No comment. Don't want to deflate the thread any further.
e46 M3 suspension setup, or how to not downgrade your car with suspension mods
I try not to think about them.Originally posted by Allnightlong View PostWhat are your thoughts on air suspensions?
Youtube link for those on PC (or android) and don't want that fat bastard called iTunes on their PC.Originally posted by eacmen View PostGreat podcast episode with Mike Kojima. Suspension guru extraordinaire. Highly recommend a listen:
Pretty eye opening stuff, seems like a lot of work to really dial in this car and conversely mad easy to royally mess it up.Originally posted by oceansize View Post
Obioban was there some doc whereby it stated that after the 13.5F/13R heights we then need to correct for revised suspension geometry?
Follow up question, how does the car behave under compression where it goes beneath that ride height factor? From this video, after the arms go beyond 90deg we gain positive camber and a host of other unwanted behaviours.2006 Silber Grau Metalizat ZCP 6 MT
Absolutely. As with most mods, especially on a car that’s as good stock as the E46 M3. Wish this were more widely understood and appreciated.Originally posted by CrisSilberGrau View PostPretty eye opening stuff, seems like a lot of work to really dial in this car and conversely mad easy to royally mess it up.2008 E90 M3 6MT
2011 E90 328i 6MT
RWD, slicktop, no iDrive
Yup because most people don't have the chance to drive a stock e46 m3 on brand new suspension. Comparing 20 yr old worn out suspension is meaningless. Recently bought brand new oem dampers on my ZHP and did some bump stop modifications and swaybars and the car is incredible. I can blow through backroads and hit bumps at 80mph+ and the car just takes the bumps like it should and is still a lot of fun and predictable. These cars stock, M3 included, actually sit virtually on the bumpstop use it to control roll, grip, and oversteer/understeer characteristics so if you go lower on that setup without moving to a shorter bumpstop with similar characteristics (easily misunderstood by the average person) you are changing the handling dynamics negatively at an exponential rate the lower you go.Originally posted by IamFODI View PostAbsolutely. As with most mods, especially on a car that’s as good stock as the E46 M3. Wish this were more widely understood and appreciated.
If you want to go lower, everything needs to be calculated and setup accordingly in the proper ride height ranges if you care about performance. Just going low for looks does not work. If you setup can't take bumps at 80mph without the car getting upset, your suspension is not able to properly do its job to control the chassis.
Ian is 100% right with this stuff and I have hundreds of hours testing this stuff on both my cars as well as guidance from a suspension engineer that this stuff is indeed true.2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
- Likes 3
https://podcasts.apple.com/us/podcas...=1000577379915
That's a good listen. I liked that a lot of the concepts they talked about are already being discussed on this forum.Originally posted by oceansize View Post2003 Imola Red M3 w/ SMG
Interesting. I ended up watching some more of his content after this. Kind of a quirky guy. Some misleading information but also a lot of things I didn't know about.Originally posted by eacmen View PostGreat podcast episode with Mike Kojima. Suspension guru extraordinaire. Highly recommend a listen:
I didn't make a list, but off the top of my head some of the shock tuning and spring rate things could lead to confusion.Originally posted by eacmen View Post
Curious. What info did you find misleading?
-They both agreed that spring rates were a bad way to talk about spring selection due to varied motion ratios, but then proceeded to speak in terms of spring rates. Mike was not forthcoming with his perspective on ride frequency.
-The "4 clicks in, 1 click out" can cause a lot of confusion because every shock is completely different. 8 clicks on one brand might equal 1 click on another. Some adjusters do almost nothing and others have dramatic effects. More importantly, if you aren't in the ballpark to begin with you're wasting your time. I've wasted a LOT of time turning adjusters when in reality I was not even in the ballpark to begin with.
Just generalizations that people might think they can apply to their vehicle, A few more disclaimers would have helped
