Transmission Compression Springs
    Originally posted by Mayan-Viking View Post
    It would be very interesting if this all came down to a $1.17 ball pin. Regardless, time to pull the tranny...
    Right?!
    Motor need to come out to pull the tranny I'm told. If that happens, might as well respray the car. Logic dictates.
      Right. I mean, anything else would just be irresponsible and imprudent at this point right?
        • Checked all the centering springs/detent mechanisms I can get to without removing the tranny.
        • Rebled the slave from the bottom up
        • Checked clutch stop and engagement
        • Checked clutch resistance by hand
        • With car on jack stands in the rear:
          • Started the car with it in neutral
          • Depressed clutch and engaged 1st (or any other gear) and the wheels don't move
          • Release clutch and wheels spin
          • Depress clutch and wheels stop (after some rotations)
        Casa, I saw your last post today. I think the pressure plate probably about to explode: causing clutch dragging at high rpm (centripetal force) but released clutch completely at idle rpm.
        So you may want to repeat the test as above, and at this step "Depress clutch and wheels stop (after some rotations)", the wheels stop at idle, but if rpm is increased higher then the bad PP will act up and starts grabbing the clutch, causing the wheels to rotate. The same thing happened when you tried to pull the gears out to neutral but it was hard to pull it out at high rpm as you said.
          When the RPMs came down to about 2.5k, I was able to get it out of 2nd by slowly rolling on the throttle (just enough to relieve drivetrain stress from engine braking). The clutch pedal then worked slightly, (not well) but enough to get it into 3rd and crudely into 4th. I could feel a fairly strong wobble coming through the pedal in my foot as I released the pedal to engage the clutch.
          The only thing could cause the pedal to feel wobble is something was pushing, pulsing, on the PP rearward, or the PP growing longer cyclically, at high rpm, or the clutch disk was falling apart and pushed on the PP. I would hope what pushing on the pp rearward is not a loose flywheel, but I strongly think it is the PP on its last breath, before exploding, or the clutch disk falling apart.
          DukeofChen's problem was the clutch dragging caused by the shorten plastic pivot pin. The synchros were good enough to overcome the dragged clutch and engaged them at low rpm, but at high rpm, the speed differential was too big for the synchro to overcome the dragging clutch.
            Won’t know until you drop the transmission…but it sounds like a clutch or pressure plate issue.
            Yep... valid point. Time to get busy.
            Thanks Sapote. Based on this... and knowing the transmission has to be pulled, I think next step is to just tear into it and get it done. I don't want the clutch or PP exploding. No idea how solid the bellhousing is in these transmissions but I'd rather not find out.
            Makes perfect sense. I was hoping for a similar outcome but don't think that's the case.
            I'll search, but what's the consensus on flywheels and clutches? I'm a fan of lighter weight clutches in general, but have read some things over the years that you shouldn't go too light with these cars. I know the stock setup is great for smooth engagement, but that's not a primary concern of mine. Reliability and performance are.
              Hey Casa, reviving this thread from the dead!
              I came across this thread from the OP and have similar issues when shifting, almost like hitting a wall trying to shift into 3rd at first, then as time/heat goes on it becomes difficult shifting into 4th and 5th. the shifter goes into the gate partially, hits a "wall" and when I release the clutch its either in neutral or I get a grind and pops back to neutral. then have to slow down significantly to get it into gear. This 6mt car is new to me at 155k miles, I flushed trans fluid with a large amount of particulate (non-magnetic copper looking material pushing me toward synchros, had a CAE shifter on before my purchase and changed to short shifter). Im assuming synchros so i found a low mileage SMG gearbox I plan to swap in with my 6mt bellhousing, but after reading this thread I want to get a solid parts list in stock so Im ordering all shift springs/detents etc above, TOB, pin, clutch assy.
              Question is, have you settled the issue yet? What was your resolution? Thank you!
                Hey Apexwagon. My issue turned out to be a failing clutch. Specifically, the friction material was starting to "delaminate" from the backing plate of the friction disc. Even after trying all of the stuff in this thread, the car wouldn't shift well and at times was nearly impossible to get into gear (especially higher RPM).
                As part of a total restoration and color change of the car, I replaced the clutch (everything - throwout bearing, friction disc, pressure plate) with a OEM DMF flywheel (Luk) and self adjusting clutch (Sachs) from RockAuto and the transmission is shifting fantastically now. No issues.
