NO OBD2 communication after CSL tune
    Hey guys
    I am not to familiar with coding and tuning honestly
    Ive installed my Karb. CSL intake along with HTE tune from Hassan.
    Which has been running great no problems what so ever
    Hassan is awesome always sticking by.
    Since I just relocated to TX
    I took the M3 to get an inspection
    There is no communication so I can not pass inspection
    I hooked up my scanner (Schwaben)
    no OBD 2 features, it does read the vehicle when I scan using BMW icon
    I get a question mark for the DME.
    Hassan said it just needs a firmware update.
    We got that done, did not work right away
    drove it around next day it worked.
    checked it again this morning and no communication again.
    Does it need more time? I'm at a blank here
    any input and knowledge will help.
    Subscribed as I need to eventually get smog inspection and pending tune with Hassan.
      I think this is the thread you are needing.
      The CSL binaries Paffy has on the MSSFlasher website do not have all the changes necessary to play 100% nice with the non-CSL bootloader. It mostly works, but notably the ability to read error codes is broken Download a corrected program here (https://nam3forum.com/forums/filedata/fetch?id=12984) Flash only the program -
        https://nam3forum.com/forums/forum/s...asher-csl-tune
        Thank you
        I have no idea what I'm looking at lolol
        I will try my best to self educate
          This isn’t something I can learn in a few hours
          Can someone help me out using team viewer or something similar
          I need to get the car inspected as soon as possible
            Are you running CSL software for a MAP sensor? If not, you should ask Hassan about this. Stock software with an alpha n tune for a CSL airbox should communicate just fine with emissions computers.
            If you are running CSL software, then the no communications issue is a known bug: https://nam3forum.com/forums/forum/s...o-csl-software
            No real fix unless you want to go through the trouble of porting over BMW's software patch.
              I am running the map sensor
              So I’m guessing the software along with it
              So the alpha N tune
              Would not give me this bug ? From what I’m reading
                Originally posted by Stack View Post
                So the alpha N tune
                Not if it's based on the regular non-CSL firmware
                  I noticed a little trick
                  If I cycle the key on to off then on again
                  It reads the scanner and I have obd 2 communication.
                  It’s not perfect
                  But at this point I’m willing to live with it
                    It’s not perfect
                    This hack works on my car which hasn't been mapped.
                    These cars can be quite odd at times...
                    2002 BMW E46 M3 Coupé
                    2005 Porsche 911 (997.1) Carrera S
                      FWIW 0401 Community Patch fixes this issue by porting the same fix BMW applied to the standard M3 software across to the CSL software.
