    Run any FEA on that sub strap bracket bolted to the seat mounts? IIRC they're supposed to hold under 3000 lbs of load, which isn't insignificant.
    Not yet, since the geometry of the brackets is likely to change a bit post test fit. But I will before getting them made.
    Looking back at them, I'll probably add a gusset to the outer mount, just to be extra safe.
      Got the fire extinguisher in the mail and played around with its positioning on the car. It's funny how much more I can learn from 30s of holding something in my hands vs 30 min of staring at the same thing on a screen.
      Ultimately, I've decided to compromise a bit with the bracket. I was trying to make everything fit with the seat in the absolute lowest position it can go, but I don't think there's really a need for that. This fixation also made me overlook a pretty crucial detail:
Name:	Screenshot 2026-10-14 at 10.27.28 PM.png
Name:	Screenshot 2026-10-14 at 10.27.57 PM.png
      It's nice to have everything packaged neatly and out of the way, but the extinguisher is also entirely useless if you can't get it out from under the seat!
      With the front of the seat in the highest hole, it all works out nicely:
Name:	Screenshot 2026-10-17 at 2.11.32 PM.png
      Amusingly, the top hole puts the seat cushions at the exact same height as the current Nogaros, so it was very unlikely that I would have used the lower holes anyway.
      So, in summary, the brackets themselves will still allow for a lower seat position, but if you want to run a fire extinguisher, you're gonna be stuck with the top hole on the front.
      Some goals for the new version of the bracket that I'm working on:
      1. Bracket needs to be able to be installed/removed without taking the seat out of the car.
      2. Less bends for higher stiffness.
      3. Overlap in a better spot, so that there's less extra material (overlap is there so the width of the bracket is a bit adjustable).
      4. Extinguisher facing the other way. Should make it easier to grab without looking and should also make it much harder to accidentally discharge by bumping it against the transmission tunnel.
        Okay, this is looking waay better now:
Name:	Screenshot 2026-10-18 at 12.11.21 PM.png
Name:	Screenshot 2026-10-18 at 12.11.50 PM.png
Name:	Screenshot 2026-10-18 at 12.12.13 PM.png
Name:	Screenshot 2026-10-18 at 12.13.05 PM.png
Name:	Screenshot 2026-10-18 at 12.41.51 PM.png
        Bracket is designed to be welded where I've scribbled in red for max stiffness, but it's not critical. Cool thing is that sendcutsend can do the welding for me prior to anodizing/powder coating:
Name:	Screenshot 2026-10-18 at 12.42.51 PM.png
        Everything packages nicely (better this time around, actually), bracket should be way stiffer and weight is ~220 g. Pretty happy with that.
        Only thing I'm unsure of is if sendcutsend will be able to bend those tabs in the middle of the bracket that support the extinguisher. Their software doesn't flag it, but that doesn't mean much. Worst case I'll just bend them myself.
          Sub strap bar gusset modeled:
Name:	Screenshot 2026-10-18 at 3.08.28 PM.png
          Aaaand now I've officially run out of things to do without having the seat and another set of sliders in hand.
            So the HalGuard extinguisher comes with a very basic mount. Just a piece of pressed sheet and two clasps:
            Path of least resistance is to adapt my design to interface with this part, but the I don't love the idea of carrying around the unnecessary weight of the base. So off come the clasps! They're just riveted in, so getting them off was easy.
            I then printed a test of my bracket and assembled:
            Everything fit well, but there were a number of things I didn't like, the biggest one being how thin the bridges between the bend reliefs of the clasp tabs are.
            The whole reason why I elected to run the clasps through the mount, instead of riveting them on top, is so that in a crash, the mount takes the load. Just having those thin bridges hold the clasps on kinda defeats the purpose of this design.
            So, time to test some alternatives. I first tried just some slots:
            As you probably tell, threading the clasps through them was impossible.
            After a bit of using the brain, I realized I could entirely get rid of the bottom tabs from the first design and just bend the whole surface, like so:
Name:	Screenshot 2026-10-20 at 9.31.26 PM.png
Name:	Screenshot 2026-10-20 at 9.31.38 PM.png
            Weighs the same, is easier to manufacture, lets me angle the clasps up to avoid snagging them when moving the seat and should add a bit of stiffness. The two bends even contour to the body of the extinguisher better than the tabs did:
Name:	Screenshot 2026-10-20 at 9.32.20 PM.png
            Test print proved successful:
            Happy with this latest design. It's looking pretty final to me!
            CAD says the mount will weigh ~220 g. Extinguisher + clamps weigh 2219 g, so we're looking at roughly 2.5 kg (5.5 lb) for the whole assembly (including fasteners, etc.). A bit more than I would have hoped, but I think having the extinguisher is worth the trade off. The weight is also in about the best place you can put it, so should be fine.
            Oh also, the prototype brackets arrived:
            As mentioned earlier, those are made out of aluminum, just cause it was cheaper. The final ones will be made of steel.
            Now I just need the seats!
              The one hole for the rear slide mount looks to be in the bend radius-- might want to slightly tweak the bed location to avoid distortion.
