    Originally posted by SliM3 View Post
    Don't rely too heavily on that funktionsrahmen as it is not accurate!
    Yeah definitely - it's riddled with inaccuracies/additions that have been made in code after that version of the funktionsrahmen was written. Have found it useful though to explain some of the concepts / thinking behind various modules that you can then match up (or not) to what's in the code.
      Awesome work! Its nice to see more people diving into this. I have some IDA disassemblies of MSS54 from the CAN bus analysis, I dig them out and send them to you, maybe its of use for you.
      Would you be fine with me linking this thread or the Github page on MS4X.net?
        That would be awesome thanks! The more we share the better! Yes please feel free to link to either or!
          I haven't posted any updates in a few days but have been making some progress.
          One of the key components of MpowerE36's work is the calculation of what he terms m_720_map, which is the calculated air mass per 720 degrees of crankshaft rotation. It's the main component of the calculation of RF from MAP.
          as he identifies the calculation of m_720_map looks like this:
          Code:
          m_720_map = m_720_1 - m_720_2 - m_720_3
          Now m_720_1 is calculated air mass based on the MAP sensor reading and nominal air pressure and temperature - that's the baseline if you will.
          m_720_2 is a compensation for pressure loss in the system (due to TETV (tank ventilation) and the like).
          m_720_3 Mpower_E36 has identified as "air mass correction per 720 degrees of crankshaft rotation" and referred to the table at 0xe42c - it looks like this:
Name:	Screenshot 2025-03-14 at 8.52.59 AM.png
          Now the thing is, by default 0401 doesn't use this table. If we look at the segment task we see (in part):
Name:	Screenshot 2025-03-14 at 8.54.08 AM.png
          k_rg_m_cfg's (my name) value is 1 in 0401:
Name:	Screenshot 2025-03-14 at 8.55.03 AM.png
          So by default two functions are called. the second of these (what I've called rg_m_calc()) provides a calculated value for MpowerE36's m_720_3.
          And when I look through this function it is calculating a mass value based on things like intake and exhaust camshaft position, tabg (there are an entire separate set of tabg calculation functions solely for informing this function), etc.
          Now why would we need to know camshaft position and exhaust gas temperature? Because what m_720_3 is is the calculation of the mass of residual exhaust gas left in the cylinder (which varies, especially, based on cam overlap). Remember the DME intentionally recirculates some exhaust gas (particularly at certain RPM and loads) to reduce emissions and we can see this playing out in the table above (which isn't used by default, but gives us a representation of what the system is doing).
          Anyway - I have some more work to do to finish up documenting the interpretation of this function, but pleased to have figured this out and have a more concrete understanding of exactly what it is.
            I've renamed the function "calculate_pressure_from_air_mass()" in my previous post to "p_egbp_calc()" given, as I've been working through everything, I've identified that this function is looking up a value for exhaust gas back pressure.
            This is the function with parameter and variable names that make sense:
Name:	Screenshot 2025-03-14 at 6.15.12 PM.png
            The function looks up a curve which provides an estimated value of exhaust gas back pressure based on current ML (air mass flow).
            This value is relative (e.g. it's just the back pressure component). so this is then added to P_UMG_FILTER (ambient air pressure) to get an absolute exhaust gas back pressure measurement.
            This value is filtered through a PT1 filter and then checked for max/min values for plausibility, before returning.
            Here's what the parameters look like:
Name:	Screenshot 2025-03-14 at 6.18.02 PM.png
            The calculated value p_egbp is then used in the calculation of rg_m.
              I'm continuing to make good progress. I've now understood and named about 70 of the 112-odd CSL specific parameters. The names are of course my best guess as to what they would logically be named based on what I can figure out from BMW's naming convention. Unless anyone who has access to the actual names of these parameters is willing to share then my made-up names will have to do :-)
              There's about 40 more parameters which I'm still working through to establish their purpose and what they should be called, but I'm very pleased with how it's going. I'm categorizing as I go (as can be seen in the screenshot below), which shows the modules which contain changes for 0401.
Name:	Screenshot 2025-03-20 at 9.47.07 PM.png
                Great work as always mate.
                  8a980 KL_TANM_PT1_INIT
                  8e5f4 K_RF_DIAG_F_KATH
                  8e5f6 K_RF_DIAG_F_VAN
                  8e5f8 K_RF_DIAG_SCHWELLE
                  8e848 KF_RF_KORR_DRREL
                  8e6c8 K_RG_R
                  8e6ca K_RG_V_HUB
                  8e6cc K_RG_ZYLANZ_BANK
                    8e6c8 K_RG_R
                    8e6ca K_RG_V_HUB
                    Amazing - thank you so so much!
                      ppm008 really appreciate your help - any chance I could list out all the parameter addresses I'm working on and see if you've got details for any others? I've come up with names for a bunch but if it's possible to confirm the actual names that would be even more ideal. (don't want to bug you too much though so feel free to say no!)
                        These are all of the parameters from the master binary which we currently don't have the actual names for. For anyone who's wondering the addresses below are as the prog binary references them, so the actual addresses in the partial would be the value below minus 0x80000. e.g. 00088826 would be 0x8826.
