Need help doing vanos test with INPA
    A friend of mine has an S54 in an E30 he did a Vanos refresh with beisan parts but now has a code for inlet Vanos.
    We ran a Vanos test using the script in this thread and not really sure how to interpret it but it doesn't look good. We ran the test two times and the results look similar, can we drove the car for about 30 minutes? Getting everything nice and hot still the results look pretty similar.
    I'm starting to think that they didn't set the timing right the plungers and the range of the cam gear sprockets..
    Exhaust side looks fine. It's the intake side that looks like it has a mechanical issue.
    The first thing in your log it commands the intake to -10, the result it wants to see is 0, the result you get is 15, so the cam isn’t able to retard all the way it wants to, the computer obviously knows this so no wonder it sets a code.
    The second thing wrong with your log is the adjustment times for the intake being just 0, I think this is just a result of the same issue since it doesn’t make sense measuring the adjustment time for an adjustment that doesn’t have the entire proper range available to it.
    So yeah, disassemble and figure out what went wrong.
      Sorry if this is a super noob question.
      All i need is the same cable I use for INPA to conduct this test?
      The car needs to be idling to run the test?
        Yeah, same cable and idle, as i remember- coolant and oil temp above ~60
          So finally got time to run this test. Took the car for a spirited drive before testing.
          Here are my results. I think it looks okay compared to other peoples results?
          Code:
          Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
          Start     : 02.09.2023 14:34:57.4
          Nr 1(  1) : 02.09.2023 14:34:57.6
          apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","")
            JOB_STATUS                      = OKAY
            EVAN_ISTWERT                    = -1           FF FF FF FF  ÿÿÿÿ
            EVAN_SOLLWERT                   = -10          FF FF FF F6  ÿÿÿö
            EVAN_ISTWERT_EINH               = Grad KW
            EVAN_SOLLWERT_EINH              = Grad KW
          Nr 2(  1) : 02.09.2023 14:35:03.0
          apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG","","")
            JOB_STATUS                      = OKAY
            EVAN_ISTWERT                    = 59                 00 3B  .;
            EVAN_SOLLWERT                   = 75                 00 4B  .K
          Nr 3(  1) : 02.09.2023 14:35:08.4
          apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT","","")
            JOB_STATUS                      = OKAY
            EVAN_VERSTELLZEIT_FRUEH         = 205                00 CD  .Í
            EVAN_VERSTELLZEIT_SPAET         = 206                00 CE  .Î
            EVAN_VERSTELLZEIT_FRUEH_EINH    = ms
            EVAN_VERSTELLZEIT_SPAET_EINH    = ms
          Nr 4(  1) : 02.09.2023 14:35:14.7
          apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","")
            JOB_STATUS                      = OKAY
            EVAN_STATUS                     = EVANOS-1-Einheit vorzeitig weggedriftet
          Nr 5(  1) : 02.09.2023 14:35:29.2
          apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","")
            JOB_STATUS                      = OKAY
            AVAN_ISTWERT                    = 1                  00 01  ..
            AVAN_SOLLWERT                   = -10          FF FF FF F6  ÿÿÿö
            AVAN_ISTWERT_EINH               = Grad KW
            AVAN_SOLLWERT_EINH              = Grad KW
          Nr 6(  1) : 02.09.2023 14:35:34.5
          apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG","","")
            JOB_STATUS                      = OKAY
            AVAN_ISTWERT                    = 48                 00 30  .0
            AVAN_SOLLWERT                   = 55                 00 37  .7
          Nr 7(  1) : 02.09.2023 14:35:39.8
          apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT","","")
            JOB_STATUS                      = OKAY
            AVAN_VERSTELLZEIT_FRUEH         = 168                00 A8  .¨
            AVAN_VERSTELLZEIT_SPAET         = 213                00 D5  .Õ
            AVAN_VERSTELLZEIT_FRUEH_EINH    = ms
            AVAN_VERSTELLZEIT_SPAET_EINH    = ms
          Nr 8(  1) : 02.09.2023 14:35:46.3
          apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","")
            JOB_STATUS                      = OKAY
            AVAN_STATUS                     = AVANOS-1-Einheit vorzeitig weggedriftet
          Stop      : 02.09.2023 14:36:01.6
          Dauer     : 64.2 s
            Looks fine. Reaction time is really good.
            intake &exhaust camshafts is 1 degree out of spec. But I wouldn't bother. 1 degree is fine.
