The Red Drift ///Machine - 2026 NASA TT4 adventures
    I deleted the hood shocks and always had issues with opening the hood after a track session to let it cool off.
    well...no more! Cost about $30. It locks into the aerocatch latch and the pin. Wind proof!
      Air dam is almost done. Needs a little more trimming.
      I'm happy with the brake deflectors. So mold making has started! I think I have an idea for mounting. More to follow!
      Taking Bryson's reinforcement plate and making a CF part!
        It is a mad dash to NASA on Jan 30th and to finish a bunch of molds before Apr 30th when it starts to get hot in TX. Working with polyester resin in the heat sucks. Make molds Jan to Apr, Carbon parts May to Oct, more molds Nov to Dec.
        Air dam is trimmed and finished.
        Click image for larger version  Name:	IMG_5484.jpg Views:	0 Size:	31.2 KB ID:	332317
        Click image for larger version  Name:	IMG_5485.jpg Views:	0 Size:	32.8 KB ID:	332320
        1.2 lbs...should save me 1-2lbs over my cheap amazon.com aero version.
        Click image for larger version  Name:	IMG_5486.jpg Views:	0 Size:	59.5 KB ID:	332322
        Separate foglight block offs.
        Click image for larger version  Name:	IMG_5487.jpg Views:	0 Size:	84.3 KB ID:	332319
        Front bumper molds...3rd try...done. 1st attempt - the flanges need more support so they sagged when I was laminated the FG. 2nd attempt - I used some borderline release agent. Apparently, it was on the wrong side of the borderline so the part stuck to the mold and destroyed it.
        The plan is to pull a part and mold the air dam and some tire spats into one piece. Finally, make a mold of the entire assembly.
        Click image for larger versionName:	IMG_5492.jpgViews:	0Size:	114.7 KBID:	332316
        Single air duct and brake deflector molds done. Still working on the wheel well plates. Had a gel coat issue so I'm starting over.
        Click image for larger version  Name:	IMG_5489.jpg Views:	0 Size:	91.2 KB ID:	332321
          The car 100% needs a suspension refresh. The car is no longer comfortable to drive and there is a noticeable difference between front and rear tire wear. You can feel the suspension bottom out over curbs and bumps. It now hurts my back, the ride used to be more comfortable than my Dinan stage 2 E90 M3. Now just waiting on Jalal (aka Shaikh) to do his FCM stage 3 magic.
          AJ Hartman rear wing is on order, might be here in 2 weeks. Also time for a front splitter upgrade. I have to get into compliance with the 6" limit for NASA TT4 and will also add some tunnels. My splitter is 6.25" along 14" on the edge of the splitter...a 1/4"!!! But I don't want to hear any shit so better to be safe than sorry.
          FYI...A 6" splitter is a bad in-between for NASA. Needs to be a little less than 6" for TT4 or 10"-11" for TT3.
          And finally, I will implement the cheat code - Hoosiers!
          And It's been a little bit since the last driving video. So if you can't sleep just watch this for a minute.
            Working on CF strut tower plates. Making a compression Adding a tab to make a triangular brace. The layup will be long strand forged carbon with nut inserts molded in. I have no idea if the insert will hold up. Worst case, I drill them out and bond a stud plate underneath.
            Half way done! The 2nd half of the mold will be a PIA. All of the little details will provide opportunities for a bad release.
              Maybe consider making the underside flat? The details are just there to save weight for the cast part.
              (which means you'll end up with a heavier carbon part if you fill that in, of course)
                I did but I don't think it will be a huge issue. I use release wax and then a chemical release. So I just need to spend more time getting the wax into the corners. Then the chem release is a solvent so it should provide a good backup to the corners and edges.
                  You could also do a hybrid. Fill the tight corners with putty to open up the radii and make release easier with little weight penalty.
                    I would more likely do that for the first half but I'm willing to risk it for the 2nd half. The 2nd half uses about 1/3 the casting resin and is relatively quick to setup. Most of the work is in the first half of a compression mold.
                      2nd half of the mold is done. Once again, I forgot to install drive pins in the negative side to get the part out. So I had to drive the part out by threading a bolt in. I chipped the mold around the bolt hole which will require a repair. It will be a pain but maybe I'll learn my lesson this time.
                      Also didn't catch a negative draft around the inner opening. So I need to make 2 small repairs on each side.
                      Overall they came out really good!
