“I don't like the fact I biased the crank to achieve correct timing. In fact I followed your instructions the first go around and unfortunately it was the same result as last time except both cams were retarded instead of only EX cam.”
It doesn’t matter how you did; the good result is what matter.
I wonder if the thicker spring reduces chances of rattle due to harmonics?
With everything installed, there’s a tiny gap between the hub rear end to the cam sleeve, this allows the cam to advance/retard relative to the hub. During advancing the cam, the hub compresses the cup spring further until it and the funny thrust washer bottomed on the cam sleeve or when cam turned. During retarding, the hub does not compress the cup spring. This is why it takes more time to advance than retard.
