    The Corvette thing is nuts. That would be an immediate black flag for the day at any track in the southeast. Most organizers would probably ban you from future regs too.
    Glad it wasn't worse!
    2003.5 SG/Grey
      yep, northeast too.
      I will say, fully understanding this does not apply to everyone-- I have one event on the west coast (HoD event at Legunca Seca) and was shocked at how much lower the driving standard was than any event I've done on the east coast over the last 20 years. People were both dangerous and... slow. Before the day started did a ride along with an instructor in a C7 (having never driven Leguna) and he was completely inept-- spent the entire session letting the stability control drive his car.
        Fully agreed. Dude was gone after lunch, so I'm assuming he got kicked out. Day went much smoother after that.​
        yep, northeast too.
        This is fully, 100% anecdotal speculation, but it feels like there is a higher incidence of this kind of stuff at Laguna than at the rest of the tracks around here. It's by far the most famous track in the area, so it attracts a lot of people with varying skill/prudence levels. Combine that with being 15 min away from a couple fancy towns with high income residents and you get a lot of people in really fast cars that do not have the necessary experience for their run group.
        Then there's also the issue of track day organizations squeezing in a crazy amount of cars on track at the same time because of the aforementioned demand.
        I'm usually on way higher alert at Laguna because of all of this, but I really wasn't expecting someone to cut me off from the outside when I was already braking...
        Anyway, bumped into some track friends on that day who were running in high intermediate (they're normally in advanced) for this exact reason. I think I may have to start doing the same.
          I'm glad the car is OK and with only minor damage. Battle scars only add to the character.
          COTA is THE worst for this! Total bucket list item for a lot of people and for good reason. It is an actual F1 track. The bad, there has been at least one crash every time I've been there. The track doesn't suffer amateurs. There is a ton of run off...if you bail early. Most lose control after the apex and there is nothing but walls...at a high speed track.
          The worst is the layout. High HP cars pull 20 car length on me into T1 and then I'm on their bumper in T3-5. Pull 30 car lengths on the back straight into T12, I'm in their bumper by T16-18. Rinse and repeat.
            Oh man I bet COTA is worse than Laguna Seca. Very similar experience with the high HP cars over here too, just to a lesser extent.
            The most annoying part of Laguna is that it's actually a really fun track, so I keep wanting to go back regardless of how people behave.
              Also, got sliders in the mail and started test fitting.
              First off was just making sure the prototype aluminum brackets fit and they mostly do:
              There's a bit of interference between the rear left tab on my brackets and the tab that holds the spring on the sliders, but that's an easy fix. The more annoying issue is that those zinc plated slider release tabs interfere heavily with the sub strap bar when depressed. I didn't realize how far down they had to move for the mechanism to release.
              So, the solution is to move the bar back a bit (and up by a couple mm to clear some rivets that weren't captured in my scan) and rework the attachment tabs/gussets. CAD measurements say that after those adjustments, the angle between the harness buckle and the bar is 11.5 deg, so still pretty spot on the spec. As discussed previously, the angle between the bar and the hole in the seat is WAY larger than that (37.5 deg to be precise), but there's nothing I can do about where Recaro decided to cut a hole in their seat...
              (and yes, these brackets are too crusty to put on the car, but they're great for prototyping! I'll need to clean them up or stop being lazy and go find a nice clean set at a local junkyard)
              With the new sub strap bar position, it needs way less cutting, which is also nice. I basically just have to cut the square corners off the front and give it some new slots, like so:
Name:	Screenshot 2026-11-07 at 1.03.19 PM.png
Name:	Screenshot 2026-11-07 at 1.03.35 PM.png
              Put all this feedback back into the CAD and printed out a set of the final(ish) brackets:
              Everything fits statically, but there's massive interference when the release bar rotates. Figured it was time to get that into CAD, so I scanned and recreated it. CAD shows the interference well:
Name:	Screenshot 2026-11-07 at 2.01.59 AM.png
              The prototype brackets are much wider for shimming the seat left/right, so I did not run into the issue with those. I'm glad I printed the test fit.
              The Speed Engineering brackets solve for this by changing the bend location on their outer bracket. Screenshot from their install video and a view of both brackets:
Name:	Screenshot 2026-10-05 at 10.50.32 PM.png
              This is pretty superficial and dumb, but I just don't love how it looks...
              Also, with my design, it would make the front tab super long and flimsy. Yes, there are gussets everywhere, but I still don't love it. So I'm going to cheat!
              Turns out the straight U channel I was using as a placeholder for the release lever lines up almost perfectly with the inner part of the stock release plate/tab/thing (it was like 0.5mm off). So my plan is to attach it to that directly and chop off the part that interferes, like so:
Name:	Screenshot 2026-11-07 at 1.26.15 PM.png
Name:	Screenshot 2026-11-07 at 1.26.04 PM.png
              Yes, this does entirely defeat my implicit "don't modify the stock parts" philosophy, but man, it's so much neater.
              Worth noting that there is a weld bead on the interface between the U channel and the stock part, so I'll need to notch the U channel a bit, no big deal. I still need to figure out how to get this whole part to not rotate down when sitting still and I'll likely take a page out of the Speed Engineering brackets: small laser cut bracket that limits rotation against the bottom of the block that holds the pistons for the slider release mechanism (see below). I think it's a pretty elegant solution, so no need to do it differently.
              Anyway, we're up to speed now. Have some more time in CAD ahead of me, but we're getting close!