              Guys, done vanos rebuild and test in tool32. Are all ok? I Think something wrong with exhaust cam. Someone who understands results- comment plz
              Start : 16.09.2023 16:00:46,5
              Nr 1( 1) : 16.09.2023 16:00:46,6
              apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
              JOB_STATUS = OKAY
              EVAN_ISTWERT = -1 FF FF FF FF yyyy
              EVAN_SOLLWERT = -10 FF FF FF F6 yyyo
              Nr 2( 1) : 16.09.2023 16:00:51,9
              apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
              JOB_STATUS = OKAY
              Nr 3( 1) : 16.09.2023 16:00:57,2
              apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
              JOB_STATUS = OKAY
              EVAN_VERSTELLZEIT_FRUEH = 228 00 E4 .a
              EVAN_VERSTELLZEIT_SPAET = 219 00 DB .U
              Nr 4( 1) : 16.09.2023 16:01:03,5
              apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
              JOB_STATUS = OKAY
              Nr 5( 1) : 16.09.2023 16:01:17,8
              apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
              JOB_STATUS = OKAY
              AVAN_ISTWERT = 36 00 24 .$
              AVAN_SOLLWERT = -10 FF FF FF F6 yyyo
              Nr 6( 1) : 16.09.2023 16:01:23,2
              apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
              JOB_STATUS = OKAY
              AVAN_ISTWERT = 39 00 27 .'
              Nr 7( 1) : 16.09.2023 16:01:28,5
              apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
              JOB_STATUS = OKAY
              AVAN_VERSTELLZEIT_FRUEH = 165 00 A5 .?
              AVAN_VERSTELLZEIT_SPAET = 205 00 CD .I
              Nr 8( 1) : 16.09.2023 16:01:34,8
              apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
              JOB_STATUS = OKAY
              Stop : 16.09.2023 16:01:49,4
              Dauer : 62,9 s​
                Done several tests- Intake cam is stable from -1 to 59, exhaust has different angles- first as i see- adaptation on exhaust cam is -8, so in tests i've seen different results- first test on exhaust where target is -10 fact angles was: -3, -5, -8, +10 +15 +13 etc, cam is always has different start position, when second test in advance- +40, +38, +37 etc. Engine has 288/280 shrick cams and no error codes at all, is it could be solenoids pack issue or mecanical wrong timed exhaust cam? will do retiming soon, but now i aware of vanos- should i change it or it is only timing issue
                  JOB_STATUS = OKAY
                  JOB_STATUS = OKAY
                  Your exhaust camshaft does not reach the end stops (0 - 45). It also doesn't use the full range (+45 degrees). Doubt it would be a timing issue. More solenoids and or piston seals.
                    Yeah, always different values in each test, already installed beisan kit on mechanical vanos part, didnt maintaned solenoids. Now i'm in doubts- buy new coil pack or whole vanos module, but ECU didnt show any error codes on vanos or camhaft position at all
                      Thanks Tomba for putting together the test file, it's super helpful. I couldn't get the VANOS tests in INPA since I have a K+DCAN cable and DIS didn't show VANOS tests, so your test file was perfect for me!
                      I recently did a full VANOS rebuild using Beisan components (solenoid pack, all seals, pump disk, pressure regulator filter, cleaned vanos valve/manifold, etc) and ran the tests with a fully warmed up engine with 100 miles on it since the rebuild.
                      Code:
                      Start : 04.10.2023 13:26:00.3
                      Nr 1( 1) : 04.10.2023 13:26:00.4
                      JOB_STATUS = OKAY
                      [EVAN_ISTWERT = 0 00 00 ..
                      Nr 2( 1) : 04.10.2023 13:26:06.0
                      JOB_STATUS = OKAY
                      Nr 3( 1) : 04.10.2023 13:26:11.3
                      JOB_STATUS = OKAY
                      EVAN_VERSTELLZEIT_FRUEH = 209 00 D1 .Ñ
                      EVAN_VERSTELLZEIT_SPAET = 221 00 DD .Ý
                      Nr 4( 1) : 04.10.2023 13:26:17.9
                      JOB_STATUS = OKAY
                      Nr 5( 1) : 04.10.2023 13:26:32.6
                      JOB_STATUS = OKAY
                      AVAN_ISTWERT = 0 00 00 ..
                      Nr 6( 1) : 04.10.2023 13:26:38.1
                      JOB_STATUS = OKAY
                      Nr 7( 1) : 04.10.2023 13:26:43.5
                      JOB_STATUS = OKAY
                      AVAN_VERSTELLZEIT_FRUEH = 167 00 A7 .§
                      AVAN_VERSTELLZEIT_SPAET = 190 00 BE .¾
                      Nr 8( 1) : 04.10.2023 13:26:50.1
                      JOB_STATUS = OKAY
                      Stop : 04.10.2023 13:27:05.1
                      Dauer : 64.9 s
                      It looks like angles and reaction time look good. I did rerun it and the intake showed 60 instead of 59; either way, it doesn't seem concerning. I actually had a hard time with timing the intake. It kept being off a little bit, but sapote had some great advice and discussion on another thread on how to get it shored up. So also, thank you sapote!
                      The only thing I don't understand is the leak test (DICHTHEIT/dichtheitsprüfung) results. It says that both intake and exhaust both drifted prematurely (Einheit vorzeitig weggedriftet). Is this actually a problem or does it always say this? Looking at all the other post they all seem to say this.
                        Yes, is a problem. Should not drift more than 5deg
                          The dichtheid test, I already posted my suspicion on this. Maybe it needs to be set differently. I do had a few cars in the past who succeeded the test flawlessly. Newer ECUs have the ability to show the actual measured values during such tests. For the MSS54 I haven't found it yet.
