Need help doing vanos test with INPA
    Looks good, intake is 1 degree off but I wouldn't change it. So far nothing strange I could observe with these values.
      Maybe some bad fuel?
        Thanks sir for looking. I really need to learn how to decipher these values my self
        I want to go can a few pages and compare the test results from my s54 turbo car and thus S54 wagon and see how they compare.
          Possibly, I and to some octane booster and see if there's any change
            pinging sounds more like cumbustion is not OK. Would check fuel trims and knock adaption too.
            +1
            Grab yourself a Bryson mullet tune
              It's very simple, not rocket science.
              The first job performed is STEUERN_EVANOS1_FRUEHANSCHLAG -> Command inlet VANOS advance until endstop.
              When it completes you get back the SOLLWERT, German for setpoint, and the ISTWERT, which is the actual value.
              The setpoint gets always set to -10, the value it expects to see is 0.
              I would say +-1 would be deemed good, +-2 would be acceptable, anything beyond that and your engine just isn't in time properly.
              After that it goes to STEUERN_EVANOS1_SPAETANSCHLAG -> Command inlet VANOS retard until endstop.
              The setpoint here is 75, while it expects to see 60. Again here +-1 would be good +-2 would be acceptable, etc.
              Next up is STEUERN_EVANOS1_VERSTELLZEIT -> Command inlet VANOS adjustment time
              It returns EVAN_VERSTELLZEIT_FRUEH which is the time it took to fully retard the intake cam, and EVAN_VERSTELLZEIT_SPAET which represents the time it took to fully advance the intake cam.
              We consider under 250ms-ish good here, DIS allows up to 500ms before it fails you.
              The rest of the test is the same thing but for the AVANOS which is just the exhaust side.
              The only difference being the intake ranges from 0-60, while the exhaust ranges from 0-48, same tolerances apply, exhaust is usally a bit faster on the adjustment due to less range.
                So I had a question about the Vanos test.
                One of my cars is starting to have the marbles in a can sound at low RPM with a load on the engine. Sounds like pinging but it's a fresh rebuild. It's the same sign you're hearing cars when you run low octane fuel when you get the marbles in the canned sound.
                Doing some searching I came across several instances where they mentioned timing being off.
                I have never heard the pinging before until recently, so my guess is maybe it would probably go away if I reset Vanos adaptations and then probably come back
                So if I want to run the Vanos test, should I run it now and it's current state or should I run it after I reset adaptations?
                And would a successful vanos test mean that the engine is properly timed
                I also had these Shadow codes. I never saw a check engine light but I decided to check codes today and saw these Shadow codes. Inlet Vanos retard valve errors
                This sounds like the CSL tune on stock cams if your marbles are below 2800rpm or so at medium/high throttle. Cam offsets will not solve this. I believe the only way to eliminate it is to remap several of the fields in the CSL file itself beyond a simple tune. As Heinz mentioned, I have created maps that solve this and bring back stock drivability. I call them the mullet tune. If you’re interested, shoot me a PM.
                  Tomba, thank you so much for the .tst file! Very easy to perform with tools that I already own!
                  To keep the thread rolling, here are my results from the test, on a freshly rebuilt motor with all new chains, chain guides, vanos seals, etc. with a few dyno pulls and 1 race weekend on it.
                  I may re-time it over the winter to get that last 2 degrees on the intake cam.
                  Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
                  Start : 29.10.2024 17:28:44.6
                  Nr 1( 1) : 29.10.2024 17:28:44.8
                  apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  EVAN_ISTWERT = -2 FF FF FF FE ÿÿÿþ
                  EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
                  EVAN_ISTWERT_EINH = Grad KW
                  EVAN_SOLLWERT_EINH = Grad KW
                  Nr 2( 1) : 29.10.2024 17:28:50.2
                  apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  EVAN_ISTWERT = 58 00 3A .:
                  EVAN_SOLLWERT = 75 00 4B .K
                  Nr 3( 1) : 29.10.2024 17:28:55.7
                  apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
                  JOB_STATUS = OKAY
                  EVAN_VERSTELLZEIT_FRUEH = 263 01 07 ..
