GB: Aluminum Undertrays for E46 M3 by Euro Parts Palace and POW3R Motorsports
    I've documented my unboxing and launched an intro special here.
      Originally posted by LemansM View Post
      Bumping this one up. Any installed picts yet? Thoughts? Thx!
      Here's some pictures from our customers! Everyone liked it so far and most commented on how easy the install was especially with the instructions and necessary hardware already provided.
        wanted to share some picture and some notes regarding my install. this is a pretty complete product. everything lines up as it should. a lot of nuts and bolts included as well as some riveted pieces which certainly make the install easier.
        definitely easier to take the wheels off when doing this. i did this on the floor, i imagine on a lift this is a cakewalk. took me about 1-1.5 hours. doing this again, i could probably do this in 20 minutes (yes, that simple)
        i personally feel that in the instructions, when it asks you mock-fit the rear to make the holes for the front, i would also suggest you mockfit the 2 screws on the side. this attaches the undertray to the front lower fender liner and the bumper, although seeing the pictures above, the bumper above doesn't extend whereas mine does. i have an '06. kind of odd that the bumper mounting is different.
        overall, i'm happy with everything and with the track season coming soon, we will see how this affects the cooling (pow3r says it improves it)
        pictures below:
        picture from where the bracket connects to the sway bar bracket
        undertray bracket and sway bar bracket are 2 pieces and get attached from here.
        '06 Carbon Black
        Sabelt, Brey Krause, MCS 2-way, SuperSprint, Karbonius, Epic, Volk
          pictures below:
          Thank you, Marco for your detailed review! Much appreciated. We do have these available in stock at our warehouse in Michigan now! If anyone would still like to purchase these E46 M3 Undertrays, please send me a message or purchase them from Epoustouflant as he's doing a group buy on them. If anyone has any questions, feel free to let me know! Thanks guys.
          2mm aluminum skid plate for the E46 M3 shields the front end from debris while a rubber-trimmed venturi aperture draws heat out to cut oil temps. Satin black.
            how effective is that hole for the "venturi" effect? Also not that it matters to me but might to some, doesnt that add lift? Similar to 997 911s with adding a third radiator. the air exits to the bottom versus the top like the GT3.
              Ordered one of these, looks like a nice piece and my 20 year old plastic shield is in shambles
                Originally posted by majdi View Post
                These undertrays are designed to withstand increased levels of protection, and reduce oil temps while on track. The rubber trim on the undertrays cooling aperture seals onto the OEM plastic cooling shroud, drawing heat away from the oil cooler through the effects of venturi.
                What is supporting data for reducing oil temps? What conditions, what car setup, how many degrees?
                What is the increased level of protection for? What are we protecting from?
                Was there any aerodynamic testing done? This part is flat, there is a reason why stock plastic tray is not...
                Youtube DIYs and more
                  Bump also, interested in fit and if these are still worth getting.
                    Bump for this data. I tried reaching out to the manufacturer but I never got a response...
                      How long since you reached out? Also interested in this info.
                        At this point, probably about 6 weeks ago. I sent them a message on instagram and they left me on read…
                          I contacted them for the same product, nothing crickets
                            That opening isn't going to do anything. In fact it might cause air to go up into the engine bay. The problem is the undertray is higher than the leading edge of the bumper which causes air pressure to increase. That is why the OE part curves downward which keeps the flow attached and creates alower pressure region.
                            To effectively extract air from the oil cooler, the oil cooler needs to be sealed off to the undertray and then the opening needs a gurney flap to increase extraction from the oil cooler.
