Originally posted by heinzboehmer
Used 3M Super 77 for this. Super 90 should work fine as well. Spray it on the pillar cover first, wait for it to get tacky and then press the fabric onto it. If it's too wet when you put the fabric on, it'll bleed through.Originally posted by Ubaderb View Post
What glue do you use?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Picked up something yesterday:
Finish is Cerakote Arctic Black P-202. Supposedly designed to help dissipate heat. https://www.cerakote.com/shop/cerako...lack-oven-cure
Now just need to find some time to rebuild them and get them on the car.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 3
Thanks! That was the intentionOriginally posted by D-O View PostI like the look - all business.
Brake dust colored too, so I don't have to worry about keeping them super clean2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
What do you think of a version of that bulkhead panel with a ski-pass through? Would the rigidity be compromised?Originally posted by Sharocks View PostThis is when I have to ask, is this actually worth it lol
I like having a pass through, makes the car useable since the backseats at least for me are useless now because of my Recaros.
It likely would.Originally posted by nyc951 View Post
What do you think of a version of that bulkhead panel with a ski-pass through? Would the rigidity be compromised?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Started on the brake work.
Quick pic of everything before starting:
Rebuilding the calipers. Decided to use girodisc seals and brembo dust boots after hearing of a friend's experiences on track with the girodisc boots:
And fully dressed:
Unfortunately this is where I realized something went very wrong during the rebuild. Pressure tested the calipers with air and found this:
I thought the seals felt too tight when installing the pistons...
This is the only seal that was obviously bad when pressure tested, but now I don't trust any of the others. I really don't want to find out that another seal is ripped while on track, so I've decided to rebuild all of the calipers again. New seals are on their way.
The more I think about this, the more I lean towards this being an installation issue. I decided to lubricate everything during the install with just brake fluid, but I really should have used assembly fluid. Oh well, at least it was a good learning experience.
Have ordered some assembly fluid for next round. Hopefully that solves all my issues.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
You're talking about heat shields between pad and caliper or between rotor and chassis?Originally posted by Obioban View PostAre you planning to run heat shields?
Either way, I'll be running both. Still need to run the experiment to decide between titanium shims or stock porsche noise isolators.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Yeah I'll definitely report back with how the seals hold up. Have a long track day on Sep 18 (7, 30 min sessions), so will update with how they did.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Absolutely would be compromised, but for a street car this is way overkill lolOriginally posted by nyc951 View Post
What do you think of a version of that bulkhead panel with a ski-pass through? Would the rigidity be compromised?2004 BMW ///M3 Carbon Black/Cinnamon 6MT
2005 BMW ///M3 Interlagos Blue/Black 6MT Dinan S3-R
Fully disassembled the rears. 3 out of 8 seals were ripped, yikes. The other two I found weren't ripped as bad as the one that inflated the dust boot, but still. I'm glad that one failed catastrophically, otherwise I wouldn't have taken these apart.Originally posted by heinzboehmer View PostI thought the seals felt too tight when installing the pistons...
Interested in seeing how the fronts look. Should have them disassembled by tonight.
Also, found a good way to pop the pistons out:- Leave the caliper fully assembled and stuff some wood/cardboard in such that the outboard pistons can't move much and the inboard pistons contact the wood/cardboard right before popping out.
- Pull inboard pistons out with fingers. Should be easy to do if step 1 was done correctly.
- Remove crossover pipe and replace with a bleeder in the outboard port.
- Stuff some more wood/cardboard in such that the outboard pistons contact the wood/cardboard right before popping out.
- Pull outboard pistons out with fingers. Should be easy to do if step 4 was done correctly.
Also, I was at laguna seca for car week stuff this past weekend and Ford had a display with parts from that new homologated GT3 mustang thing. This is what the rear brakes looked like:
Given the design of the front CSL rotors, my current brake ducts will be way less effective and this design looks super appealing. I don't know if I'll have enough clearance under 17s to do something similar, but it would be super cool to build something like this. Air would have to get sucked out of the caliper with this setup and I can think of two ways to do this:- Build an active system that pulls air out with a fan at the end of the brake duct hose. This is appealing because it can get combined with a temp sensor to make sure that the pads are always in their optimal operating temp range. Can also log individual caliper temps.
- Build a passive system with a venturi tube or similar that creates a vacuum in the brake duct hose so that air gets pulled out at speed. Simpler than the active system, but no control over caliper temp, some added drag and potential for overheating on lower speed tracks.