              That said, SCS may use a tighter bend for steel than alu, so maybe doesn't matter.
                Yep! Bend radius of the steel is significantly tighter than the aluminum.
                  As soon as I read that and saw the pic I knew what was coming. Love the project, thanks for bringing us along.
                  Email to [email protected]
                    It weighs an entire 131g! Can't have that much dead weight just hanging around.
                    Glad you've been enjoying my rambling
                      Certainly it can be tighter-- but does SCS actually make it tighter?
                      (I actually don't know)
                        Indeed. 2.54 mm for steel vs 3.175 mm for the aluminum.
                        Steel part has been tweaked slightly since I got the prototypes made. Those slider holes are 13mm away from the outer edge of the bend, think it should be alright.
                        I'm trying to keep those tabs as short as possible to help with stiffness.
Name:	Screenshot 2026-10-21 at 2.52.56 PM.png
                          Hardware delivery today. Normally, I wouldn't get too excited about some screws, but I found these black torx M5 screws + washers that should blend in real nice with the powder coated brackets. These are meant to be used with the gussets and extinguisher bracket.
                          No unsightly shiny fasteners allowed!
                          I'm hoping the washers don't prove to be too problematic, but they do feel fairly slippery. I don't plan on using them on any joints that either see any real load or aren't accessible when everything is fully installed. I'll probably use some blue loctite on any screws that I use with these washers, as well.
                            Track day at Laguna today. Have to say that I'm very impressed with the RE-71RZ. They last way longer than the RS did and feel just as fast. Happy with that purchase.
                            Also super impressed with the Frenkit dust boots on the 996 calipers. Had some serious brake fade in one of the sessions and they held up nicely.
                            Unfortunately, there was a bit of an incident as well. I had a (non-car) friend in the car for a ridealong and was taking it fairly easy. Let a couple cars by before turn 10 and, as the straight was ending, started going back on line to take the corner. As I was moving left, some corvette guy thought he could squeeze by on the outside, ran out of track and cut me off, hitting my LF tire with his RR.
                            Aftermath:
                            Click image for larger version  Name:	20261102_104122.jpg Views:	14 Size:	106.3 KB ID:	614372
                            Click image for larger version  Name:	20261102_135517.jpg Views:	14 Size:	89.3 KB ID:	614373
                            Could have been a lot worse, but it's still pretty frustrating.
                            Car drove completely fine and a visual inspection showed that everything was in good shape, so I kept going for the rest of the day. No more incidents, but I did see that same corvette guy making some more questionable decisions. His car seemed to have some mechanical issue and the rear was sliding everywhere (guess his car took it worse than mine?), so he kept cutting across the track trying to control it. At one point, I saw him come to a complete stop on the curbing on the inside of turn 2, then try to reverse up the pit exit.
                            Absolute insanity.
                            And no, I'm not salty.
                            Anyway.
                            Took more stuff apart to assess the damage when I got back home and it looks like the only two casualties were the fender and the wheel. Wheel does not look or feel bent, but the outer lip is a bit distorted, so I'm just going to replace it.
                            Paint on the fender is not original (as you can probably guess from the hard candy bondo shell), so not too sad about having to replace that.
                            Click image for larger version  Name:	20261102_191603.jpg Views:	14 Size:	68.6 KB ID:	614374
                            Click image for larger version  Name:	20261102_184629.jpg Views:	14 Size:	192.3 KB ID:	614375
                            Click image for larger version  Name:	20261102_184638.jpg Views:	14 Size:	167.2 KB ID:	614376
                            All suspension components, tie rods, strut braces, etc. look fine, so I think I lucked out! Gonna get an alignment just cause, but as mentioned earlier, it could have been a lot worse. This is about as good of an excuse as possible to finally give the paint on this car a bit of love, so you'll likely see some of that in the future.
                            Noticed a couple other things while doing the post-track inspection. First off, I think I know why I smelled a very faint burning oil smell on the way down:
                            Click image for larger version  Name:	20261102_185024.jpg Views:	14 Size:	128.9 KB ID:	614377
                            Looks like the dipstick o ring. Easy fix.
                            And now for the most puzzling thing of them all:
                            Click image for larger version  Name:	20261102_184839.jpg Views:	14 Size:	104.3 KB ID:	614378
                            I thought it was bird poop at first and was incredibly confused about how it got there. Turns out neither water nor brake cleaner could dissolve it, so I ended up equally as confused.
                            Ended up scraping it off with a plastic trim tool (I'm so glad the calipers are cerakoted) and had some of it come off as a chunk. Some closeups:
                            Click image for larger version  Name:	20261102_190701.jpg Views:	14 Size:	82.2 KB ID:	614379
                            Click image for larger version  Name:	20261102_190815.jpg Views:	14 Size:	66.1 KB ID:	614380
                            I still have no idea what this is. So weird.
                            Anyway. Think it's time to figure out how to get my hands on a euro bumper...
                              melted corvette fiberglass?
                                I think you might be right. My leading theory is that it's melted corvette something.
                                It looked like the corvette only took damage to its wheel (since it's way taller than mine), but I could have missed a small missing chunk somewhere.
