    Keep in mind I've only used them for one track day, but I think they're worth checking out. Looks like they're a bit cheaper than the NT01s too, which is kinda surprising.
    The previous RE-71RSs were fast, but they didn't last long at all. The middle tread section wore like crazy and the rest of the tire fell off and lost grip after about 15 min on track.
    I'm curious to see if this pattern reemerges as the tires go through more heat cycles. So far so good though.
    I've been using Goodyear Supercar 3Rs, they last about 4-5 heat cycles less vs an NT01 for me. The difference is the 3R did not fall off that much. I'd never cord an NT01 but they lost so much grip they became almost undriveable. They aren't that much more than the NT01s...but a LOT better!
      Spent some time cleaning up the seat bracket CAD. It's pretty much entirely parametric now, so I can just change the values of some variable and generate new brackets. Some random examples:
Name:	Screenshot 2026-10-02 at 2.35.27 PM.png
Name:	Screenshot 2026-10-02 at 2.35.48 PM.png
Name:	Screenshot 2026-10-02 at 2.44.51 PM.png
Name:	Screenshot 2026-10-02 at 3.00.58 PM.png
      Also, I think I've decided that that's where the sub strap bar is going to go. I have yet to finalize the mounting part, but I think I've come up with a potentially clever idea. Just need to translate into CAD now.
        404 on those pictures
          Thanks, should be fixed now
            Pulled the track pads off the car today and the fronts looked like this:
            These were a brand new set of PFC08s that I installed before the track day. Rotors look fine, but I only noticed this after I put eveback together, so I didn't measure them. Street pads also look completely normal.
            Super weird.
              Super weird.
              They were overheated.
                Yeah I think you're right, they do look overheated. All the usual thermal measures (Ti shims, cooling scoops) were working and car was stopping fine, though.
                I wonder if I overheated them in the first session, when I was trying to bed them in/learning the new surface. Would explain why they felt fine the rest of the day.
                  Usually caused by not allowing enough cool down. To pads just cook when the car comes to a stop.
                    Makes sense. I did stop for a red flag, so maybe that caused it. Otherwise, it seems like I need to do longer cool down intervals.
                      Very possible the red flag contributed. I get pretty good results with brake cooling deflectors which are relatively easy to live with. Will need to remove the dust shields.
                        Okay, back to seats. Prototype brackets are pretty final now (top picture in my previous seat post), don't think there's much more to do to them besides use them to measure seat placement in real life. I haven't gotten them made yet, but I will soon.
                        Plan is to use the prototypes to fine tune the front/back/L/R/up/down offsets on the car, then translate those to the now-parametrized CAD model. The prototypes are purposefully wider than the seat and have those super long slots to accommodate the adjustments. I'm probably just gonna get an assortment of different length screws and print the L/R shims on demand.
                        Also, brackets are cheaper to make out of 5052 Al than they are to make out of cold rolled steel, so gonna do that for the prototypes. Real brackets will be powder coated steel.
                        With the prototypes out of the way, I moved on to making the brackets look more "normal". This is what I settled on:
                        Click image for larger version  Name:	Screenshot 2026-10-05 at 4.53.46 PM.png Views:	7 Size:	176.7 KB ID:	530290
                        Click image for larger version  Name:	Screenshot 2026-10-05 at 5.02.39 PM.png Views:	7 Size:	470.1 KB ID:	530291
                        Sub strap bar packages pretty tightly in there, but it does work:
                        Click image for larger version  Name:	Screenshot 2026-10-05 at 5.02.00 PM.png Views:	7 Size:	719.6 KB ID:	530292
                        Click image for larger version  Name:	Screenshot 2026-10-05 at 5.04.06 PM.png Views:	7 Size:	751.6 KB ID:	530293
                        Note that I opted to design the attachment tabs for the bar with vertical risers (i.e. two bends), instead of one diagonal riser in the same plane as the middle portion of the seat brackets (i.e. one bend). This is for two reasons:
                        1. I want the bar to not move front/back/left/right, so that the sub strap can tighten properly and not lose tension. The vertical risers should handle the up/down loads better than the diagonal risers (front/back feels like it would be the same), at the expense of some potential L/R movement, which I don't care about.
                        2. On a much more practical note, with a diagonal riser, sendcutsend can't bend the tab on the outer mount because the angle is too tight
                        Eagle eyed viewers will note that the sub strap bar ends look different in the first image in the post vs the second. I'll probably end up trimming it a bit, but I do like the stick out as a secondary mechanical backup. If, for some reason, all four fasteners fail, the bar is still fairly constrained by the vertical risers, the manual release mechanisms on the sliders and the geometry of the cutout on the brackets.
