  • 0-60motorsports
    Just bought this car from kaiv
    Heck yes. My search for a solid driver's coupe is over, finally.
    https://nam3forum.com/forums/forum/c...cktop-stripper
    Congrats! That looks amazing.
  • oceansize
    Up for sale is my 2005 Mystic Blue slicktop M3. This was originally meant to be a forever car but it’s time for someone to enjoy this clean and sorted M3. A little background in the interest of full disclosure: You may have seen this car on my IG with an S65 in it. The original plan was to build a CA-legal swapped street car
  • oceansize
    Finally unmasked my botched repaint over the repair areas on my strut towers, they were cracked.
    I knew I should have just sprayed the entire tops, regardless of match just spraying 3 separate spots will always look off.
    On the underside I used self etch primer, and POR-15 over it, I can already tell that won't last, I should have used 2k epoxy like I did up top, superior rust protection.
    Oh well, I can always have it done professionally later and now I can get the car put back together.
    You're good man, enjoy the car for a bit. It's not a show car Besides once you get everything back together it won't be as noticeable if at all from what I can see.
  • Cubieman
ID:	345078 Click image for larger version
ID:	345079 Click image for larger version
ID:	345080 Click image for larger version
  • Stackedm5
ID:	344978 Took it out for a drive and car wash after. Not much i can do, waitinf for parts and $$ to drop
  • CarbonM3
    I installed my turn csl intake this weekend, sent dme to Kassel for hp map conversion, installed map sensor conversion kit. I have some ct sound 6x9 coming in on Monday. Ill install those in the new “sub” whatever the trunk thing is called on Tuesday.
  • 6speedS54
    Replaced rear brakes, picked up NRF radiator for later
  • tnord
    things are happening.
    we got a good rain on sat that washed all the salt off the roads.
    gave the car a good wash/vac on Sun, and put new Motul XPower oil in with Mahle filter yesterday. Ordered an AC o-ring kit to hopefully get that working, and a new blower motor/resistor to put an end to the fan squeeking. Then ordered new MPS4S to replace the supersports I put on the car in 2010. Hopefully I can get the ohlins R&T installed in the next ~week. So many big things getting checked off the list this year the car is finally going to be put back into real service after a decade of sitting on the sidelines.
  • maupineda
    I’ve been wanting to do this - I have all of the male and female connectors, just haven’t found a minute to get wiring. Do you have a cheat sheet on which wires you bought?
    I have traced the pins, the tricky ones are the white ones, but I am almost certain they don’t have any polarity, anyhow, this is how they are from the factory, the numbers below are the PIN numbers on the connector side
    1 - white wire. Heater element
    2 - white wire. Heater element. This lines up with the sensor part number on the sensor body
    3 - gray wire. This is the signal wire to the DME
    4 - black wire. This is the sensor element ground
    the white wires really just close the loop to the heater element which is nothing but a resistor, same in principle as a light bulb filament.
    I am basically making one sensor harness out of two, to join them I am using crimped terminals isolated with heat shrink tubes. To make it easier to myself I colored white wire for pin 1 with a black sharpie so I know which is which without having to removal the harness protective sleeve
    Click image for larger version  Name:	IMG_2934.jpg Views:	0 Size:	161.9 KB ID:	343680
    Click image for larger version  Name:	IMG_2937.jpg Views:	0 Size:	189.8 KB ID:	343681
    Click image for larger version  Name:	IMG_2938.jpg Views:	0 Size:	172.4 KB ID:	343678
    Click image for larger version  Name:	IMG_2939.jpg Views:	0 Size:	146.5 KB ID:	343679
  • davidinnyc
    No, I have not made one. But will do one as I splice them and join them.
    i have re routed the engine side loom to the plastic holder and taken the exhaust off
    Yeah, I have a few sets of sensors I can pull the wiring from but wanted to find the wiring separate from cutting through a few O2 sensors… fun!
  • maupineda
  • davidinnyc
    Making a harness extension for the rear 02 sensors so I can route it under the beauty cover as per the factory
  • maupineda
  • M3LSB.Gab
    New chrome grilles
  • discoelk
    Those tips aren't my style but that's cool AF.
