GB: Aluminum Undertrays for E46 M3 by Euro Parts Palace and POW3R Motorsports
Originally posted by LemansM View PostBumping this one up. Any installed picts yet? Thoughts? Thx!
wanted to share some picture and some notes regarding my install. this is a pretty complete product. everything lines up as it should. a lot of nuts and bolts included as well as some riveted pieces which certainly make the install easier.
definitely easier to take the wheels off when doing this. i did this on the floor, i imagine on a lift this is a cakewalk. took me about 1-1.5 hours. doing this again, i could probably do this in 20 minutes (yes, that simple)
i personally feel that in the instructions, when it asks you mock-fit the rear to make the holes for the front, i would also suggest you mockfit the 2 screws on the side. this attaches the undertray to the front lower fender liner and the bumper, although seeing the pictures above, the bumper above doesn't extend whereas mine does. i have an '06. kind of odd that the bumper mounting is different.
overall, i'm happy with everything and with the track season coming soon, we will see how this affects the cooling (pow3r says it improves it)
pictures below:
picture from where the bracket connects to the sway bar bracket
undertray bracket and sway bar bracket are 2 pieces and get attached from here.
'06 Carbon Black
Sabelt, Brey Krause, MCS 2-way, SuperSprint, Karbonius, Epic, Volk
Originally posted by MarcoPolo View Postwanted to share some picture and some notes regarding my install. this is a pretty complete product. everything lines up as it should. a lot of nuts and bolts included as well as some riveted pieces which certainly make the install easier.
pictures below:
Originally posted by majdi View Post
These undertrays are designed to withstand increased levels of protection, and reduce oil temps while on track. The rubber trim on the undertrays cooling aperture seals onto the OEM plastic cooling shroud, drawing heat away from the oil cooler through the effects of venturi.
What is the increased level of protection for? What are we protecting from?
Was there any aerodynamic testing done? This part is flat, there is a reason why stock plastic tray is not...
Youtube DIYs and more