                      Onto making the repairs, calculating the volume, and then making a part sometime in the future. Just not sure when, gotta get ready for NASA in 3 weeks among other things.
                        Making a CF version of Bry5on's wheel well plates. It came out ok, needs to be a little thicker and needs a quasi isotropic layup.
                          EDIT: Added some explanation on how to work with foam in an infusion or wet lay.
                          Progress towards NASA Jan 30th...
                          Splitter is made and came out great! The spread tow fabric looks outstanding as always!
                          Foam core cut and shaped
                          Click image for larger version  Name:	IMG_5545.jpg Views:	20 Size:	86.6 KB ID:	340672
                          This was a wet layup and the vacuum bag. Not 100% optimal but the foam core presents some infusion challenges without infusion channels. The foam core is impermeable so the large flat surface will not enhance resin flow in an infusion. Some resin with flow through the carbon except for any spot where layers of carbon tows line up. And then any air will have an extremely hard time to flow towards the vacuum side.
                          I drilled over a hundred holes in the foam to allow air to flow from the mold surface. Even then, I didn't want to risk large epoxy voids in an infusion. The holes in a wet layup will allow for excess resin and air to be pulled through the holes and towards the vacuum. But damn...a wet lay is a LOT more work! Critical to use a very slow hardener and mix in smaller batches to prevent exotherm. I used Pro-Set extra slow so I had 3 hours.
                          If you do a wet layup, it is important to thoroughly roll the layers under the foam to remove as much air as possible to minimize the risk of air being trapped under the foam. Air creates resin voids which results in a weaker part.
                          Click image for larger version  Name:	IMG_5588.jpg Views:	21 Size:	93.2 KB ID:	340668
                          i am installing tunnels but the challenge with the E46 is the short overhang. The tunnels sit right where everyone places the splitter mounts. So I'm using a bridge which I will bond and bolt to allow for an optimal mounting location.
                          Click image for larger version  Name:	IMG_5589.jpg Views:	20 Size:	82.7 KB ID:	340674
                          Click image for larger version  Name:	IMG_5590.jpg Views:	21 Size:	100.0 KB ID:	340670
                          Less than 9lbs!!!
                          Click image for larger version  Name:	IMG_5591.jpg Views:	22 Size:	55.5 KB ID:	340669
                          AND...AJ Hartman rear wing. Somethings are better left to the professionals. A rear wing is one if those things. Expensive but the E46 kit is comprehensive. Took an hour to mount. Easy peasy!
                          Click image for larger version  Name:	IMG_5561.jpg Views:	21 Size:	116.8 KB ID:	340671
                          Click image for larger version  Name:	IMG_5560.jpg Views:	22 Size:	114.9 KB ID:	340673
                            You have some mad skills sir! I am always interested to read your updates.
                            Old, not obsolete.
                              Thanks! Actually...making a glossy flat carbon part is easy if you use glass or plexi. Looking at the AJ Hartman rear wing, I have a long way to go with developing my composite skills!
                                The final days getting ready for NASA. Nothing going as planned. Scrambling to find someone to drill holes in some weightlifting plates for ballast, tires being delayed by the weather, and having issues finishing composite projects due to cold weather.
                                My car taking a weee in preparation for 20 degree weather in Houston that never came.
                                Click image for larger version  Name:	IMG_5603.jpg Views:	7 Size:	96.0 KB ID:	342541
                                Got the new splitter mounted. It looks relatively simple but tool 3x longer than I planned and I'm not sure why. I do need slightly longer mounts due to the air dam being taller.
                                Click image for larger version  Name:	IMG_5604.jpg Views:	7 Size:	110.1 KB ID:	342542
                                Click image for larger version  Name:	IMG_5605.jpg Views:	7 Size:	116.7 KB ID:	342544
                                Check out my kidney grills!
                                Click image for larger version  Name:	IMG_5625.jpg Views:	7 Size:	114.6 KB ID:	342545
                                Had to go back to the old splitter for TT4...all ready to go!
                                Click image for larger version  Name:	IMG_5620.jpg Views:	7 Size:	127.6 KB ID:	342546
                                Click image for larger version  Name:	IMG_5621.jpg Views:	7 Size:	126.8 KB ID:	342539
                                Click image for larger version  Name:	IMG_5623.jpg Views:	7 Size:	117.7 KB ID:	342543
                                Click image for larger version  Name:	IMG_5619.jpg Views:	7 Size:	129.1 KB ID:	342547