                          Before the test the VANOS piston might need to move up (advance) then close both control valves (advance & retard) and observe the drift. A leak free system shouldn't drift to much. But I do suspect it is set correctly once the test it self is started.
                          You can try the following,
                          1. STEUERN_EVANOS1_FRUEHANSCHLAG and then,
                          2. STEUERN_EVANOS1_DICHTHEIT
                          Other option would be to activate the solenoids on your own with a separate device to advance with the engine speed lifted [STEUERN_LLS_TESTDREHZAHL] and then observe how the actual camshaft is moving once you don't activate them [STATUS_EVANOS1_IST] for intake, I would suggest TestO with DS2 Serial job for exhaust as I can't find the actual exhaust vanos position it in the job list.
                          Numbers do look good in your result.
                            I ran those two tests, FRUEHANSCHLAG (early stop?) then DICHTHEIT (leak test) on a warm engine.
                            Intake and exhaust both gave status "Messung beendet, Soll-/Istwert-Vergleich ausfuehren" ("Measurement finished, carry out setpoint/actual value comparison") and setpoint and actual are within 5 degrees, so it seems leak/drift is okay!
                            Here are my results:
                            Code:
                            Test file : C:\EDIABAS\ECU\MSS54_VANOS_LEAKTESTS.TST
                            Start     : 06.10.2023 11:55:06.8
                            Nr 1(  1) : 06.10.2023 11:55:06.9
                              JOB_STATUS                      = OKAY
                            Nr 2(  1) : 06.10.2023 11:55:12.4
                              JOB_STATUS                      = OKAY
                              EVAN_STATUS                     = Messung beendet, Soll-/Istwert-Vergleich ausfuehren
                              EVAN_ISTWERT                    = 48                 00 30  .0
                              EVAN_SOLLWERT                   = 45                 00 2D  .-
                            Nr 3(  1) : 06.10.2023 11:55:27.0
                              JOB_STATUS                      = OKAY
                            Nr 4(  1) : 06.10.2023 11:55:32.3
                              JOB_STATUS                      = OKAY
                              AVAN_STATUS                     = Messung beendet, Soll-/Istwert-Vergleich ausfuehren
                              AVAN_ISTWERT                    = 17                 00 11  ..
                              AVAN_SOLLWERT                   = 15                 00 0F  ..
                            Stop      : 06.10.2023 11:55:47.9
                            Dauer     : 41.1 s
                            It's pretty straight forward, but in case anyone needs it I added a test file, just like with the other one, unzip it and place it in C:\EDIABAS\Ecu
                            The contents are exactly what Tomba recommended, but for both intake and exhaust.
                            Code:
                            1|mss54ds0|STEUERN_EVANOS1_FRUEHANSCHLAG
                            1|mss54ds0|STEUERN_EVANOS1_DICHTHEIT
                            1|mss54ds0|STEUERN_AVANOS1_FRUEHANSCHLAG
                            1|mss54ds0|STEUERN_AVANOS1_DICHTHEIT​
                            Thanks again Tomba!
                              Hi everyone, big thanks to Tomba for putting this test together.
                              Is there anyone here who can check my results? Im chasing some vague vanos codes when running the car hard.
                              JOB_STATUS = OKAY
                              EVAN_ISTWERT = -2 FF FF FF FE ÿÿÿþ
                              Nr 2( 1) : 19.01.2024 19:56:51.5
                              JOB_STATUS = OKAY
                              EVAN_ISTWERT = 57 00 39 .9
                              Nr 3( 1) : 19.01.2024 19:56:56.9
                              JOB_STATUS = OKAY
                              EVAN_VERSTELLZEIT_FRUEH = 229 00 E5 .å
                              EVAN_VERSTELLZEIT_SPAET = 212 00 D4 .Ô
                              Nr 4( 1) : 19.01.2024 19:57:03.4
                              JOB_STATUS = OKAY
                              Nr 5( 1) : 19.01.2024 19:57:17.8
                              JOB_STATUS = OKAY
                              Nr 6( 1) : 19.01.2024 19:57:23.1
                              JOB_STATUS = OKAY
                              AVAN_ISTWERT = 47 00 2F ./
                              Nr 7( 1) : 19.01.2024 19:57:28.4
                              JOB_STATUS = OKAY
                              AVAN_VERSTELLZEIT_FRUEH = 193 00 C1 .Á
                              Nr 8( 1) : 19.01.2024 19:57:34.8
                              JOB_STATUS = OKAY
                              Stop : 19.01.2024 19:57:49.7
                              Dauer : 63.8 s
                                JOB_STATUS = OKAY
                                JOB_STATUS = OKAY
                                JOB_STATUS = OKAY
                                JOB_STATUS = OKAY
                                JOB_STATUS = OKAY
                                JOB_STATUS = OKAY
                                JOB_STATUS = OKAY
                                JOB_STATUS = OKAY
                                Dauer : 63.8 s
                                Hi! Intake camshaft is out of spec on 2 degrees but here shouldnt be any issues, but it not work in full 60 degrees, 59 only, same with exhaust- position is good but 47 degrees, should be 48. Reaction time is good!
