 and you should only need one, maybe two with the tool. The crappy part is if it leaks for whatever reason, those four TTY bolts are not cheap. A good DIYer should be able to handle this without issue.
    Somehow I don't know anyone with a 3D printer, but I cant imagine it being hard to find locally. Thank you!
    I bought 1 OE and 2 Corteco seals just in case. The bolts are definitely annoyingly priced, no doubt.​
    It is a pain. See here for my most recent experience: https://nam3forum.com/forums/forum/m...661#post309661
    Man, looks to be. Some solid info in there. I'm going to PM you with a question or two if you don't mind.
