Flashing the MK60 with ZCP software
    A software only flash is way more appealing than swapping hardware and building a custom firmware and vehicle model that may or may not behave as safely for most people. We’re still working to eliminate opening/physically accessing the MK60 module to flash if that wasn’t already clear.
    That said, you’re not exactly wrong. The MK60e5 has a more detailed vehicle model that includes things like compensations for tires, as well as several other features. The e46 MK60 has an extremely simple vehicle model for calculating/triggering interventions. Porting the e46 model into a MK60e5 also does not appear to be trivial. The e46 CAN integration is the easy part.
    I might have missed that part. To be honest, I haven't read through the entire thread. I tend to jump in and out, skimming through several pages as I browse.
    That said, where can I find the firmware dumps? Is there a repository or a collection of links somewhere. i can also help with disassembly. Nvm Found it
    The MK60E5 is quite popular in the ABS retrofit community and is used in all sorts of applications and it will make it way in my E36 with a flavor of zcp software....one day🤣
      We might have mislabeled mine and it could be an 813.3. I’ll get in there with a mirror. It’s byte identical to another 813.3 Ryan_R just shared.
      and this numbering logic makes way more sense. I was wondering…
      So my 818.3 does not match the M3 dumps we had FYI. Sent it to the group.
      Do you mind posting the output of the ident job and ident_teves_ecu_sw_nr job from your module? This is what my 818.3 shows
      Code:
       JOB_STATUS = OKAY
      ID_BMW_NR = 2282250
      ID_HW_NR = 0.1
      ID_COD_INDEX = 6 00 06 ..
      ID_DIAG_INDEX = 6 00 06 ..
      ID_VAR_INDEX = 22 00 16 ..
      ID_DATUM_JAHR = 2004 07 D4 .Ô
      ID_DATUM_MONAT = 9 00 09 ..
      ID_DATUM_TAG = 11 00 0B ..
      ID_DATUM = 11.09.2004
      ID_LIEF_NR = 24 00 18 ..
      ID_LIEF_TEXT = Temic
      ID_SW_NR_FSV = 0.0.129
      ID_SW_NR_OSV = 0.0.0
      ID_SW_NR_MCV = 0.0.0
      ID_SW_NR_RES = 0.0.0
      _TEL_AUFTRAG = 6 Bytes
      0000 : B8 29 F1 02 1A 80 ¸)ñ..?
      _TEL_ANTWORT = 36 Bytes
      0000 : B8 F1 29 1F 5A 80 00 00 02 28 22 50 01 06 00 06 ¸ñ).Z?.. .("P....
      0020 : 00 00 00 73 ...s
      Code:
       JOB_STATUS = OKAY
      SW_NR = AUPY3482.9C3
      SW_DATUM = 17.03.03
      SW_ZEIT = 14:13
      0000 : B8 29 F1 02 1A 94 ¸)ñ..?
      _TEL_ANTWORT = 37 Bytes
      0000 : B8 F1 29 20 5A 94 0C 41 55 50 59 33 34 38 32 2E ¸ñ) Z?.A UPY3482.
      0020 : 00 00 02 01 7A ....z
      Maybe it's better we label these with the internal SW numbers (i.e AUPY3482.9C3 for my example)
        Click image for larger version  Name:	grafik.png Views:	7 Size:	14.1 KB ID:	616629​
        Here are the time stamps and teves software number extracted from the other bins.
        Originally posted by Claude
        MK60 818.3 (E46 M3, non-ZCP): two different software levels exist – comparison of terraphantm's dump vs. the known 818.3 dump
        Thanks to terraphantm for sharing his DSC dump. It's labelled 818.3 like the 818.3 dump we already had, but it is not the same software. It isn't a bad read and it isn't a tune either. It's a later factory build of the same 818.3 code base with a different parameter set. Here's what I found. This is an analysis only, not a flashing guide.
        1. Identification (KWP 1A 94)
        Both images carry a 30-byte ID record. Its pointer sits in the header at 0x230. The record is exactly what the ECU sends back for ReadECUIdentification 0x94:
        • Known 818.3: AUPY2681.ZC5, built 14.06.02 14:30 (record @0x3DB08)
        • terraphantm's 818.3: AUPY3482.9C3, built 17.03.03 14:13 (record @0x3DAA8)
        Date and time are stored as binary bytes, e.g. 11 03 03 = 17.03.03 and 0E 0D = 14:13. I rebuilt the 1A 94 response from the ROM: it matches terraphantm's diagnostic log byte for byte, including the XOR checksum 0x7A. So the newer one is about 9 months younger.
        For reference, the other E46 dumps:
        • 811.3 (non-M): ASPY1681.XC3, 07.06.01
        • 817.3 (M3 ZCP): AWPY3381.ZC4, 13.02.03
        • 820.3 (non-M): APPY2782.KC8, 27.09.02
        2. Integrity / lock status
        • Both start-up check words (the 32-bit MISR over the vector table and over the main image) verify OK on the new dump. It's a self-consistent factory image.