                        With the fasteners missing and the untrimmed ends, the bar can slide L/R, but can't pop out, as it'll bottom out on the sliders. It can also slide back, but it won't because the sub straps are pulling it forward. All other directions are constrained.
                        I also plan on redrilling the bar on the mill, so that I can slot the holes. This will avoid preloading the brackets and thus prevent any binding in the sliders.
                        Last thing to note is the gusset peaking out at the rear (in orange). Here's a better view of it:
                        Click image for larger version  Name:	Screenshot 2026-10-05 at 4.54.15 PM.png Views:	7 Size:	173.4 KB ID:	530294
                        Unfortunately, the seat gets in the way of a larger gusset that spans all the way up the to section with the six holes, but this should still help a lot. I do really like how the gusset packages, especially cause I can get sendcutsend to press in nuts for me to make this a nice and neat bolt in addition:
                        Click image for larger version  Name:	Screenshot 2026-10-05 at 4.43.21 PM.png Views:	7 Size:	35.8 KB ID:	530295
                        Click image for larger version  Name:	Screenshot 2026-10-05 at 4.43.39 PM.png Views:	7 Size:	88.1 KB ID:	530296
                        Last thing I've played around with is the seat release lever and fire extinguisher packaging.
                        Spent some time going through fire extinguisher options and I'm pretty set on the HalGuard HP250 (I've also seen the manufacturer market it as the "HalGuard PRO Halon 2.5lb"). It's the most compact fire extinguisher I could find that doesn't use a dry chemical agent. Lifeline makes a very similar one, but the OD is slightly bigger and the handle is much bulkier, which makes the packaging much more awkward (i.e. pushed further back and thus harder to reach when you're strapped in the seat). I was very tempted to go with one of the tiny Element fire extinguishers, but I don't trust myself (and especially not others) to remember how to light and use it in an emergency. The HalGuard unit is as vanilla as it gets, when it comes to operation. Pull the pin, squeeze the handle. Everybody knows how to do that.
                        Anyway, it's tight under there, but everything does package (rotated handle is there to show how far up it needs to travel to unlock the sliders):
                        Click image for larger version  Name:	Screenshot 2026-10-07 at 3.16.55 AM.png Views:	7 Size:	855.5 KB ID:	530297
                        Click image for larger version  Name:	Screenshot 2026-10-07 at 3.18.04 AM.png Views:	7 Size:	313.8 KB ID:	530298
                        I even managed to package the handle with a U channel extrusion, for added stiffness. This is the same way BMW implemented this handle in the E9x/E8x seats. Happy about that.
                        I haven't modeled neither the fire extinguisher mount nor the full handle lever arm, but I'll take a stab at them later. I'm hesitant to go too far cause I'm missing some key information still. First off, I don't yet know exactly where the seat is going to be placed in space, which will affect fire extinguisher placement. I also no longer have the BMW manual slider release rod (since the Brey Krause Nogaro brackets replace it with their own part), so I can't measure/scan it to design the interface of it against the release lever.
                        I haven't found the time to go dig through cars in the junkyard for manual sliders, but I'll try to get to that soon. If anyone has a set lying around that they want to sell me, let me know!
                          Lesgoo. Looking forward to seeing the prototypes! I may have missed it but have you sourced seats yet?
                          🔹 2001 M3 Laguna Seca Blue
                          Instagram: link
                          Build thread: link
                            Yep! Ordered through Maar-Shop, but the seats haven't shipped yet. Supposedly will be arriving in Germany soon, then they'll get shipped over here.
                              Spent some time this weekend working on a "first draft" of the fire extinguisher bracket:
Name:	Screenshot 2026-10-12 at 12.50.34 PM.png
Name:	Screenshot 2026-10-12 at 12.50.50 PM.png
Name:	Screenshot 2026-10-12 at 12.51.24 PM.png
Name:	Screenshot 2026-10-12 at 12.53.48 PM.png
Name:	Screenshot 2026-10-12 at 12.52.26 PM.png
                              Everything fits and is super light (~200 g for the entire bracket), but man, I just can't get over how ugly it is.
                              I need to come back to this at some point and figure out a better alternative. Am considering designing this to be 3D printed instead of made out of sheet metal.
                                Run any FEA on that sub strap bracket bolted to the seat mounts? IIRC they're supposed to hold under 3000 lbs of load, which isn't insignificant.
                                I would not worry about ugly, since it's all going to be hidden other than one of the two side mounts, once installed.
