Forcing OBD Readiness
    Hello everybody, I spent some time making a patchlist for the common versions disabling the DTCs mentioned above. Enjoy. I have not been able to test it as I don't have easy access to MSS54s. Please let me know if it works
      I was able to test my file on 2 cars today and it worked
      I patched the SAP delete, rear O2 delete, and forced OBD readiness.
      Tested on SW version 2101 and 2801.
        Patch worked great for me. Thanks!
        2003.5 SG/Grey
          Method 4 has worked for me for years.
          2003 E46 M3 TiAg/Cinnamon 6MT
          2005 E46 330i ZHP Imola/Sand
          Instagram:@thegenius46m
            Anybody figure this out for MSS6X yet? I tried the same method that was used on MSS54 and it didn't work. I suppressed 104 DTCs and nothing. I came across an interesting page on inpa that showed completion condition counts vs conditions encountered counts that calculated to a ratio. From what I can tell, if the ratio is above 1 the monitor will set to ready
              Hey guys, reviving to ask a question about OBD readiness expectations... After patching the DTC codes, should I expect my OBD monitors to immediately go green? Or does it need to go through a drive cycle? What's your process?
              I see a quote here on the XDF github wiki that shows:
              Regardless of which method you employ, the DME's errors must be cleared after reflashing the DME with the updated binary.
              Seems to imply that you need to 'reset codes' immediately afterwords and take it for a drive?
                Tested on SW version 2701, works as well, thank you
                /// 2004 SG/IR - Build Thread