        • Same lock situation as the old 818.3: "LOCK" at 0x200, no backdoor key, no KWP RequestDownload/TransferData, no flash-controller access in the code. Nothing changes regarding flashability.
        3. Code
        • 0x0000–0x2BC00 is identical, apart from address relocations. RAM variables are shifted +4 to +8 bytes because the newer build has a few extra RAM bytes. Pointers into the calibration area are shifted −0x60 to −0x80.
        • From 0x2BC00 up there are real code changes, net 0x60 bytes shorter. The image ends at 0x3FC64 instead of 0x3FCE4.
        • All 818.3 function names below 0x2BC00 carry over 1:1. Above that they need the −0x60 offset or an alignment.
        4. Calibration blocks
        Most calibration blocks are byte-identical: AUTY, the existing NOPARADJ block, AUPY data and AUTS. AUTB, AUTC and AUTT differ only in embedded pointers.
        The big difference: AUTW24F1.DFT is gone. In the new build that block is tagged NOPARADJ.UST, i.e. "no parameter adjust". Its 16 scalar parameters were compiled into the code as constants, and 6 of them have new values:
        • param @0x3EBC6: 90 → 60
        • param @0x3EBC8: 50 → 75
        • param @0x3EBD4: 150 → 120
        • params @0x3EBDC/DE/E0/E2 (four channels): 10 → 25 each
        Unchanged: 50, 150, 70, 13000, 16500, 2, +127/−127, 25 and the other 50.
        Example: one function computes min(|x|,150) * 90/150 + 150 in the old build and min(|x|,150) * 60/150 + 120 in the new build. The caller subtracts the offset again, so that term is cut to 2/3 (max 60 instead of 90). What these parameters do physically is still open. That code area isn't named in the 818.3 name catalogue yet.
        5. Odometer-based reset rewritten
        The DSC reads the odometer from the cluster (CAN 0x613, bytes 0–1, 10 km units). At 500 km and 1000 km it clears a block of per-wheel adapted values.
        • Old build: index = km/500. It resets when the index steps up by one, below 1500 km.
        • New build: rewritten with a new status bit and hysteresis. It arms at 480–499 / 980–999 km and fires at 500–520 / 1000–1020 km. There's also a new small function that sets this bit from an init/clear routine.
        Same intent, but it's more robust against jumps or invalid odometer values (e.g. cluster swap).
        6. Other diffs
        The remaining diffs in the fault-handling area look like a different compiler/code-generation output, not functional changes. One example: a function now returns a normalised 0/1 instead of a masked value. I haven't checked every one of them individually.
        TL;DR: There are (at least) two 818.3 software levels. ZC5 is from 06/2002, 9C3 from 03/2003. The 9C3 build has the AUTW parameter block baked into the code, with 6 values changed, and a reworked 500/1000 km adaptation reset. Maps, CAN layout and lock status are otherwise the same. If you have an 818.3 unit, the SW number from a 1A 94 / ident read tells you which one you have.
        Method: raw-image diff with M·CORE disassembly (opcode-normalised alignment so that shifted branches/literals don't show up as changes), every parameter load site compared side by side, check words verified with the MISR verifier from the MK60-M-Core-Disassembly-Process repo.
          So thinking about it, the fact that we have two 818.3 modules with different software onboard to me suggests that these things were programmed after production rather than having a fixed ROM burned at the factory. So likely flashable if we figure out how to talk to the flash controller?
          Edit: Also the first CSL was built in September 2002 right? So there must be a variant of the module that predates the dump we have (I haven't dumped my actual car's module, but the software version matches the string above).
            Documented how I built my bench harness here: https://github.com/heinzboehmer/MK60.../bench_harness
            In case it's of any use to anyone.
              Is your MK69 labeled with PN 2 282 250? Mine is 2 282 249 …
              I’ve got a line on another 249 early 818.3 MK60 to try bench flashing in the coming days. Looks like we may have found the golden ticket, or at least something close to it.
                This is the label on mine
                  So re: flashable modules -- in the past I have been told "ID_HW_NR" (from the 'ident' job --output reproduced below) being 0.0 indicates a flashable module while 0.1 indicates not-flashable (i.e fixed rom). Anything in the disassembly to indicate that could be a real marker of onboard flash vs ROM?
                  Code:
                   JOB_STATUS = OKAY
                  ID_BMW_NR = 2282250
                  [B]ID_HW_NR = 0.1[/B]
                  0000 : B8 F1 29 1F 5A 80 00 00 02 28 22 50 [B]01 [/B]06 00 06 ¸ñ).Z?.. .("P....
                  Circling back to this one for closure. ID_HW_NR is located at EEPROM 0x135 and doesn’t appear to be referenced anywhere in the disassembly on my check. We can of course write to EEPROM (have two methods to do this now) but it doesn’t look like that helps us unfortunately.
                    Well that gives me hope that it’s not a true indicator of much then. Signs seem to be pointing towards there being no real flash ability difference. Though what gives me pause is you’d think the guys who flash these things would have tried.
                      You’ve got to wonder if they did the disassembly work or just happened to get their hands on a leaked factory tool. If the latter, it could just be pointing to the wrong location and only compatible with certain modules? But yeah, it’s suspect. And odd that the early 818.3 and 813.3 are identical with a normal privilege read.
                      We do have a method to do reads of some additional program areas that were behind a privilege wall now, but it’s not wrapped up into a nice easy tool just yet. Still no silver bullets.
                        Everything I've heard points to it being the latter. Rumor has it that the modules are sent to some third party that has the factory SW tool to reprogram them.
                        As far as I can tell, MK aren't actually flashing these modules themselves.
                          I would agree. It’s been rumored for years, before AI was around, and doing reverse engineering without it 10 years ago would have been a serious time consuming project. Probably some race team that had access to a piece of software that was given to some shop…
                            The guy doing the actual flashing was working for Teves during the time these units were in production, so definitely some leaked intel.
                              That's almost always the case. Whenever I see someone with extreme knowledge no one else has in the software/hardware world then I know 99.99% of the time it is due to insider knowledge and not genius. AI has changed this a bit, in that now I know someone has pointed AI toward whatever it is they are studying.
                                Haven’t dropped an update in here but there’s been an incredible amount of progress. All working on the early 818.3 M3 MK60..
                                Disassembly is complete and every function/table is named. No onboard bootloader unfortunately confirmed. No flash controller that we can find thus far.
                                Here’s a full table of every internal M3 <> ZCP difference, there are 22 and none of them are editable with NCS Expert: https://github.com/Bry5on/MK60-M-Cor..._edit_list.csv
                                I also had the bot take a crack at describing the vehicle model in more detail. It’s pretty concise so I’m just gonna paste that here (sorry for early readers, will fix the markdown artifacts when I’m at an actual computer):
                                **How an intervention happens, start to finish** (E46 MK60 818.3 (M3), MK60-view speed):
                                1. **Steering:** the `0x1F5` steering angle goes through offset learning (`0x24F46`). The coding steering set then converts it to road-wheel angle; your `wert_04` picks set 4 in code.
                                2. **Dataset:** coding unpack (`0x3B5D8`) picks dataset 10 for your car.
                                3. **Static model:** `r_ref_eval` @ `0x29606` computes the reference yaw from steering angle, speed, A and B. This is the textbook formula we've been using.
                                4. **Dynamic model (new):** the reference the firmware actually compares against isn't that static value. It's a dynamic model (`0xD98C`) that starts from r_ref and then runs its own states, using **15 more per-dataset tables**, the μ estimate, and a speed-scheduled filter.
                                5. **Measured yaw:** the `0x1F3` yaw minus the learned yaw offset, then filtered.
                                6. **Decision:** the error is |measured yaw − dynamic reference|. It's checked against the oversteer bars (the taper down to the 3.00 °/s floor) plus timers. The result sets the DSC-active bit and feeds the valve masters. I haven't decoded yet which valve each wheel gets.
                                7. The 0x235/0x316 engine-intervention flag feeds only the torque, TCS and lamp code. It isn't part of the yaw decision.​
                                **What's new from the full map:**
                                - **ZCP differs from your dataset 10 in far more than A/B.** There are 22 more tables plus one curve that differ, including a bar table tied to B (8024 vs 12297), an inverse-model 1/B term (1806 vs 1178), and all 15 dynamic-model tables. A filter curve is all zero on yours and {6380, 6380, 4969, 0} on ZCP.
                                - **There's a second model.** It works backwards from measured yaw and lateral g to the steering angle they imply, and compares that with your actual angle.
                                - **There's a third way to trigger DSC.** That steering-angle residual can set DSC active, but only between 14.4 and 100 km/h. Your 60–68 mph sweepers (about 97–109 km/h) **straddle that 100 km/h limit**.
                                - **The car learns a yaw offset while driving.** It moves only about 1 count per second, so it can't cause a single event by itself. You can read it live, along with the steering offset, with KWP `0x21` local ID `02`.
                                - The coding bytes only change gain, not the entry bar, which confirms what we thought before.
                                **Does the B edit alone fix it? Probably not fully.** B is the biggest steady-state term. With the ZCP reference, both 60–68 mph events clear, but event #2 clears by only 0.09 °/s, and 3 of 5 logged events still trip. An A/B-only edit would leave the static model on ZCP values but the dynamic and inverse models on non-ZCP values. Our offline predictor also uses the static reference, not the dynamic one the firmware compares against. That fits the missed event #2 and the long tail on #3.
