ZCP/CSL Wheel paint code
    Does anyone have the paint code for Style 67 18'? I'm guessing BAS Glasurit supplied the paint...
      Wonder if anyone has been able to source this stateside. If not, does anyone know of an alternative that’s proven to be very close?
        88Z
        2002 BMW E46 M3 Coupe
        2005 Porsche 911 (997.1) Carrera S
          Originally posted by R60BBA View Post
          88Z
          Awesome
            The barrels are ‘grey powder’, which I presume is just a grey primer.
            Looks like the big mystery of ~20 years has finally been resolved…
              Click image for larger version  Name:	image_19498.png Views:	2740 Size:	55.1 KB ID:	78705 Click image for larger version  Name:	B0F9BD05-781A-4014-BC93-CE4469A6E69A.jpeg Views:	3763 Size:	44.1 KB ID:	78706
              it is a Glasurit Special paint code A55 Dekra Silver from Line 90
              I believe A55 is used on the 359 M wheels (hence the dates of 2005 - ). The CSL wheel was made in 2003 and is finished in 88Z.
              Original BBS finish attached for reference:
              Click image for larger version  Name:	FB0D7ED4-1A97-4D9B-8EF9-EEBF89981D6C.jpg Views:	439 Size:	118.8 KB ID:	172985 Click image for larger version  Name:	42679436-EC09-41C6-AA0B-062BB8A774CD.jpg Views:	424 Size:	35.2 KB ID:	172986 Click image for larger version  Name:	2DA1342C-D6DB-4101-99B0-9D3D2C5B9D7D.jpg Views:	448 Size:	37.8 KB ID:	172984
                Anyone know of a place in NJ area that has come close to the original finish?
                  The 359M wheel finish doesn't hold a candle to the bbs 163m csl wheel, in case anyone is wondering.
                    Reached out to BBS and got a completely different paint code from y’all. Hmmm. I sent them A55 and they said that was BMW’s alias for DS-AP which is BBS’s internal code for paint 025/010902. This appears to be the same code the BBS CH has (Brilliant Silver). Idk - this doesn’t seem like accurate information.
                      Click image for larger version  Name:	F0060A1E-6A8A-44C4-8BC3-28082705D313.jpg Views:	256 Size:	95.8 KB ID:	211744
                      Most likely because you emailed BBS USA as opposed to BBS Germany.
                      As per post 18 of this thread, the colour code is 88Z.
                        What is the best way to refinish CSL wheels? I’ve seen some with blurry part numbers around the BMW rounded. Assuming this is because they had new powder coat applied but the person didn’t sandblast them down to bare metal?
                          Sandblasting wheels is a bad idea, it doesn’t leave a nice surface, instead they should be chemically stripped of all previous paint.
                          Furthermore I ordered all the above paint codes from my paint supplier, and compared them against a set of brand new In box CSL wheels that I have, none of them are a good match.
                          I think the best is just to ask whoever you pick to refinish your wheels to provide some photos of the finish that they’ll be using, if you are satisfied with what you see, just go for it.
                            I think best thing is to take them to a paint place that can mix or identify the paint by scanning the wheels. We have shops here that sell paint and they have a device that they put on the car to match the paint perfectly. It scans it and gives them the right stats to mix the paint.
                              +1 ; most powder coating shops have a chemical stripping process where they dip the wheel and remove the finish. This is the way
                                What does 88Z mean? Are you saying that we should be able to go to a paint supplier and just tell them 88Z with no other context of codes and they will be able to pull it up?
                                88Z seems like such a short small number like its missing something
