What projects would you trackle in quarantine?
    Originally posted by bryce2113 View Post
    Here's my plan so far, but a lot is dependent on whether/when track season is going to happen:
    Finished:
    • Replacing front diff mount bolt and bushing with Rogue Engineering kit to fix stripped out hole from previous owner. This is thankfully the last step in finishing the subframe reinforcement from last summer.
    • Intake and cabin filter replacements
    In Progress:
    • Refinishing the ZCP steering wheel to deal with the worn out alcantara and faded paint. Repainting trim and rewrapping the wheel with a kit I located.
    To do:
    • Oil change
    • Diff and trans fluid change
    • Wash, clay, paint touch up (damn rock chips in the front), full paint correction, and ceramic coat. Need some better weather in Wisconsin ASAP.
    • Replace ZCP rotors. Replace pads with Hawk DTC-60s (or maybe 70s) for the track.
    • Install front brake ducts and run hose to rotors.
    • Replace front tires.
    Finished bringing back my ZCP wheel from the grave by rewrapping the cover and repainting the trim piece. Looks 200% better now. Thought I'd share the results. PM me if you want details.
ID:	3116Click image for larger version
ID:	3117Click image for larger version
ID:	3118Click image for larger version
    2005 ZCP SMG ///M3
      I'm still working from home so my time has been limited, I did however manage to fit my new 280/272 cat cams and DLC coated followers.
      I also fix my washer jet pump which was siezed, and fixed the headlight washer hose which was causing my bottle to drain.
        I’ve been working on my wagon while stuck at home. So far I’ve done new rtabs, new diff input seal, front diff bushing and cover with new bushings. Been a lot of work but should drive much better without the rear clunk.
          Nothing crazy where. Replaced some
          badly needed rear window weather stripping and added angel eyes up front.
          2006 M3 SMG Coupe Jet Black - AFE Intake - Borla Exhaust - ST XTA Coilovers
            Got my sunroof delete put in and made a rear seat delete panel to the the back up and cut out some noise.
            2003.5 Titanium Silver / Black 6M/T (Gone)
              Click image for larger version  Name:	 Views:	0 Size:	77.8 KB ID:	4169
              Simple project. Just putting an engine in. Did rod bearings, valve adjustment, replaced cam bolts, put my old rebuolt vanos on, screw in studs for headers, did rear main seal which took a total of 5 minutes with the engine out, and fought the entire time it was going in. The way the hoist had it, the engine was slightly lopsided so I had to pick up the top and remove the cowl to get it in. The trick was getting it past the A/C port and not have it rest on the steering column. It was a nightmare but once it was in I just took the next day off because it has taken so much to get to this point. Hard work pays off.
                Originally posted by Inizes View Post
                Done so far:
                • E21 trans mounts
                • Trans fluid flush
                In progress:
                • Fixing the sandblasted front of my car (lots of rock chips from 100k miles in a rocky soil environment, pre-installed to my ownership)
                • Full paint correction
                • Ceramic coating
                To do:
                • Replace flex joint/giubo
                Here area few photos of the rock chip repairs - not perfect but way better.
                Let this be a PSA for all those who are repainting their front bumper for whatever reason. Get a clear bra done at the same time. Shop around. I got mine done for $250! Easily some of the best money spent on this car because my bumper is immaculate!
                Also, seeing how nice and clear your lenses are got me jealous. When installing my angel eyes I didn't clip my left lens in all the way and a few months later its all foggy and worn away. Im debating wether or not I should just get 2 new ones or simply sand them....
                  Clear bra was one of the worst things I’ve done to my car.
                  never again.
                    never again.
                    how so? Have a couple cars with complete coverage, and one with partial, so far so good, but it's only been 3 years on the oldest one. (Xpel on all of them)
                      Done:
                      Cobra Nogaro wired to OE electric sliders
                      Grey -> Black carpet swap
                      MCS 2WNR's
                      To do:
                      Full beisan vanos
                      valve adjustment
                      GC end links
                      Guibo + CSB
                      Turner spherical RTAB's
                      Rogue Trans Mounts
                      Paint OE bumper (Currently on CSL rep)
                      Corner Balance
                        Looked like crap after ~8 years. Taking it off took 4 days of effort and misery, and I didn’t even finish removing it (bumper is still covered). I just couldn’t take any more of the removal process.
                          Look at an older Porsche by the rear vents. All the clear covers they put on cracked and got covered in dirt. It took my dad and I hours to removed his and we scratched the paint up quite a bit.
                            Taking my car to Racewerkz to on Wednesday to get some racp work done and have my x-brace installed
                              never again.
                              +1, especially on an Alpine White car. I'd rather just drive it around and pay for a respray every 5 years if it's really that bad.
                                never again.
                                Really? Why is that?
