JBanzhaf Grabbed me this screenshot from ISTA. Hopefully the next person googling for this can find it. Pretension to 170nm, back off, torque to 120nm
1997 m3 sedan with s54 swap
Intake prototype parts for section 1 and section 2. This feeds my AFE intake nicely. The plan is to have section 3 be CSL box specific. The print failed near the top but still usable to test fitting. It was never going to be an end use part since its just printed in petg-gf
One challenge I need to solve: The engine will move and there isn't a ton of ability for all of this to flex. I'm trying to figure out the best way to get some flexibility into the design without having to resort to anything that flows really badly like a corrugated hose. Open to a few ideas including wrapping and forming a custom shaped silicone hose/coupler, making longer slip fit joints between each piece, and keeping the middle section printed or made out of something with more ability to deform (polypropylene is a bitch to print but would work).
2 Photos
The newer, "high flow" TPU filaments are fairly easy to print. I've tried a couple softish ones (~90A) and they were all easy to work with. I've also printed things out of this stuff, which was significantly more of a pain: https://recreus.com/en-en/products/filaflex-60aOriginally posted by 3staxontheradio View PostOne challenge I need to solve: The engine will move and there isn't a ton of ability for all of this to flex. I'm trying to figure out the best way to get some flexibility into the design without having to resort to anything that flows really badly like a corrugated hose. Open to a few ideas including wrapping and forming a custom shaped silicone hose/coupler, making longer slip fit joints between each piece, and keeping the middle section printed or made out of something with more ability to deform (polypropylene is a bitch to print but would work).
Required messing with the extruder tension and feeding the filament directly into the extruder (even with a PTFE tube, the friction was too high). But, once set up, it does print out fairly well and is extremely flexible. Not sure you need that much flex for this piece, but it's an option.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
My main hesitation with TPU is that the thermal performance isn't great. I haven't looked into them that hard though so maybe I am just ignorant on them.Last edited by 3staxontheradio; 04-25-2025, 11:20 AM.
Looking at the data sheet for that one: what am I really looking for as a standard to use? It's by definition soft so that's not an issue. Is there a standard out there for measuring plastic deformation creep?Last edited by 3staxontheradio; 04-25-2025, 11:18 AM.
I don't actually know the answer to that. Maybe you could go off the melting temperature (and add some margin)?Originally posted by 3staxontheradio View PostLooking at the data sheet for that one: what am I really looking for as a standard to use? It's by definition soft so that's not an issue. Is there a standard out there for measuring plastic deformation creep?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
More scanning, more reworking but I am close to a final design. I don't have the exact location of the CSL flange yet so that is just approximate. I printed a test part for fit check and its perfect, no extra space.. Intake area cross sections are also well dialed in.This version needs a slight adjustment to the brake ducting so I will be scanning one of those and reworking. It will need a small notch to make some clearance and the sensor will get relocated to the top.
I also got to use a grinder on this car for the fist time removing the horn bracket:
Headlight comparisons:
Been doing lots of things with my car instead of getting it back on the road. Short shift clearance for how this transmission sits in my car has been a problem so I am making up DSSR and shift carriers to solve that. These will be DMLS aluminum parts. I ended up settling on a garagistic adjustable shift lever. A quick chart I put together comparing dimensions of the shift levers I have laying around:
These are close to final iterations for carrier and DSSR:
Plastic prototype parts fit tested in the car:
- Likes 5
I also made up a battery bracket for an optima D35 style battery. It's printed in Nexpa-GF25 and I overbuilt it. The battery floor area has lots of panel joints and small surface changes to make clearance for so there was a surprising amount of complexity that had to get built into it.
I put it on makerworld:
