Rod Bearing Showcase Thread
    Done at 121k miles, no record of them being done before.
    Pics are in order from bank 1 to 6.
      I need to replace rod bearings..
        2006, first time replacement at 91k miles. Blackstone was showing relatively high levels of copper all the time, but I didn't like the increase of all three lead, copper and iron in the last report. OCI ~7500 miles, didn't do Blackstone every time. Planned to do it around 100k miles, but used the downtime working from home and not needing to drive to get it done.
          changed them in fabruary. 120k miles. oil analysis was good. so i won't do an oil analysis again. btw thats km on the analysis. just changing the oil a lot and will change them when I feel I need to.
          2003 AW/BLK 6MT - Instagram
            2006 M3 62K sure looks like it was time, no thanks to Blackstone it has been done.
            blackstone62k.pdf
            Click image for larger version  Name:	m3top.jpeg Views:	0 Size:	64.2 KB ID:	71072
              198K, 2004, no copper showing but the "spring" was gone in several suggesting detonation pounded them at some point. Not bad at all and probably could have gone another 60k.
                About to have mine done. VAC coated rod bearings with extra clearance and ARP bolts. I also got the oil pump upgrade kit.
                Will post pics of the old bearings.
                  My rod bearings at 80K . . .
                  Replaced with OE, WPC & OEM bolts
ID:	72343Click image for larger version
Name:	Screen Shot 2020-12-08 at 9.44.18 PM.png
                  Oil Change 1200 miles after rod bearing job . . . Blackstone analysis
                    Records show the recall was done at around 11k, these were replaced at 164k. Replaced with ACL bearings.
                    Click image for larger version  Name:	IMG_4631.JPG Views:	0 Size:	67.1 KB ID:	92744
                    996TT
                    Turbo E36 M3
                    FZJ80
                      175k (ish...have to pull the records).
                        Bearings changed at 97,658 based on the trend in lead in multiple reports.
                        Click image for larger version  Name:	reportbeforebearings.jpg Views:	0 Size:	130.2 KB ID:	92827
                        Click image for larger version  Name:	3161.JPG Views:	0 Size:	163.0 KB ID:	92828
                          2003.1 120k miles, cyl 1 at top
                          Unknown maintenance history (recently acquired)
                            Had the rod bearing recall done around 25k and then these done at 145k. Mostly highway miles, but still, they were ready to change out. Glad i did it now and didnt wait any longer. Blackstone wasnt showing much copper
ID:	95985 The Click image for larger version
ID:	95984 Click image for larger version
ID:	95983 160k miles. Don’t know when the previous owner changed them. But glad I got it done.
ID:	108601 Click image for larger version
                                216,500 km (133,000 miles). Top of number #3 was worst - copper just starting to show through. Funny, my oil analysis consistently looked fine. Blackstone's report stated "Your original rod bearings still look good with lead (the primary bearing element) at a perfectly average 6 ppm". I'm glad I replaced them anyway.
