Black Friday Deals
    [USER="503"]antknee[/USERAlthough if you did get them from FCP I wonder if their lifetime warranty would cover rotors and pads?
    They do! But of course you only come out ahead if you hold on to your car longer than the lifetime of the brake kit, which, let's face it, a lot of people won't (even if they're planning to).
      antknee nice score. You saved money vs buying from another vendor. Although if you did get them from FCP I wonder if their lifetime warranty would cover rotors and pads?
      Yeah i thought about it but since I’ve owned this car I’ve never changed the brakes. That’s 12yrs and 70k miles so i figured I’ll just take the savings now lol.
        I was going to say with something like ZCP rotors and pads FCP Euro is the way to go since they’re Lifetime. That 10% Off right now helps too.
          Ahah were on the same boat. 15 year ownership at 72k miles. I don’t see myself getting rid of her anytime soon so the lifetime warranty is a good thing.
          I was about to pull the trigger on an entire header install kit, exhaust nuts/bolts/gaskets from thebmwminipartstore and someone in this thread reminded me about the lifetime warranty. In the event I decide to go with Supersprint headers I can get a replacement kit for just nothing.
            Forgot to mention an out of the ordinary one. The UPS store had 30% off print services so I had the complete 300 page rod bearing DIY printed and wire bound so it's like an instruction manual. Came to about $25 in black and white high res. I'll be doing it over the course of weeks so thought it would be nice to be able to physically check off steps, look back, etc
              Damn! I really wish I would have known this, I plan on doing that same thing for the Beisan instructions as I hate having to use a phone/laptop with oily and dirty hands.
                Damn, I’ve been wanting to print and bind the 100 page torque value PDF for a while now :/
                  Besian and torque docs both would be good ones as well.
                  Picked the rod bearing doc up today and it puts the scope of work in perspective. 300 pages and 134 steps. This is printed double sided. Color would have been nice but it's 3X the price and the pics are high quality so B&W is fine.
                    All of my Black Friday stuff is coming in little by little. Post up some pics guys !!
                    Here’s my avin unit. I’m looking forward to installing this. It looks almost identical to the oem nav headunit.
                      Give us a mini review once your done installing it.
                        I will for sure
                          Originally posted by Triqzy View Post
                          Change injectors to higher flow or new oem? Also what issues did you experience with the buildjournal can tune?
                          I know of three blown engines on here with their one size fits all tune. One was mine and had other circumstances involved. One of those engines had predetonation from E30 and it gouged his cylinder walls. It doesn't do much of a remap but rather pulls back the knock sensor. Instead of the engine retarding the timing where it should, they cause it to advance more into a danger zone. The zone is where fuel explodes before it should.
                          I also meant larger injectors. Stock ones are great until you need ALOT more fuel.
                            Arith2 im sorry to hear about your motor bro. That’s horrible considering their tunes are complete shit to begin with and don’t even make good numbers. Now their tune is blowing up cars? Unbelievable.
                              It isn't all their fault my engine let go. I know it didn't help. When it comes to temps at the time of failure, my coolant and oil were probably around 170° F or so. I know it wasn't an overheating issue. Fuel trims were below 5% also. Detonation is what killed my engine. On the power stroke, something exploded and blew my piston into a hundred pieces. I've thought about it for many hours and that's what I've determined. I could've gotten another 2000 miles out of that engine before blowing it up....
                              If that wouldn't have killed it, a rod or main bearing would have. A bearing did actually weld to the crank. There a nice Cali engine in it with plenty of service records. I will say it doesn't have the horsepower the other one had but it does fine. Probably higher compression from all carbon build up in the old one.
                                My Black Friday purchase came in yesterday 😁:
                                2002 M3 Carbon Schwarz/Black 6MT
