M3 S54 Cooling System Hi-Temp O-ring Kits!
They are now included in the new kits. PM me if you need those. 👍Originally posted by ac427 View PostHi Wolfn8tr, Are the seals for this pipe included in the current and old kits ?TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
Looks like the eBay link doesn't work anymore. Do you still sell these?2003.5 E46 M3 Silver Grey/Cinnamon
Fixed link, thanks for the heads up.Originally posted by Sid_E46 View PostLooks like the eBay link doesn't work anymore. Do you still sell these?TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
I feel like thats a bit of a hard question, my best advice would be to do as much as your budget can handle. It’s kind of a “well since I’m here…I’ll do this”.Originally posted by maupineda View PostI think I will get this while in the US. Does anyone knows of a good reference on what should I get to do a mild refresh? My radiator is fine, car is perfect, just looking to do the right PM.
if you’re already taking hoses off to replace the gaskets inside, you’re not too far from removing a few bolts and replacing a water pump and thermostat. Maybe go ahead and replace the hoses all together too? At an absolute minimum, if you take the hoses off, change the thermostat, its easy and only like $70ish
Just ordered a set, thanks!
Depends on history of the car too, mine is higher mileage but has had regular coolant flushes for the life of the car and has always been stored indoor. Ever thing looks perfect, but recently found out the thermostat had failed after driving it in cooler weather. The "while I'm in there" and my bare minimum that I just ordered is thermostat, upper and lower coolant hose, temp switch, pump and fan clutch to cover regular wear items so I know I don't have to worry about it for another 100k. I skipped the "Genuine" only reservoir and $70 pipe.Originally posted by maupineda View PostI think I will get this while in the US. Does anyone knows of a good reference on what should I get to do a mild refresh? My radiator is fine, car is perfect, just looking to do the right PM.
Shout out to WOLFN8TR - order came in FAST and exactly depicted. Thanks for putting together this kit for the rest of us schleps!Build thread: Topaz Blue to Shark Blue
Hey WOLFN8TR . I'm going to ask a stooooopid question. Do you use the Super Lube on all the o-rings? Any you would avoid?Build thread: Topaz Blue to Shark Blue
