DIY Z4 cruise control stalk with ZCP steering wheel
    I don't like the buttons on the steering wheel so I opted to swap to the ZCP steering trim. I can deal with having to move my hand to adjust the volume or hitting a button on the navi screen to answer the phone. The one thing that is missing is the cruise control switches, and while I don't use cruise control much it's great for a longer trip. Thankfully you swap in a z4 cruise control stalk, which is really easy to do.
    I'd imagine this would work with a true ZCP car, although I'm not sure if anything needs to be coded to enable cruise functionality and/or the wiring is there or not. Perhaps somebody else knows?
    Parts list:
    03-08 e85 Z4 cruise control stalk: 61316940989 $130
    Adapter lead: 61116911072 $13
    The adapter lead is actually for the clutch switch, but it has the correct color wires and the plug is the correct type. You might be able to make something work, but getting the adapter lead makes it easy. I ended up buying a whole z4 steering clock spring with all switches on eBay for $75.
    Onward to the DIY...
    Unplug the battery, just in case. You wouldn't want the airbag to go off while you're working. Pull off the bottom trim under the steering wheel, you just press in the locking pin on the two plastic holder plugs and then pull the trim down.
    The Z4 steering wheel clock spring combo switches (the thing that spins and passes through all the wires and the turn signal & wipers attach) is the same between the e46 and e85. So this means that the z4 cruise switch just slides into place. You can see where the cruise stalk slides in on the bracket on the lower right of this picture.
    Here is another picture of the cruise stalk on a spare clock spring I have
    Now you have to clearance the lower steering trim so the cruise stalk fits. The Z4 trim is completely different and won't work in our cars so you need to modify the stock trim. I used a Dremel and a sharp hobby knife to cut the side and remove part of the metal base.
    Left is my modified one, right is unmodified
    Here is what it looks like with the modified lower trim and some broken top trim I had in a box. I used my spare steering clock spring to test fit. Must say it's a lot easier to clearance the lower trim having these pieces available off the car to test fit.
    Once you have it fitting nice there is a bit of wiring to do. I moved the wires around in the adapter lead plug so the colors matched the wiring on the harness plug I was tapping into. Just made it easier to not make a mistake when doing the wiring. The cruise stalk only uses 3 of the 4 wires, so you can remove pin 3.
    I ended up unpinning the blue/blk signal wire and moving the wire into the cruise stalk plug, but the other wires you'll have to tap into.
    E46 clock spring harness side -> cruise stalk plug
    pin 7 brn/blk. -> pin 1 ground (tap into)
    pin 8 blu/blk -> pin 2 signal (unpin and move)
    pin 10 violet/yel -> pin 4 +12v (tap into)
    All Finished
    Plug everything back in
    Put on your lower trim
    Plug back in your battery and turn your car on, test the switch. Just push up or down to enable cruise, you should see a light come on the dash
    Enjoy the cruuiiiseeeee
    This is the SHIT. Only thing I miss from my button delete trim is cruise control. Going to be doing this for sure, thanks for the awesome DIY!!!
      This is very cool. Can the zcp button be set up to turn the traction on/off on a non-zcp car?
        I think so, although I haven't tried yet. Right now that button does nothing. I assume since the button on the center console is just a button I can wire it to the steering wheel IO button to do the same thing. Once I figure it out I'll be sure to post it here.
          If you don't like steering wheel buttons, this will completely remove it:
            Thats great work! I love cruise control, the lack of it actually kept me from buying a ZCP. Sounds small but its a must have for me. Way to solve a problem
              Only if you retrofit a CSL/ZCP MK60 DSC module.
                https://www.ebay.com/itm/BMW-E46-Ste...1/114427781235
                You could combine that with a e39 high intensity washer stalk to still be able to activate MTM and have no buttons at all
                (I have that for MTM activation, but I like the steering wheel controls, so not doing button delete)_
                  ^I’ve got that as well on my ZCP car ... came that way from the PO since he also added the multifunction controls back in. Very tempted to go back to a fuzzy wheel and single MTM button. Cruise control functionality mod in this thread is excellent, but pretty sure I personally have used CC like twice ever.
                    I'd think you could wire the IO button on the steering wheel to do the same thing as the button on the center console though, yeah? Both are just buttons.
                      Yeah, but the pin doesn’t do anything unless it’s an 817.3.
                      I had the button wired up for a long while with no 817.3– didn’t do anything. No change in wiring, 817.3 swapped in, it works.
                        This is awesome! I really missed my e36 CC stalk. Nowadays I don't even use CC, but this is still really cool. And obviously the perfect way to do it, they even have the same (as my '94 e36 was) in my 2012 E82.
                          I have a ZCP and miss having cruise control on long drives. Would love to do this if it’s confirmed that ZCPs can have this working properly.
                          997.1 GT3 Carrara White/Black
                          C43 AMG Diamond Silver/Red​
                            You can reenable cruise control on a CSL DME, so maybe you can do the same on a ZCP. Might have to route some wires though.
                              Great write up and excellent find. FYI the part number for the "no-button" upper steering wheel trim is: 61 31 8 383 366
                              Cheers
