Best Battery Replacement Options
    Just to provide a data point: Car sat in the garage for 4-6 weeks (battery connected, no charger) and just started right up without hesitation.
    Antigravity ATX-30
      I don’t know how lithium batteries react when shorted to ground but traditional ones its dangerous.
      Worse than traditional ones lol
        https://youtu.be/FfmrqWdm-mw?t=156
        Wow. Glad I installed those rubber terminal covers. I don’t run with the plastic battery compartment shelf anymore since I need access to the restart button on the battery. I’ve often worried about a stray wrench or something shorting the terminal.
          Antigravity ATX-30
          Do you recall how many lbs you saved when you swapped to the antigravity battery?
            +1 for antigravity, they are legit
              Battery for battery about 45lbs, but should be closer to 50 once I get the heavy steel bracketing swapped out for some aluminum straps.
                That’s awesome. Thanks for the response.
                  Antigravity ATX-30
                  That’s sweet really looking forward to ATX-30
                    Weighed it with the adapter posts installed (and a full charge with all them heavy electrons)
                      ZHPizza how many pounds is that?
                        5lb 15oz
                          Wild, so light! Wish there were a bit more affordable...
                            5lb 15oz
                            That’s why I had to ask and make sure. Wow! A 5 lb battery. That’s awesome how far technology has come. I’m definitely going to have to look into this.
                            Would you be able to leave a ctek tender on this battery during the winters ?
                              Yep just make sure it's the correct charger for LiFePO batteries. This is the one that I got as it was recommend by Antigravity.
                                https://www.amazon.com/dp/B00EUF6UM8
                                concur this charger works well.
