Who's got any winter projects going on for their track car?
Trying to remember the year (maybe '97ish) but once saw Michael Andretti flip upside down thru the esses there in a cart race. Never had the balls to try an event there when i was tracking a C5 hardtop back in the day.Originally posted by CrookedCommie View Post
Yeah the shit pavement and low traction is unique, there's a few high risk places and this is one of them. I'm not sure why they decided against having a tire wall in front of the concrete at this exact spot, although most loop it coming into thunder valley and crash on the inside, where there is a tire wall. Most of the significant off track stuff I've seen here in the last ten years is due to fluid spills.
HPDE Cup events are limited with little kids. Not letting that stop my spending. Let's see if I finish these by spring:
- M24 interior door panels, parcel shelf
- CAE shifter
- Poly rear windscreen and vented qtrs
- Fog light and washer delete
- Fluids, filters and misc bushings
@mannschaftschnell on IG for pics, if I ever get it done
CAE Shifter Install
Replace Wheel Bearings
Install ZHP rack that’s been sitting around…Hope the seals aren’t f**ked and there isn’t too much play.
Buying a new DME so the car can be properly tuned (ugh…problems with my EEPROMS)
One of the bolts from my camber plates through the front left shock tower has been rubbing against the shock tower bolt opening and the hole has been elongated/out of round. I have no idea how this happened as I mark my torqued shock tower bolts, but it certainly happened, no idea how, I’m thinking my strut brace is partially or fully to blame. I discovered it after doing a post season inspection. Who knows, but it’s freaking me out and pissing me off simultaneously. Don’t really know how to get that fixed and am scared to take it to someone. Have to rip the bandaid on that in the off-season. I guess a body shop is the best place. I can’t weld. F**K! F********K! If anyone has any ideas…
Novec Fire Suppression.
Mount new smartycam.
Unnecessarily giant wing. Haven’t decided yet.
Splitter. Still haven’t decided.
Canards
Buy a trailer….
Ditch headlights when the trailer arrives to save some weight up front. Rain light in the back.
Pray for my head gasket nightly.
Sent from my iPhone using Tapatalk2006 ///M3 6MT Coupe Jet Black Track Car
I have the SIR wheel bearing tool you can borrow if needed.Originally posted by Fresh1179 View PostCAE Shifter Install
Canards
Buy a trailer….
ZHP rack - I got a rebuild kit on eBay, I'm willing to bet a ZHP rack would use the same seals. I think it was $60.
Could I trouble you to link me to the recommended wheel bearing tool / kit? I have a bunch of generic kits and feel like every time I am piecing together different components to get something that works fast and efficient.Originally posted by bigjae46 View Post
Thanks
B 90 (sirtools.com)Originally posted by fourmula1 View Post
Thanks
BMW does make front and rear wheel bearing tools. Otoh, they are not as universal as the B90.
front: 83300491905
rear: 83300492287
(I have the BMW tools, they made install a breeze. At the time, the B90 kits were out of stock everywhere.)
I would also strongly recommend you get the Bav Auto half-shaft tools as well (my experience with half shafts here)
https://www.ecstuning.com/b-bav-auto.../b8800102~bav/
E36 M3
Added hood pins and patched a pair of tears on my faux carbon fiber hood. Noticed how much it was flexing driving home from my last event, and got nervous.
Trying to sort brake ducting with my splitter (using the hard backing plates). The mounts block the typical bumper holes. I had some 3d printed ducts zip ties to my lca, but one ended life at about 100mph. I have an idea, but don't think parts will arrive in time for my next event this weekend.
