Robs E46M BRG Street Build
    Your skills are impressive. It’s like you’ve worked on these cars before 😉
      Long overdue update! Been cranking away on this build and made a ton of progress. With the motor back in and basic programming done I gave the engine a quick test fire. Success!
      After the successful first test fire I got the refinished Evolve airbox with matching valve cover installed along with the Turner Motorsports IAT conversion able that plugs unto the old MAF plug.
      Installed a new radiator overflow tank and decided to retain the SAP. Also replaced the windshield cowl and all of the various hood seals.
        With the drive train back in and running I moved on to the exhaust and bumpers. For muffler I went with the @rogueengineering Diablo Caliente section 3. Work of art! Bummer it's hidden under the diffuser. The Diablo is attached to the @supersprint_official 63.5mm catted section 1 and resonated section 2. Will be interesting to see how well this balances with the CSL intake noise.​
        Click image for larger version  Name:	53660708703_bd4c6a03ec_b.jpg Views:	0 Size:	137.0 KB ID:	268243
        Click image for larger version  Name:	53659620012_fd3f9fed78_b.jpg Views:	0 Size:	77.0 KB ID:	268244
        Click image for larger version  Name:	53666847760_f7177aac0e_b.jpg Views:	0 Size:	221.8 KB ID:	268245
          Thats a beautiful exhaust setup. Coming along nicely.
            Awesome build so far, loving the progress and direction the car is headed. With the green paint, silver accents, and kevlar looking carbon in the engine bay, i'm getting some serious AC Schnitzer CLS II vibes.
            Click image for larger version  Name:	ACS-Repro-2015-08-01_1000x657_3000x3000.jpg Views:	20 Size:	198.0 KB ID:	268275 Click image for larger version  Name:	CD_76_02_CLS_II_Motor_1000x657_3000x3000.jpg Views:	20 Size:	302.2 KB ID:	268276
              What a clean build, very cool. Some green carbon trim on the inside would be sweet. oCarbon would probably be able to do that if it was something you wanted. I got my carbon from for my ZHP done by them and it’s fantastic work.
                One of my inspirations!!​
                Yeah I worked with a guy off instagram https://www.instagram.com/carbonized_bg/. Interior pics coming soon!
                  Nicknames can only be bestowed upon by someone else, and I am donning this build The King of the North! Long live the King of the North! (Game of Thrones reference for some of you gents)
                  /// 2004 SG/IR - Build Thread
                    On to the exterior trim. I had the finisher rails painted gloss black to match the Shadow Line high gloss black trim on the doors and vent window. That trim is getting hard to source, I ordered from Schmiedmann and it tool 4 months... With the rails off I also installed new seals for the vent windows. Also new window and door seals sourced from Schmiedmann.
                    For the interior I started with the doors. Such a pain in the a$$.... Took for ever to get the glass re-installed and after getting it all back together the passenger door lock was acting up. So decided to just bite the bullet and replace the lock actuator. Then got the vapor barriers with fresh butyl installed.
                    Finally time to start installing the new custom interior!!
                      For the interior I worked Joni at Prestige Prestige Auto Upholstery (aka BMWrestoreseats). He's pretty local to me and great to work with. Right on the way to my regular FCP Euro visits 😂. I wanted a tan interior and it was temping to follow what I did with Rosso, but also wanted something unique. Ultimately decided to go with a light tan as the primary with black Alcantara inserts and trim. Very happy with the result! Also went with the only proper seats for this car, Recaro Sportsters.
                      Alcantara headline, rear deck and pillars
                      Used the updated E46 non M insulation under the rear seats, fit prefectly.
                      Rear seats in
                      Front seats in!
                      I used the same front seat mounting solution as Rosso, Brey-Krause adapters with OE electric sliders using E30 front/back switch.
                        Rebuilt to better than new, love it! +1 for awesome color choice, I'm partial to greens as well.
                        '07 M Coupe - RAC RG63 - AutoSolutions - Bilstein PSS10/B16 - Arqray
                          Rear seats in
                          Front seats in!
                          What’s the part number for the non M insulation?
                            Functionally, what’s the difference between the M vs non-M insulation?
                              What's the part number for the non M insulation?
                              Yeah I think I need to order one too
                                Rear seat sound insulation part number
                                Hi all, Hoping to crowd-source some knowledge here. I've pulled up the butyl-type sound deadening under the rear seat as it was all broken up as I understand happens. The part number on what I removed is 51488204055 however when I check on realoem and on schmiedmann they both indicate that that part number didn't come on my
                                2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats
                                Build Thread:
