Thanks for the advice. I’ll report back when I dig in and fix this after I get back from some work travel.
Clutch switch
Finally got back to this. Traced the wiring and all appears to be as it should be physically. I verified continuity of the harness as well. At the clutch switch connector:
1. GND
2. DME (12V clutch pedal up -> 0V clutch pressed)
3. +12V
4. EWS pin 8 (0V up -> 0V pressed)
This thread was a big help: https://nam3forum.com/forums/forum/m...h-help-code-50
Seems as if no meaningful signal is getting to the EWS. Bad switch warranting a call to Bimmerworld?Last edited by nahvkolaj; 05-08-2026, 08:53 AM.
Are you using a black clutch switch, a brown clutch switch or a green clutch switchOriginally posted by nahvkolaj View PostFinally got back to this. Traced the wiring and all appears to be as it should be physically. I verified continuity of the harness as well. At the clutch switch connector:
1. GND
3. +12V
If it's a black clutch switch, what is the part number on it? Does it end in 700?
If it's a green clutch switch, then you'll need to disable clutch switch in the ews module because the green clutch switch doesn't support ews interlock which is why you wouldn't be getting a signal
If it's a brown clutch switch, I'm not sure then....
It’s a supposedly “new” black clutch switch with P/N 61-31.9122700.9 etched on it.Originally posted by nextelbuddy View Post
What is the correct behavior at Pin 4? Does the switch pull a 12V signal to ground from the EWS when the clutch is disengaged? Or does it send 12V to the EWS when the clutch is disengaged?Last edited by nahvkolaj; 05-08-2026, 01:06 PM.