                  EVAN_VERSTELLZEIT_SPAET = 226 00 E2 .â
                  EVAN_VERSTELLZEIT_FRUEH_EINH = ms
                  EVAN_VERSTELLZEIT_SPAET_EINH = ms
                  Nr 4( 1) : 29.10.2024 17:29:02.1
                  apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
                  JOB_STATUS = OKAY
                  EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
                  Nr 5( 1) : 29.10.2024 17:29:16.5
                  apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  AVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ
                  AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
                  AVAN_ISTWERT_EINH = Grad KW
                  AVAN_SOLLWERT_EINH = Grad KW
                  Nr 6( 1) : 29.10.2024 17:29:22.0
                  apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  AVAN_ISTWERT = 47 00 2F ./
                  AVAN_SOLLWERT = 55 00 37 .7
                  Nr 7( 1) : 29.10.2024 17:29:27.4
                  apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
                  JOB_STATUS = OKAY
                  AVAN_VERSTELLZEIT_FRUEH = 219 00 DB .Û
                  AVAN_VERSTELLZEIT_SPAET = 215 00 D7 .×
                  AVAN_VERSTELLZEIT_FRUEH_EINH = ms
                  AVAN_VERSTELLZEIT_SPAET_EINH = ms
                  Nr 8( 1) : 29.10.2024 17:29:33.8
                  apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
                  JOB_STATUS = OKAY
                  AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
                  Stop : 29.10.2024 17:29:48.8
                  Dauer : 64.2 s
                    JOB_STATUS = OKAY
                    JOB_STATUS = OKAY
                    JOB_STATUS = OKAY
                    JOB_STATUS = OKAY
                    JOB_STATUS = OKAY
                    JOB_STATUS = OKAY
                    JOB_STATUS = OKAY
                    JOB_STATUS = OKAY
                    Dauer : 64.2 s
                    Actually you don't need to retime engine- there is full diapason of vanos (from -2 to 58 (60 degrees) and from -1 to 47 (48 degrees). Starting position of cams will be zeroed with adaptations.
                      Cumbustion, you mean fuel contamination?
                        Could be yes.
                          Hello everyone, I found this post very interesting and I just tested it on an S50B32. Could someone tell me if my test is correct? Thank you.
                          Test file : C:\EDIABAS\ECU\BMW_S50B32_VANOS_TEST.TST
                          Start : 08.06.2025 10:44:35,0
                          Nr 1( 1) : 08.06.2025 10:44:35,1
                          apiJob("bmss501","ident","","")
                          ID_EML = 0 00 00 ..
                          ID_OBD2 = 0 00 00 ..
                          ID_AI_NR = 02
                          ID_HW_NR = 14 00 0E ..
                          ID_MOTOR = S50_MSS50
                          ID_SW_NR = 04
                          ID_BMW_NR = 1406611
                          ID_EWS_SS = 2 00 02 ..
                          ID_LIEF_NR = 0000115852
                          ID_PROD_NR = 971810576
                          JOB_STATUS = OKAY
                          ID_DATUM_KW = 20
                          ID_BUS_INDEX = 00
                          ID_COD_INDEX = 00
                          ID_DATUM_JAHR = 97
                          ID_DIAG_INDEX = 30
                          ID_LU_MESSUNG = 0 00 00 ..
                          ID_AIF_VORHANDEN = 1 00 01 ..
                          ID_LAMBDA_STEREO = 1 00 01 ..
                          ID_SG_HERSTELLER = 0 00 00 ..
                          Nr 2( 1) : 08.06.2025 10:44:35,2
                          apiJob("bmss501","STATUS_MOTORTEMPERATUR","","")
                          JOB_STATUS = OKAY
                          STATUS_MOTORTEMPERATUR_EINH = Grad C
                          STATUS_MOTORTEMPERATUR_WERT = 7.200000E+001
                          Nr 3( 1) : 08.06.2025 10:44:35,4
                          apiJob("bmss501","STATUS_OEL_TEMPERATUR","","")
                          JOB_STATUS = OKAY
                          STATUS_OEL_TEMPERATUR_EINH = Grad C
                          STATUS_OEL_TEMPERATUR_WERT = 4.300000E+001
                          Nr 4( 1) : 08.06.2025 10:44:35,7
                          apiJob("bmss501","STEUERN_EVANOS_FRUEHANSCHLAG","" ,"")
                          JOB_STATUS = OKAY
                          EVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ
                          EVAN_SOLLWERT = 0 00 00 ..
                          Nr 5( 1) : 08.06.2025 10:44:41,0
                          apiJob("bmss501","STEUERN_EVANOS_SPAETANSCHLAG","" ,"")
                          JOB_STATUS = OKAY
                          EVAN_ISTWERT = 59 00 3B .;
                          EVAN_SOLLWERT = 60 00 3C .<
                          Nr 6( 1) : 08.06.2025 10:44:46,3
                          apiJob("bmss501","STEUERN_EVANOS_VERSTELLZEIT","", "")
                          JOB_STATUS = OKAY
                          EVAN_VERSTELLZEIT_FRUEH = 142 00 8E .?
                          EVAN_VERSTELLZEIT_SPAET = 174 00 AE .®
                          Nr 7( 1) : 08.06.2025 10:44:52,6
                          apiJob("bmss501","STEUERN_EVANOS_DICHTHEIT","","")
                          JOB_STATUS = OKAY
                          EVAN_STATUS = VANOS-Einheit undicht, Messung abgebrochen
                          Nr 8( 1) : 08.06.2025 10:45:06,9
                          apiJob("bmss501","STEUERN_AVANOS_FRUEHANSCHLAG","" ,"")
                          JOB_STATUS = OKAY
                          AVAN_ISTWERT = 1 00 01 ..
                          AVAN_SOLLWERT = 0 00 00 ..
                          Nr 9( 1) : 08.06.2025 10:45:12,3
                          apiJob("bmss501","STEUERN_AVANOS_SPAETANSCHLAG","" ,"")
                          JOB_STATUS = OKAY
                          AVAN_ISTWERT = 40 00 28 .(
                          AVAN_SOLLWERT = 45 00 2D .-
                          Nr10( 1) : 08.06.2025 10:45:17,6
                          apiJob("bmss501","STEUERN_AVANOS_VERSTELLZEIT","", "")
                          JOB_STATUS = OKAY
                          AVAN_VERSTELLZEIT_FRUEH = 184 00 B8 .¸
                          AVAN_VERSTELLZEIT_SPAET = 225 00 E1 .á
                          Nr11( 1) : 08.06.2025 10:45:23,8
                          apiJob("bmss501","STEUERN_AVANOS_DICHTHEIT","","")
                          JOB_STATUS = OKAY
                          AVAN_STATUS = VANOS-Einheit undicht, Messung abgebrochen
                          Stop : 08.06.2025 10:45:38,4
                          Dauer : 63,4 s
                            Hey everyone, helping someone out with an E46 M3 that is having issues after having the vanos refurbished at another shop. The symptoms are the following DME codes:
                            1: Driver / fuel pump relay
                            5E: Inlet vanos, adaptation
                            B8: Function, inlet vanos
                            In addition to that there is also an issue where the car usually wont start on the first attempt. It will crank endlessly but usually fires right up the second try. It also feels very down on power compared to my E46 M3. I swapped in a tested good fuel pump relay which did not fix the starting issue. I am planning to measure fuel pressure to make sure the fuel pump is working fine, but I was wondering if the intake timing being off could possibly cause the hard starting issue and the vanos codes. I found this forum thread and the test Tomba made and ran it. (Thanks again Tomba, you tuned an E60 M5 bin for me a while back so I could run S65 injectors. Thank you Sapote as well for being so involved on the forum).
                            Here are the results:
                            Start : 10.08.2026 18:51:47.0
                            Nr 1( 1) : 10.08.2026 18:51:47.4
                            JOB_STATUS = OKAY
                            EVAN_ISTWERT = 38 00 26 .&
                            Nr 2( 1) : 10.08.2026 18:51:53.0
                            JOB_STATUS = OKAY
                            EVAN_ISTWERT = 75 00 4B .K
                            Nr 3( 1) : 10.08.2026 18:51:59.0
                            JOB_STATUS = OKAY
                            EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
                            EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
                            Nr 4( 1) : 10.08.2026 18:52:05.8
                            JOB_STATUS = OKAY
                            Nr 5( 1) : 10.08.2026 18:52:20.7
                            JOB_STATUS = OKAY
                            AVAN_ISTWERT = 0 00 00 ..
                            Nr 6( 1) : 10.08.2026 18:52:26.2
                            JOB_STATUS = OKAY
                            AVAN_ISTWERT = 49 00 31 .1
                            Nr 7( 1) : 10.08.2026 18:52:31.7
                            JOB_STATUS = OKAY
                            AVAN_VERSTELLZEIT_FRUEH = 165 00 A5 .¥
                            AVAN_VERSTELLZEIT_SPAET = 205 00 CD .Í
                            Nr 8( 1) : 10.08.2026 18:52:38.4
                            JOB_STATUS = OKAY
                            Stop : 10.08.2026 18:52:55.0
                            Dauer : 68.1 s
                            Compared to the other results in this thread the intake values in test 1 and 2 seem very problematic. Since the minimum value is 38 and goes all the way up to the requested value of 75 do you all think that the intake cam being out of time could be the issue?
                            I appreciate the help!
                              I will take a look
                                It expects to see 0 and yours is 38, meaning the intake cam is too retarded. Need to remove valve cover and double check the vanos timing on the Intake side.
                                How did you check the cam timing? Using the bridge tool?