                        00088826
                        00089840
                        00089a4c
                        0008a6c5
                        0008a97a
                        0008a97c
                        0008a97e
                        0008a9a2
                        0008a9a3
                        0008a9a4
                        0008a9a6
                        0008a9a8
                        0008a9aa
                        0008c354
                        0008c35a
                        0008c35c
                        0008c376
                        0008c378
                        0008c37a
                        0008c37b
                        0008c37c
                        0008c37e
                        0008c380
                        0008c382
                        0008c384
                        0008c3db
                        0008c558
                        0008c55a
                        0008c55c
                        0008c56c
                        0008c56e
                        0008c582
                        0008c59e
                        0008c5ba
                        0008c5e6
                        0008c682
                        0008d000
                        0008d002
                        0008d201
                        0008d202
                        0008d204
                        0008d205
                        0008d220
                        0008d222
                        0008d2ee
                        0008d2f0
                        0008d2f2
                        0008d2f4
                        0008d2f6
                        0008d2f8
                        0008d2fa
                        0008d2fc
                        0008d716
                        0008db30
                        0008df4a
                        0008dfac
                        0008e056
                        0008e088
                        0008e08a
                        0008e08c
                        0008e08d
                        0008e08e
                        0008e25c
                        0008e5e4
                        0008e5e8
                        0008e5ea
                        0008e5ec
                        0008e5ed
                        0008e5ee
                        0008e5f0
                        0008e5f2
                        0008e5fa
                        0008e5fc
                        0008e5fe
                        0008e600
                        0008e602
                        0008e604
                        0008e61e
                        0008e638
                        0008e69a
                        0008e69c
                        0008e69e
                        0008e6a0
                        0008e6a2
                        0008e6a4
                        0008e6c6
                        0008e6ce
                        0008e6d0
                        0008e6d2
                        0008e6d4
                        0008e6d6
                        0008e708
                        0008e732
                        0008e764
                        0008e7ae
                        0008e8fe
                        0008e918
                        0008e91a
                        And these are all the parameters from the slave binary which we currently don't have actual names for. I've included all the SMG parameters (0008a8xx to 0008aexx) which are missing actual names as well. Not sure if anyone has those, but thought I'd include them for completeness. To convert the below addresses to the offset in the partial it's what's below minus 0x88000. e.g. 0008808a would be 0x008a.
                        0008808a
                        0008903f
                        0008a1da
                        0008a1dc
                        0008a1de
                        0008a1df
                        0008a1e0
                        0008a1e2
                        0008a1e4
                        0008a1fa
                        0008a1fc
                        0008a1fe
                        0008a200
                        0008a202
                        0008a204
                        0008a206
                        0008a228
                        0008a24a
                        0008a24c
                        0008a24e
                        0008a251
                        0008a252
                        0008a253
                        0008a254
                        0008a255
                        0008a256
                        0008a258
                        0008a259
                        0008a25a
                        0008a25c
                        0008a25e
                        0008a260
                        0008a262
                        0008a263
                        0008a264
                        0008a265
                        0008a80e
                        0008a811
                        0008a814
                        0008a816
                        0008a817
                        0008a818
                        0008a819
                        0008a81a
                        0008a81b
                        0008a81c
                        0008a81e
                        0008a821
                        0008a824
                        0008a826
                        0008a82a
                        0008a82c
                        0008a830
                        0008a832
                        0008a838
                        0008a83c
                        0008a83d
                        0008a840
                        0008a842
                        0008a844
                        0008a846
                        0008a848
                        0008a84a
                        0008a84c
                        0008a850
                        0008a852
                        0008a853
                        0008a856
                        0008a85a
                        0008a85e
                        0008a860
                        0008a862
                        0008a865
                        0008a866
                        0008a867
                        0008a883
                        0008a88a
                        0008a88c
                        0008a88d
                        0008a896
                        0008a898
                        0008a89c
                        0008a89d
                        0008a8a2
                        0008a8b8
                        0008a8ba
                        0008a8c4
                        0008a8d4
                        0008a8e2
                        0008a918
                        0008a96e
                        0008a9a0
                        0008a9aa
                        0008a9b4
                        0008a9be
                        0008a9cc
                        0008a9da
                        0008aa30
                        0008aa44
                        0008aa52
                        0008aad2
                        0008aadc
                        0008aae4
                        0008aeb4
                        0008e706
                        0008e707
                          If anyone has any info about these 4 curves it would be super useful to know. From the code I I've worked through so far I *think* that 0xe708 and 0xe732 respectively are possibly representing molar mass of the residual gas mix based on camshaft position, but not overly confident about that yet.
Name:	Screenshot 2025-03-23 at 7.54.58 AM.png
                            0x00ffe508 and 0x00ffe50a appear to be "total count of interrupts" and "number of interrupt service routines currently in progress" (note it is possible for this to be greater than 1 as a higher priority interrupt will "interrupt" a lower priority ISR) respectively.
                            I've named these "sys_interrupt_counter" and "sys_active_interrupts".
                            edit: renamed to sys_isr_count to mirror BMW's naming of CAN_ISR_COUNT
                              0x00ffeb36 is the 32 bit telegram from the MFL to the DME with the cruise control buttons status. This variable in turn is populated from the TPU config RAM (0x00ffff08) which is a shared RAM section between the DME and the TPU to allow transfer of data. The TPU facilitates the one-wire serial interface to the MFL.
                              Section 8.3.2 in 3.05 EGAS Safety Concept in the funktionsrahmen describes how this works and it seems that this is pretty much how it's implemented in the code as well. The safety concept code is really interesting to dig into and seems in general to be pretty close to how it's documented in the funktionsrahmen.
                                This one is interesting. This (function at 0x00011e3c) is a debug function that runs in the background task. It tracks the time in milliseconds since the function last run and captures the longest time in DB_TBGND_MAX and the average in DB_TBGND_AV. This would have been useful during development as the BMW engineers were adding to the codebase to monitor the system and make sure that the CPU was getting to the background task regularly enough.
Name:	Screenshot 2025-04-02 at 8.32.58 PM.png