                Not sure why the friction material was starting to delaminate from the friction disk. There was still plenty of material there, it just started to come apart. Take a look at several pics down into THIS POST and you'll see what I mean. There pics of the exposed friction disc.
                  "Clutch removal. You can see a chunk of friction material missing in the lower right and the irregular wear pattern across the face of the entire thing.
                  Apparently this is a symptom of a bum dual mass flywheel. I’m still weighing the pros and cons of SMF vs. DMF. Also thinking about the N54 conversion Turner (aka ECS) sells."
                  I'm glad you got the gear change issue soted out. What were the Pros and Cons of the DMF vs SMF, just noise/chatter?
                  Also, What is the N54 conversion from ECS?
                    Thank you guys for your responses. I lost this thread to respond sooner. My issue ended up being bad synchros with difficult or impossible shifts into 2, 3 and 4. I purchased an SMG gearbox, and swapped my manual bellhousing on/replaced all detents etc while it was out. The clutch looked good, but had a lightweight flywheel. I replaced the clutch/flywheel/throwout bearing etc with a LUK Kit while all out with a DMF. I noticed a slight power decrease, but based on research these S54’s prefer a DMF for the balancing to not ping valves/powertrain items. And for a street/occasional track car I’d rather keep things on the mild end for comfort, drivability and longevity. I’ve done a couple track days in the last month and the car drives excellent now, buttery shifts.
                      Here are some pics, hopefully they upload..
                        And one of the car!
                          Instead of starting a new thread, I've got an issue that stared about 2 months ago now and its related to the gear gates.
                          Issue: gates for gears shift after some driving, when taking street corners 90deg ones shifting from 1/2 is butter smooth. After some driving the 1/2 shift I cant seem to find 2nd gate, because traffic I shift to 3rd and hear an audible clunk going back to the diff/driveshaft. Hwy driving 5/6 shift 6th gear gate is slightly left of the usual place (ie. towards the driver). After an incident with gear gate selection, the gates shift back for a bit then issue persists. It is inconsistent and I can't reproduce it at will.
                          This all started while driving on the hwy during traffic. While speeding up and executing a regular 3k rpm 3/4 shift 4th gear ground and it freaked me out. Went to neutral immediately, I didn't depress the clutch, simply went back to neutral. Tried to shift to 3rd but couldn't find the gate, the shifter would not travel into the gate there was a hard stop, 4th went, 5th didn't go. Took the car to my shop, and replaced my clutch and pressure plate with OEM. Buttoned everything up and issue still persists. I have an auto solutions ssk autocross 25% stock height. Used Redline MTL I have since flushed out the trans with AMS Oil 75-90 about 5 times and its still coming out black even after just a few hundred KMS.
                          If the car is stopped, parked, it has no issues doing into gear gates.
                          Reading through this thread I'd like to cover all bases as I have planned a head gasket refresh next week and it will be a good time to take the trans out and service anything that could solve the problem. Other than detent repair kit what should I be looking at?
                          Car has 165k Miles, I track it drive it hard but I'm underneath it every week sometimes multiple times checking things over.
                            Any ideas on the above?
                            TLDR:
                            1 - do I do a detent and #9 spring service
                            2 - get a low mile SMG trans and swamp my manual bell housing?
                              TLDR:
                              Your best option with the current gearbox is to pull it, remove the detents and inspect them. If you find a broken one, then that is your culprit. If you don't find anything obvious, move to option #2. I'd also go back to MTF-LT2, either BMW (Pentosin) if you can source it or Ravenol.
                                My thought with all detents and neutral gate springs on the bell housing of a 6MT: if the gearbox is out just replace them all! maybe $150 of peace of mind. and with 165k probably make it feel brand new again.. also sounds like you may have the infamous rear diff clunk that seems to be nearly impossible to diagnose.. does it clunk at stop when putting into 1st?
                                Did you check shifter bushings? I have heard stories of those reeking havoc on people, explaining similar shifting inconsistencies..
                                Also, if this is happening not while turning, and happens while driving straight, id have to suggest trans/motor mounts. Check to see if they're worn or flexing more than normal.
                                I also had a major problem when I installed the R-1/2nd gear neutral gate detent with the bevel slightly off, and it was nearly impossible to move the shifter left to REVERSE. Luckily, I rigged up a series of extension/swivel/socket with duct tape to not have to pull the gearbox down and replace the lower of the 2, but getting. that Circlip back in was a PITA with the gearbox in. cant upload videos for some reason.
